Re: Distributor advance q’s. [Re: Thumperdart] #2539686
08/21/18 05:35 PM
08/21/18 05:35 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Pretty sure they do Dom. Seen them on FBO. Was thinking about getting one of Dons distributors and send it to William for curving. I will have to test fit an old unit i have first to see how well it clears head and cover.
Re: Distributor advance q’s. [Re: mopar dave] #2539691
08/21/18 05:52 PM
08/21/18 05:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'll look into that then.......... thumbs
Re: Distributor advance q’s. [Re: viperblue72] #2539735
08/21/18 07:12 PM
08/21/18 07:12 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Looks like summit has those caps too.
Re: Distributor advance q’s. [Re: Thumperdart] #2539749
08/21/18 07:51 PM
08/21/18 07:51 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Firecore sells a "convesion" cap for the factory dizzy that has HEI Male ends. See: https://www.customwiresets.com/product.php?productid=16275&cat=0&page=1&featured
I've been running this cap and a FBO mechanical advance selector plate for several years in my factory distributor. Works GREAT!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Distributor advance q’s. [Re: rumblefish72] #2539752
08/21/18 07:56 PM
08/21/18 07:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx guys............ thumbs
Re: Distributor advance q’s. [Re: viperblue72] #2539777
08/21/18 10:09 PM
08/21/18 10:09 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
Who think the most efficient spark setting for an idling engine is full advance?
Boffin Emeritus
Re: Distributor advance q’s. [Re: polyspheric] #2539825
08/21/18 11:52 PM
08/21/18 11:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It probably isn't in most cases but we've been doing it forever and I too am guilty and will be trying a curved dizzy in my junk soon......... beer
Re: Distributor advance q’s. [Re: Thumperdart] #2539950
08/22/18 11:24 AM
08/22/18 11:24 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My smoothest idle and best vac happens at about 26*. And too much lead has less negative impact on the idle than too little does.
I find it much more difficult to keep the mech advance from starting until after the idle and then having it all in as soon as possible. Usually 2,000 or so. Getting to that usually requires several distributor dis-assemblies juggling springs and weights.
Master, again and still
Re: Distributor advance q’s. [Re: viperblue72] #2539959
08/22/18 11:45 AM
08/22/18 11:45 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Dave, isn’t your cam about 20* less duration @.050 than the OP’s 274@.050?
If I’m running a combination that has advance, like you, I prefer to not have the timing change from idle in neutral to idle in gear.
I’m not as fussy about having it all in by 2000 per se, as long as it’s fully advanced a few hundred rpm lower than whatever the low end of the cruise rpm is.
Re: Distributor advance q’s. [Re: fast68plymouth] #2539980
08/22/18 12:43 PM
08/22/18 12:43 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yes mine is 270@50 and that cam is currently working real nice. Thanks for selecting that spec Dwayne. I currently have a billet MSD with the stiffest springs MSD has and only 6* advance in it. Intitial is 30* and 36* total all in about 2900/3000rpm. Seems to work pretty good but havent tried the weaker springs yet.
Re: Distributor advance q’s. [Re: viperblue72] #2539983
08/22/18 12:54 PM
08/22/18 12:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
My question was actually directed at DaveRS23.
I thought his Hemi was something like 255@.050.
Re: Distributor advance q’s. [Re: fast68plymouth] #2539993
08/22/18 01:27 PM
08/22/18 01:27 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Oops. Dont mind me, but i thought his cam was a 274@50.
Re: Distributor advance q’s. [Re: fast68plymouth] #2540209
08/22/18 10:17 PM
08/22/18 10:17 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
laugh2 Yeah, my cam is small by Moparts standards. 246*/256* FTS.
The all-in at/about 2,000RPM is not set in stone by any means. It is just a target. Maybe I should have said low 2,000s instead.
With 3.91s and the 518, I often cruise 2 lane roads around 2,500RPM. So, as you noted, all-in by then is my goal.
beer
Re: Distributor advance q’s. [Re: viperblue72] #2540843
08/24/18 12:30 PM
08/24/18 12:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like my total all in by 2000 rpm. I run a set of light springs and set my total at 36 which it seems to like best. Then I see where the initial timing falls which mine around 21 initial. My car likes that and runs fine with no pinging at all. If I wanted to change my initial then of course I have to change my total in the dist to end up at the same total of 36. Ron
Re: Distributor advance q’s. [Re: 383man] #2543078
08/29/18 03:44 PM
08/29/18 03:44 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I'd like to get more initial timing in the 340 in the Dart...I'm currently running MSD with the black 18 degree bushing...
Does anyone have experience with these bushings? One is 10 degree and the other is 14 degree...
http://4secondsflat.com/MSD%20Distributor%20Tuning.htm
...FAFO...
Re: Distributor advance q’s. [Re: skicker] #2543249
08/29/18 11:06 PM
08/29/18 11:06 PM
CA
crackedback Offline
crackedback  Offline
CA
I have those bushing $10 ea + shipping
CNC'd and the 10 is flat sided already as well to help fit in the window.
Sold quite a few to members here and and FABO, FBBO.
Shoot me a PM if interested.
