Re: Need help tuning dominator for the street
[Re: Thumperdart]
#2538943
08/20/18 11:49 AM
08/20/18 11:49 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Mine has a PV on the primary side BTW. It is far from a blubbery mess.
Guess I'm the odd man out in this conversation...different observations about a couple different carbs I've had here. Glad that works for you and apparently you got a good tune going............ Do you have a wide band to verify afr's at different engine speeds.......... Just asking to get info and understand how you verify that your 3-circuit is great on the street and has no blubbery or over rich issues cos if so, that's a good thing for sure just haven't seen it first hand.......... No wideband needed. After 12 years of street and strip use and never fouling plugs and running great, I'm perfectly happy w/ it. Sounds crisp, clean off the footbrake or the transbrake. Part throttle driving around town, no stumbles, or running rough. Which is a lot more than I can say for some other carbs I've had to mess with.
[Re: Canam800]
#2546520
09/06/18 01:42 AM
09/06/18 01:42 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Got the carb back from Dominic and back on the car. What a difference. The car runs great. Way cleaner and smoother. Going to take it out and drive it more only got to put a few miles on it. When it stops raining here I will log some more miles and report back . Very happy so far. Night and day difference very responsive. Thanks Dominic.
Thanks Brandon Was wondering how it worked out as I haven't heard from you guys and I start twitching in anticipation............Very happy that you're happy.........
[Re: Canam800]
#2546695
09/06/18 02:18 PM
09/06/18 02:18 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
[Re: Thumperdart]
#2546842
09/06/18 07:16 PM
09/06/18 07:16 PM
Posts: 287 PA
Harry's Taxi 2
PA
Thanks Brandon Was wondering how it worked out as I haven't heard from you guys and I start twitching in anticipation............Very happy that you're happy......... Thumper, could you give us the "recipe" you used for this application?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Harry's Taxi 2]
#2546855
09/06/18 07:36 PM
09/06/18 07:36 PM
Thumperdart
State of confusion
They vary but if you send yours you can see for yourself my "recipe"........ I look at the whole picture of the said vehicle and it's intended application and go from there but lets just say I tune like the baddest did in the 60's and 70's not like the monkey crap you see today........Less emulsion(2)normally and adjustable t-slot jets to keep em clean n mean till you wood the happy peddle..........
[Re: Canam800]
#2547324
09/07/18 07:18 PM
09/07/18 07:18 PM
Posts: 287 PA
Harry's Taxi 2
PA
dogdays, I understand that, but per thumpers own acknowledgment he was given quite a bit of free guidance in the past. I gotta eat too!
#2547340
09/07/18 07:50 PM
09/07/18 07:50 PM
Thumperdart
State of confusion
Nothing is free I'm here to tell ya..........Hundreds and hundreds of dollars on gas, plugs, oil, tires etc to learn this stuff and am still learning new and unexpected stuff. My numbers below if you want to call me anytime.......... And let's just say that the "free" info isn't always accurate..............
[Re: Canam800]
#2775707
05/18/20 12:59 PM
05/18/20 12:59 PM
Posts: 1 Ashburs, Virginia, USA
LayDeluca
Hello... i can say you need to try is setting the Closed Loop Compensation Limits down. In my case I pulled the distributor to find that the gear is pretty worn on the bottom leading edges of the teeth. It looks like I need to figure out a way to get my distributor depth just a little deeper. This would explain my jumpy timing. pcb manufacturing
