Re: Highway and 3.91's
[Re: furious70]
#2538749
08/19/18 10:20 PM
08/19/18 10:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Us limp wrists must sit behind desks and earn enough money to afford OD Yeah, that's the problem.
[Re: 360view]
#2538942
08/20/18 10:47 AM
08/20/18 10:47 AM
Posts: 9,008 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
In 1968 I had 4 teeth pulled by my small town dentist without pain killers. To his credit it did all four very quickly. Did you know the tooth brush was invented in West Va? Any place else it would have been called a teeth brush.
[Re: furious70]
#2539134
08/20/18 03:54 PM
08/20/18 03:54 PM
Posts: 4,592 Michigan
MarkZ
Worthy
Worthy
Us limp wrists must sit behind desks and earn enough money to afford OD If you have a small block that swap to a 518 only set me back $1,000 using the factory TC that came with it. Looking at $1500 or about if you need an Ultrabell to fit it to a big block. As long as you can make your own mount - no problem.
[Re: cudaman1969]
#2539188
08/20/18 05:25 PM
08/20/18 05:25 PM
Posts: 4,836 Moved to N.E. Tennessee
GomangoCuda
Might add in late 60s a tank of gas was $5.00. Two 4s, 5.86 gears, cruising Friday and Saturday nite would take 2 tanks. Didn't matter back then, $100 or more does today on wall mart greeters salary does. In the year 1967, the average retail price of gas in the U.S. was $0.33. This is equivalent to $2.47 in 2018 dollars. National Average Price of gas as of 8/20/18. $2.838. It's $2.69 around here. Lol , In the early 70's I absolutely refused to buy Sunoco 260 because it was an outrageous 45 cents per gallon. Typical Walmart greeter probably does not use 2 tanks of gas in a month.
[Re: cudaman1969]
#2539192
08/20/18 05:33 PM
08/20/18 05:33 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
In 1968 I had 4 teeth pulled by my small town dentist without pain killers. To his credit it did all four very quickly. Did you know the tooth brush was invented in West Va? Any place else it would have been called a teeth brush. I did not live in WVa. I had no cavities and the 4 teeth were in good shape and not wisdom teeth. My jaw was too small.
[Re: GomangoCuda]
#2539195
08/20/18 05:41 PM
08/20/18 05:41 PM
Posts: 8,162 USA
360view
USA
Might add in late 60s a tank of gas was $5.00. Two 4s, 5.86 gears, cruising Friday and Saturday nite would take 2 tanks. Didn't matter back then, $100 or more does today on wall mart greeters salary does. In the year 1967, the average retail price of gas in the U.S. was $0.33. This is equivalent to $2.47 in 2018 dollars. National Average Price of gas as of 8/20/18. $2.838. It's $2.69 around here. Lol , In the early 70's I absolutely refused to buy Sunoco 260 because it was an outrageous 45 cents per gallon. I also remember 31 to 33 cents per gallon gasoline when CocaColas from a vending machine was 10 cents. The ratio of gasoline price to vending machine Cokes has stayed pretty stable. The ratio of a Mars MilkyWay bars to gasoline has also stayed relatively constant. The above ratios have been more stable that the ratio of the price of crude oil to either a troy ounce of silver or Gold.
[Re: GomangoCuda]
#2539225
08/20/18 06:59 PM
08/20/18 06:59 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Might add in late 60s a tank of gas was $5.00. Two 4s, 5.86 gears, cruising Friday and Saturday nite would take 2 tanks. Didn't matter back then, $100 or more does today on wall mart greeters salary. In the year 1967, the average retail price of gas in the U.S. was $0.33. This is equivalent to $2.47 in 2018 dollars. National Average Price of gas as of 8/20/18. $2.838. It's $2.69 around here. Lol , In the early 70's I absolutely refused to buy Sunoco 260 because it was an outrageous 45 cents per gallon. Typical Walmart greeter probably does not use 2 tanks of gas in a month. Unless,. I still have that car! LOL I pumped 260 for $.38 @ gallon (my weekend job) pumped 190 the most, $.29
[Re: 360view]
#2539226
08/20/18 07:01 PM
08/20/18 07:01 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
In 1968 I had 4 teeth pulled by my small town dentist without pain killers. To his credit it did all four very quickly. Did you know the tooth brush was invented in West Va? Any place else it would have been called a teeth brush. I did not live in WVa. I had no cavities and the 4 teeth were in good shape and not wisdom teeth. My jaw was too small. Sorry, must have hit a nerve.
