Re: Need to add two gauges, water temp and oil pressure [Re: 71birdJ68] #2540366
08/23/18 11:31 AM
08/23/18 11:31 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By 71birdJ68
I agree, they quit using direct mechanical gauges in large airplanes way back in the early thirties.
Pretty sure no one is selling aircraft quality gauges as hot rod items. Big difference in certifications there.
Don't be the exception.
Re: Need to add two gauges, water temp and oil pressure [Re: Supercuda] #2540439
08/23/18 02:09 PM
08/23/18 02:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just saying, why are we still using steam gauges when almost everything else has stopped using them and a long time ago.
Re: Need to add two gauges, water temp and oil pressure [Re: 71birdJ68] #2540458
08/23/18 03:05 PM
08/23/18 03:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Because they are adequate unto the job at hand. No need for a $300 stepper motor driven oil pressure gauge when a $15 mechanical one is more than adequate. You aren't going to fall out of the sky and kill hundreds of people if your gauges are "old fashioned" nor do you need to spend hundreds of extra dollars on your gauges.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2541509
08/26/18 11:53 AM
08/26/18 11:53 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I've already contributed to this thread but I also agree with a reply from Gavin.
This is not an engine laboratory, accuracy in a gauge is over rated. If my oil pressure shows the difference between 0, low, med and I'm still cold, take it easy. It's good enough.
Think of what is going on under the hood of a Hellcat. Would installing a nylon hose from the engines oil gallery to a mechanical gauge inside the car be necessary? NO
Re: Need to add two gauges, water temp and oil pressure [Re: Magnum] #2541598
08/26/18 03:34 PM
08/26/18 03:34 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well like has been said already it all depends on the quality of the gauges and senders. I still have an old set of Stewart Warner mechanical gauges from 1977 in my Savoy and I trust them and maybe that's why I still have them in the last 6 cars I've owned.
If I were going replace them it would be VDO gauges senders twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Need to add two gauges, water temp and oil pressure [Re: fourgearsavoy] #2541616
08/26/18 04:14 PM
08/26/18 04:14 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
My point was so many people think that if you don't have a mechanical gauge, then you might as well not have anything.
