Re: Smogger 440 aftermarket head choices. [Re: CSK] #2541277
08/25/18 03:47 PM
08/25/18 03:47 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
Originally Posted By csk
Originally Posted By BSB67
Sounds like your friend was already committed to a rebuild or certainly far more than the OP, with a cam and checking the crank. Once you'r that far, and you have the budget, going the rest of the way is a no brainer.
Building the ideal motor is simple, especially when it is someone else's money.
But there is such a large gap between doing heads verses doing a motor. If he does heads, it will be a marked and noticeable improvement from where he is now, he can do it in a weekend, and can easily get out of the whole deal from beginning to end between $1,500 and $2,000. Once you say the word "pistons", from the beginning to the rolling down the road complete, it will be $8,000+ and at least 6 months.
THIS ^^^^^^
x2
Re: Smogger 440 aftermarket head choices. [Re: Uberpube] #2541303
08/25/18 05:08 PM
08/25/18 05:08 PM
CA
W
wyrmrider Offline
wyrmrider  Offline
W
CA
Good move on the stroker- easy choice with a bad crank and needing pistons anyway
also agree on the head and cam only
but every time I try it the new pressures show bad rings
I'd try and do a leak down first but often the parts came in in a basket
Re: Smogger 440 aftermarket head choices. [Re: Uberpube] #2541335
08/25/18 06:54 PM
08/25/18 06:54 PM
Central NC
gch Offline
gch  Offline
Central NC
iF YOU CAN FIND SPECS ON YOUR CAM TRY DEGREEING IT FOR FUN TO SEE WHERE IT IS.oR JUST ADVANCE IT 4 DEGREES AND ROLL WITH THE HEADS.
Caps snafu.
