727 CO2 SHIFTER
#1750201
02/09/15 06:35 PM
02/09/15 06:35 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
my turbo action cheetah shifter (co2)goes from 1st to 3rd every now and then, played with air pressure and no better. turbo action says that does happen, they recommend e-controller ($450) any other shifters any better?? gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: 727 CO2 SHIFTER
[Re: 440lebaron]
#1750202
02/09/15 06:57 PM
02/09/15 06:57 PM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
My Hurst 1/4 stick with air operated shifting, would sometimes go from 1st right to 3rd. Took a while to find, but the blocker air solenoid was going bad. Replaced the blocker air solenoid, and mine worked good.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 727 CO2 SHIFTER
[Re: 440lebaron]
#1750206
02/10/15 11:21 AM
02/10/15 11:21 AM
Posts: 10,034 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I use a CO2 system with a B&M ratchet shifter, NEVER had a miss or over shift. The shifter can't get to the next gear until pressure is released and the shifter can come back a bit to reset for the next gear. It has been fool proof for eighteen years.
Re: 727 CO2 SHIFTER
[Re: moparguy7074]
#1750207
02/10/15 11:43 AM
02/10/15 11:43 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I've had my PPP shifter installed for two years w/CO2. It works great and so far I haven't had that problem. ![](/ubbthreads/images/graemlins/thumbs.gif)
I took out one of those Cheetah shifters to put in my PPP.
I called and talked to Paul at length about this shifter (SCS) and of course my "issue" was unheard of, but I know even my dad has gone 1-3 on this shifter manually as have a lot of others I've run into over the years with the SCS. Personally....If I was going air shift and was looking at the $450 "E controller" vs the $600 for the PPP.... I guess at that point I'd choke and go the PPP route..... or try modifying the rooster comb.... for free . I was on the phone ready to order a PPP, but the guy I was talking to about them about made my head explode, so I went back and figured I'd try and reinvent the wheel.
Re: 727 CO2 SHIFTER
[Re: PLUM BAD]
#1750212
02/11/15 06:56 PM
02/11/15 06:56 PM
440lebaron
westerly, ri. usa
thanks, I will check out the detents when I drop the pan for filter change, dedenbear insrtuctins only mention adding more air pressure so it does not shift thru second gary
Re: 727 CO2 SHIFTER
[Re: JD Dart]
#2532214
08/06/18 11:47 AM
08/06/18 11:47 AM
Posts: 2,567 S.E. Michigan
cl440
S.E. Michigan
You need to take out 1 of the springs that forces the handle over. The Dedenbear instruction made that very clear. If you bought a different C02 they probably didn't know. Same thing happen to a buddy of mine took it apart at the track removed the spring his has worked perfectly every time important on a 7.50 car. I am having the same problem (shifting 1st to 3rd) with the Cheetah SCS shifter, CRT RMVB and C02 shifter in the Daytona. I just read and re-read the instructions from Dedenbear and Turbo Action and I see nothing about removing a spring?
Re: 727 CO2 SHIFTER
[Re: 440lebaron]
#2532601
08/07/18 12:52 AM
08/07/18 12:52 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I had nothing but problems with my cheetah shifter, I'd pull from 1st to 3rd, yeah I know, my problem
So I bought a CO2 shifter and the plunger mushroomed over, do a search. I pulled it all out and went to a pro ratchet Problem solved.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: 727 CO2 SHIFTER
[Re: Dave Hall]
#2532612
08/07/18 01:07 AM
08/07/18 01:07 AM
Posts: 4,292 Morrow, OH
markz528
Morrow, OH
Make sure you guys are running a minimum of 110lbs. to the solenoid. I agree. Last time out I ran low on pressure (80 psi) and it shifted 1st to 3rd 2 runs in a row.
Re: 727 CO2 SHIFTER
[Re: cl440]
#2532781
08/07/18 01:42 PM
08/07/18 01:42 PM
440lebaron
westerly, ri. usa
WOW I posted this in 2015 sold car 2 years ago
Re: 727 CO2 SHIFTER
[Re: 440lebaron]
#2532823
08/07/18 03:11 PM
08/07/18 03:11 PM
cl440
S.E. Michigan
WOW I posted this in 2015 sold car 2 years ago Yeah. I did a Google search and found it. Thought it would be good to revive it and see if I could get help figuring it out.
