There is a Test/Tune at Mason Dixon on the 26th of October and then again on the 9th of November...I'm going to watch the weather and maybe plan on taking it down and let him try it out...
He's been running it everywhere...drives it 40 miles or so one way to car shows and such...
As of now there hasn't been any mechanical issues at all...
It just gets 91 pump gas put in and he logs miles...
He has been playing with jetting and tuning on it little by little...
I took it out for a little while a couple Saturday's ago and noticed its trying to spin at the initial hit...Its never done that before....
Come to find out he swapped the stock shocks off of the back and put a set of KYB Gas shocks on it...
It didn't feel like it stood as hard as it did before...
He had taken it out and hit it a few times and noticed the same thing...
After pulling the gas shocks off they were 2 1/2" shorter on full extension than the stock oil shocks...
Changed out the shocks and its back to normal...
There's not much convertor in it at 3500 but it will dead hook from an idle on the street and leaves hard...
Using the MSD Streetfighter box I currently have the rev limiter set at 6500...I may need to raise that up a little to go to the track...
He swears it still pulls hard when it hits the limiter...
