Re: Pics of your turbo setups?
[Re: racerx]
#2538544
08/19/18 01:41 PM
08/19/18 01:41 PM
Posts: 99 Nampa, Idaho
Moparmatts72
Nampa, Idaho
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) .....nice and clean,is this on a stock block ? The motor he built orignally was a stock 360 block base 408 stroker. I went with a Ritter block for mine.
[Re: crankn101]
#2538592
08/19/18 05:11 PM
08/19/18 05:11 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Still a work in progress... going to move the engine back some yet also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: crankn101]
#2538802
08/20/18 01:14 AM
08/20/18 01:14 AM
Posts: 2,260 IL
furious70
IL
Mine's not the prettiest, but running since 2012. van/RV manifolds turned upside down.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Moparmatts72]
#2539394
08/21/18 01:29 AM
08/21/18 01:29 AM
Posts: 36 CO
crankn101
CO
Well mines a street/strip car, 100% street legal will even race with full interior. How is the exhaust ran?
[Re: dvw]
#2539414
08/21/18 02:47 AM
08/21/18 02:47 AM
Posts: 8,357 fredericksburg,va
cudaman1969
fredericksburg,va
Here's some early photo's of Dizusters 360 sb turbo car. Small 1 7/8" truck manifolds. Car has been 9.55@142, 3750lbs. Doug What size turbo? What size bov?
[Re: crankn101]
#2539499
08/21/18 11:34 AM
08/21/18 11:34 AM
Moparmatts72
Nampa, Idaho
Well mines a street/strip car, 100% street legal will even race with full interior. How is the exhaust ran? Well you can see the down pipe'show they are ran and then under he brought it down to just forward of where a header collector would be so it lines up where you would normally run an exhaust. I'll find a picture. Okay here is the exhaust routing.
[Re: dizuster]
#2539561
08/21/18 01:41 PM
08/21/18 01:41 PM
cudaman1969
fredericksburg,va
76mm compressor, 50mm bov, 60mm WG, 23psi of boost on e85. Thanks, next question,what brand of each? I'm assuming the wg is adjustable.
