Re: Transmission removal without a lift
[Re: savoy64]
#2537783
08/17/18 06:42 PM
08/17/18 06:42 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
the problem you will find is when the car is high enough to drop the tranny out your floor jack cant jack high enough to put the tranny back in----get out your tape measure-----you need 17 inches clearance to pull the tranny on the floor under the floorboards----it cant even be on the jack at that point----putting it back in---slide it on the floor----get under the car with the jack----lift up the tranny and put it up on the jack----jack up the jack and wish that the jack could go higher..... That's how I have always done it. Get it down, slide it off the jack and drag it out on the floor. In in the reverse order. My new shop is getting a lift cause I am getting too old for that!
[Re: gzig5]
#2537831
08/17/18 08:19 PM
08/17/18 08:19 PM
Posts: 8,329 fredericksburg,va
cudaman1969
fredericksburg,va
The problem I had with my first trans jack was to get the car high enough to get the jack and trans out from under the car then there wasn't enough lift to get the trans up high enough to bolt back up. The one I have now will lift 30 inches from floor to bottom of pan. I made 14" high boxes that the tires set on, no jack stands. Strips front and back to keep from rolling off. Still a pain at 69. Lifts a Black Hawk big truck type.
[Re: gzig5]
#2537835
08/17/18 08:26 PM
08/17/18 08:26 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I use a motorcycle jack to RR trans with car on jackstands.....Sometimes need to lift car a little higher to get trans in and out on jack. No biggie.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 70AARcuda]
#2537908
08/17/18 10:23 PM
08/17/18 10:23 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This +6ton jack stands, no problem. I have a pair of 12tons that get things a little higher, but 6tons will do.
[Re: mgoblue9798]
#2538033
08/18/18 09:50 AM
08/18/18 09:50 AM
Posts: 6,717 KY
65pacecar
KY
suggestion- make sure to get the upper bellhousing bolts out from the top before putting the car on jackstands Definitely, makes the job much easier.
[Re: gzig5]
#2538036
08/18/18 10:00 AM
08/18/18 10:00 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I did quite a few on the ground.Even before I had a good floor jack.Just get it high enough.I pulled the dip stick tube first after draining fluid.Ive done my 4 speed on the ground also.Used to set it on my chest and heft it into place.last time I didthe 4 speed had my sons stab it in.LOL One advantage to having grown sons whe you get old.Rocky
Chrysler Firepower
[Re: gzig5]
#2538086
08/18/18 12:36 PM
08/18/18 12:36 PM
Posts: 3,105 N.W. Florida
Fat_Mike
N.W. Florida
How high am I going to need to block up my 73 Cuda to remove the 727 Torqueflight for a rebuild? 18 inches should do it with just a couple inches to spare. EDIT 18 inches PLUS the height of your jack, cradle, etc (unless you can slide the jack apparatus out from under the transmission once lowered)...
[Re: savoy64]
#2538093
08/18/18 12:46 PM
08/18/18 12:46 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
the problem you will find is when the car is high enough to drop the tranny out your floor jack cant jack high enough to put the tranny back in----get out your tape measure-----you need 17 inches clearance to pull the tranny on the floor under the floorboards----it cant even be on the jack at that point----putting it back in---slide it on the floor----get under the car with the jack----lift up the tranny and put it up on the jack----jack up the jack and wish that the jack could go higher..... I've changed a bunch this way, before I had a floor jack I'd drag them up on my abdomen and lift them up in place. Too old for that now, have a lift and high lift transmission jack, much easier now. lol
[Re: gzig5]
#2538098
08/18/18 01:04 PM
08/18/18 01:04 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I like using the Harbor Freight 12 ton jackstands for the front and the regular 6 ton stands for the rear axle. 1 set of 4 of each of those jackstands and a Costco $90 3-ton floor jack have served me well for decades.
I use the regular floor jack to slide it in and out with no issues, but it has slipped off once or twice. Hands to self when that happens. I can still lift them up and put it in by hand, but only because I work out at the gym. If I don't go regularly, that ability goes away and chance of injury in general goes up.
I've been R&R'ing the trans for 40 years by myself that way. A lift would require a dedicated, tall transmission jack for lifts, and then the lift is in the way in a small shop.
Lifting the car up onto the highest setting of the 12 tone jackstands makes it nice for polishing the sides and lowers too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
