Well i guess i got lucky ?
#2539870
08/22/18 01:34 AM
08/22/18 01:34 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Finally got my car out of panel shop prison and pulled the motor/trans last night . Trying to locate the coolant leak in the motor .
The block is cracked in #4 main from cap up into coolant passage .
I guess from a glass half full view I am lucky , it ran maybe 6-8 passes like this and I didn't drive over the crankshaft . If only there was a readily available cross bolt iron block , I would buy 1 in a heartbeat ( realistic pricing ) Oh well time to put the new TF270 heads onto my old 440 short and keep going
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Well i guess i got lucky ?
[Re: tex013]
#2539881
08/22/18 01:58 AM
08/22/18 01:58 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Glad you caught it before it got you. Do you guys run engine diapers
[Re: pittsburghracer]
#2539911
08/22/18 07:59 AM
08/22/18 07:59 AM
tex013
Sydney,Australia
Glad you caught it before it got you. Do you guys run engine diapers No diapers , not fast enough . Be to awkward on a street car . Tex
[Re: Cab_Burge]
#2540048
08/22/18 03:05 PM
08/22/18 03:05 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Those dang stock 400 and 440 blocks will crack the main webbing once you exceed the design limits on the HP, and race it often enough. sorry to hear that ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) Detonation and main cap walking are the cause usually Fixed it for you
#2540137
08/22/18 07:28 PM
08/22/18 07:28 PM
tex013
Sydney,Australia
Those dang stock 400 and 440 blocks will crack the main webbing once you exceed the design limits on the HP, and race it often enough. sorry to hear that ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) Detonation and main cap walking are the cause usually Fixed it for you hahaha 20 months of racing once a month minimum and daily driving . BAH darn it , conservative tune and billet caps/studs back to the drawing board Tex
[Re: tex013]
#2540143
08/22/18 07:46 PM
08/22/18 07:46 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
I haven't seen or heard of a stock 400 block cracking the main webs yet ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) I know a NHRA S/G racer that broke a bunch of stock 400 main caps before switching to after market main caps, he would run the tune up on the ragged edge also My old 518 C.I. low deck 400 block stroker pump gas motor had the heck wrung out of it, shifting above 7000 RPM at the track for hundreds of runs and some beating on it on the street with no block problems other than some main cap walking when I had the 906 heads on it ![work work](/ubbthreads/images/graemlins/custom/work.gif) I did have the old Mopar brand ductile iron main caps and ARP main studs installed in it to start with ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I now use the 440 Source aluminum main caps and ARP main studs, so far no negative results on any of my customers motors ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif) Knock on wood ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: tex013]
#2540211
08/22/18 10:21 PM
08/22/18 10:21 PM
tex013
Sydney,Australia
Yes Cab . But even if I could get a 400 block here , is major swap all my stuff is RB . I had 440 Source billet steel caps/ARP studs
Tex
[Re: Cab_Burge]
#2540224
08/22/18 11:27 PM
08/22/18 11:27 PM
Posts: 740 WA
JD Dart
WA
Now you have my 400 crack the main webs after 1250 runs made good power best pass 8.69@156 went throw the traps at 7600 it had the 440 Pro-Gram bullet steel caps Keith Black 9/16 studs 4.150 stroke steel h beam rods might of been OK with the aluminum caps.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: JD Dart]
#2540238
08/22/18 11:45 PM
08/22/18 11:45 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I can’t tell you how many 400 girdled blocks we have had break in the Pittsburgh area but we have a lot of good running Mopars in this area. It’s been a lot I’ll tell you that. About everyone I know stepped up to an Indy or Keith Black blocks years ago.
#2540268
08/23/18 12:59 AM
08/23/18 12:59 AM
tex013
Sydney,Australia
I can’t tell you how many 400 girdled blocks we have had break in the Pittsburgh area but we have a lot of good running Mopars in this area. It’s been a lot I’ll tell you that. About everyone I know stepped up to an Indy or Keith Black blocks years ago. John , I accept stepping up , don't need to tempt fate BUT a KB wedge will cost give or take A$10000.00 on my doorstep - bare . I would far prefer an iron block for daily use and my goals , low 10s @ 3700lbs through the exhaust Tex
[Re: tex013]
#2540272
08/23/18 01:35 AM
08/23/18 01:35 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Honestly if I was 3700 pounds and only wanted to run low 10’s I would put my car and myself on a diet and build a nice small block. These things can be impressive plus you start out lighter already from the small block.
#2540290
08/23/18 02:36 AM
08/23/18 02:36 AM
tex013
Sydney,Australia
Honestly if I was 3700 pounds and only wanted to run low 10’s I would put my car and myself on a diet and build a nice small block. These things can be impressive plus you start out lighter already from the small block. DIET ! I am barely 150lbs wringing wet . Not sure my 68 B Body is going much lighter , already has aluminium engine parts , aluminium radiator , light wheels , glass bonnet and front bumper . There is no rear seat / bench front . And again all I have is big block and there is no new small block blocks either . And no not gen3 . Tex
[Re: tex013]
#2540357
08/23/18 11:12 AM
08/23/18 11:12 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Sure seems to me that aftermarket caps and girdles don't do much, if anything, to keep the block from cracking. Seen just as many cracking w/ good caps and/or girdles as I have w/ stock caps.
[Re: tex013]
#2540374
08/23/18 11:46 AM
08/23/18 11:46 AM
fast68plymouth
So. Burlington, Vt.
The solution for not cracking stock blocks is really simple....... make less power.😎
[Re: fast68plymouth]
#2540375
08/23/18 11:49 AM
08/23/18 11:49 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The solution for not cracking stock blocks is really simple....... make less power.😎 Or let it sit in the shop unused. Make power and use it and both high and low deck blocks will break.
[Re: tex013]
#2540484
08/23/18 03:36 PM
08/23/18 03:36 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
After seeing this, I am really mad at myself for not getting a aftermarket block, sorry this happened to you Tex.
[Re: CSK]
#2540500
08/23/18 04:21 PM
08/23/18 04:21 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That’s why even though I had my Keith black block the more I thought about it I grabbed a mega block that was offered to me. The way I looked at it was I would sooner or later be building an engine for another car I have sitting here and it costs me about 1100.00 to prep a stock block to build. The mega block was more or less ready to go from another build so it made sence to grab it. It sits in darkness.
