Re: What will it run?
[Re: RRandP92]
#2542057
08/27/18 03:34 PM
08/27/18 03:34 PM
Thumperdart
State of confusion
69 dart 3225lbs race weight,caltracs,520ci,trick flow 270, .650 lift 265ish duration solid roller, 11.5:1 compression,indy intake,1050 dominator,727,8in converter specd by ultimate, 3.70 rear gear,325/50 radial. Let's here it. Hopefully get to make some test hits Friday. Any on board data or at least a wide band...........
[Re: RRandP92]
#2542058
08/27/18 03:39 PM
08/27/18 03:39 PM
Posts: 13,411 Marion, South Carolina [><]
an8sec70cuda
I agree w/ the 9.80s when sorted out. I know I went 10.40s at 129 mph at 3700 lbs w/ less motor than you have. The radials will work just fine too.
[Re: RRandP92]
#2551531
09/18/18 03:03 PM
09/18/18 03:03 PM
Posts: 23 TN
RRandP92
TN
The good throws were at .0015 on the rods. Should have checked them over.
[Re: RRandP92]
#2552031
09/19/18 07:00 PM
09/19/18 07:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
69 dart 3225lbs race weight,caltracs,520ci,trick flow 270, .650 lift 265ish duration solid roller, 11.5:1 compression,indy intake,1050 dominator,727,8in converter specd by ultimate, 3.70 rear gear,325/50 radial. Let's here it. Hopefully get to make some test hits Friday. I'd hope in the 9's
