date codes #2536765
08/15/18 02:39 PM
08/15/18 02:39 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline OP
ek3  Offline OP
E
I have been told that the latest casting dates on 440 - 6 blocks were around 5-70 . were all the six pack engines built in two runs ? [70-71] [ excld-a12's ] if you wanted to put correct date coded exh. manifolds on a car built later than may , would they have a date when the engine was built or would they be closer to the build date ? I know things were all over the place ... does anyone have any photos of a 71 with the block and exh. manifold dates ??
Re: date codes [Re: ek3] #2536769
08/15/18 02:47 PM
08/15/18 02:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There are no 440 sixpack blocks, just 440 blocks.
A sixpack engine is typically marked HP2
Casting dates can be all over the place.
Re: date codes [Re: Morty426] #2536796
08/15/18 04:03 PM
08/15/18 04:03 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
HP2 designation as "typical" for 6 pack engines is a myth as far as I am aware........HP designates an HP engine assembled on first shift....HP2 indicates second shift assembly. I can think of no valid reason to only assemble 6 pack engines on 2nd shift. I assume these engines were assembled throughout the work day regardless of 4 barrel or 6 pack configuration. However, I may be proven wrong. It would not be the first time.
For the OP.....accepted date range for exhaust manifolds is several months to just a few days prior to the vehicle SPD. I don't think you will correlate it very well to block casting dates as they do not seem to align with SPD's.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: date codes [Re: 70gtx440dana] #2536807
08/15/18 04:36 PM
08/15/18 04:36 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I thought six pack blocks only got six pack rods until 1972 when they started using up the supply. So if that is the case, then wouldn't there be a way to differentiate between regular HP blocks and six pack blocks? work
JB Rhinehart, Realist
A-Body's RULE!
Re: date codes [Re: 70gtx440dana] #2536835
08/15/18 05:52 PM
08/15/18 05:52 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Correct, I have three ‘70 F440 HP blocks that all happen to be out of real V -code cars. One from a ‘70 RR Lynch Rd, one from a ‘70 cuda Hamtramck (my cars numbers block) and one from a ‘70 Super Bee Lynch Rd. All are HP and not HP2.
The “six pack”/HD rods were used in all ‘70-1 440-4 HP and 6bbl engines. The only differences were the valve relief pistons and 3-bolt cams being used in the multicarb versions. Both the 4 and 6 bbl rotating assemblies were externally balanced.
Re: date codes [Re: 70gtx440dana] #2537302
08/16/18 06:32 PM
08/16/18 06:32 PM
E
ek3 Offline OP
ek3  Offline OP
E
I get it that normal range on the manifolds are 2-3 months ...I know there are no 6 pack blocks. hp or hp 2 does not matter .. that being said , for the people who have real 6 pack cars [ or photos ], with orig. blocks , what is the latest known casting date seen on a 6 pack block ? if they are all over the place , there must be an early and a latest known date ? I am talking what is known here. and , what are the dates on those known manifolds . fwiw, I have never seen a six pack block with a casted date past 5-70 If that's the case , then you would be able to look at the latest known six pack cars and look at the cast dates . the reason why is I hear they built most of the engines in two runs .I have no facts . it is just a little more info on how things were done . any takers ??
Re: date codes [Re: 70440+6bbl] #2537495
08/17/18 04:29 AM
08/17/18 04:29 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The reason I used the 'typically" is that ALL 5 of my Sixpack engines are stamped HP2. Statically that seems off, but obviously possible.
Re: date codes [Re: ek3] #2537497
08/17/18 04:43 AM
08/17/18 04:43 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Well you can forget that 5/70 date. The original motor to my 71 Challenger R/T 440 SIXPACK with a SPD of 3/31/71 has a casting date of 7/21/70 - over 8 months prior to the cars build date. However 71 dates have a far larger gap then 70 dates IMO.
Re: date codes [Re: Morty426] #2537658
08/17/18 02:37 PM
08/17/18 02:37 PM
E
ek3 Offline OP
ek3  Offline OP
E
what are the dates on the manifolds?
Re: date codes [Re: ek3] #2537756
08/17/18 06:02 PM
08/17/18 06:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That I don't know. The car was made into a race car and restored back to stock. The car had headers on it when I got it.
