Re: Easiest and or best way to run a 9.5et 70' Roadrunner
[Re: BradH]
#2535505
08/13/18 10:13 AM
08/13/18 10:13 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
What's the budget for this effort? 12 to 15,000$ I would think
[Re: crankn101]
#2535519
08/13/18 10:57 AM
08/13/18 10:57 AM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
Your typical B body like you're describing will likely be around 3700-3800 lbs. You'll need a REAL 825+ HP at the flywheel to run the number you want. You can build a stout, but streetable, 512 and hit it w/ a 200 shot every now and then to go mid 9s. Or go big or go home w/ the 512 and put some decent compression in it, E 85, and bigger heads than the Trick Flows, nasty roller and try to go mid 9s on motor. Either way, the stock block will be a time bomb. Or do like I did and get a strong aftermarket block and build a big, but streetable, 572" motor that'll run mid 9s all day at 3800 lbs on pump gas.
[Re: crankn101]
#2535526
08/13/18 11:09 AM
08/13/18 11:09 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Assuming it's a stock car, but with appropriate chassis and wheel/tire upgrades to handle the extra power, I would think you will need at least 850hp to get you mid 9s. Late 90's I ran mid 10s in a stock steel body and full interior 68 charger. Had a Indy headed 451 that made about 730hp. No cage, 8 3/4 w 4.30 spool, 5200 converter, 8" steel wheels w ET streets.
2 kids and a dog
[Re: crankn101]
#2535794
08/13/18 07:25 PM
08/13/18 07:25 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looked at a few numbers today.
The correction factor from sea level to 5000’ is about 1.05 for ET, so a 9.50 is close to a 10.0 @5000’. The Moroso chart shows 825hp for a 9.50@3800lbs, and “most” cars need about 10% more power than indicated to get it done. I’d be shooting for 900hp if that’s really the target ET. Less weight = less power req’d.
Basically, that ET is about 4.6lbs/hp if the car is sorted out.
[Re: fast68plymouth]
#2535803
08/13/18 07:39 PM
08/13/18 07:39 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
Here is a picture of my 70 GTX which is same body as 70 RR. It has a Chenoweth built 493 stroker with Indy SR heads. You will need more with all the street goodies on the RR. MJ
[Re: Clanton]
#2535851
08/13/18 09:14 PM
08/13/18 09:14 PM
Posts: 36 CO
crankn101
CO
What's the budget for this effort? 12 to 15,000$ I would think I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with. From the sounds of it, I might build this to a 10.5 street car and pick up a lighter car for racing.
[Re: moparjohn]
#2535852
08/13/18 09:15 PM
08/13/18 09:15 PM
Posts: 36 CO
crankn101
CO
Here is a picture of my 70 GTX which is same body as 70 RR. It has a Chenoweth built 493 stroker with Indy SR heads. You will need more with all the street goodies on the RR. MJ NA?
[Re: crankn101]
#2535862
08/13/18 09:31 PM
08/13/18 09:31 PM
moparjohn
N.W. INDIANA
Here is a picture of my 70 GTX which is same body as 70 RR. It has a Chenoweth built 493 stroker with Indy SR heads. You will need more with all the street goodies on the RR. MJ NA? Yes, 1050 carb with Indy intake. MJ
[Re: crankn101]
#2535915
08/13/18 11:24 PM
08/13/18 11:24 PM
Posts: 9,889 MI, usa
dvw
MI, usa
[quote=BradH]What's the budget for this effort? 12 to 15,000$ I would think I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with. From the sounds of it, I might build this to a 10.5 street car and pick up a lighter car for racing. [/quote} 10-12K isn't even close with new parts for a 900 hp 572. Mine was built from a combo of used and new. If all the parts were new it would be close to 20K. It'll run 9.20@145 at 4500 D/A, 9.0@150 at 1200 D/A. A dominator and single 4 might be a little quicker. 3340 race ready. The Turbo Late Hemi or SB stuff should get it done cheaper. Doug
[Re: crankn101]
#2535928
08/13/18 11:58 PM
08/13/18 11:58 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Doug, I drool every time I see that pic.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: crankn101]
#2535933
08/14/18 12:05 AM
08/14/18 12:05 AM
Posts: 5,168 CT
GTX MATT
CT
The easiest, best, AND cheapest way would be with one or more turbos. Especially if you want to actually be able to drive it on the street too.
[Re: theraif]
#2535970
08/14/18 01:10 AM
08/14/18 01:10 AM
Posts: 4,711 Wichita
GY3
Wichita
Haha, yeah, not Mopar under the hood...
[Re: dvw]
#2535974
08/14/18 01:20 AM
08/14/18 01:20 AM
Posts: 36 CO
crankn101
CO
[quote=BradH]What's the budget for this effort? 12 to 15,000$ I would think I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with. From the sounds of it, I might build this to a 10.5 street car and pick up a lighter car for racing. [/quote} 10-12K isn't even close with new parts for a 900 hp 572. Mine was built from a combo of used and new. If all the parts were new it would be close to 20K. It'll run 9.20@145 at 4500 D/A, 9.0@150 at 1200 D/A. A dominator and single 4 might be a little quicker. 3340 race ready. The Turbo Late Hemi or SB stuff should get it done cheaper. Doug For the record, building a 572 or an after market block was never in any of my plans.
[Re: crankn101]
#2535978
08/14/18 01:29 AM
08/14/18 01:29 AM
Posts: 36 CO
crankn101
CO
This was linked to me from some where, but I cant find who posted it. Anyways, what about a setup close to this with a 512" motor and EFI? https://www.hotrod.com/articles/mopp-0604-440-mopar-engine-build/ And I also read these original blocks can hold more power if the engine is "boosted", is that true?
[Re: GTX MATT]
#2535981
08/14/18 01:31 AM
08/14/18 01:31 AM
Posts: 36 CO
crankn101
CO
The easiest, best, AND cheapest way would be with one or more turbos. Especially if you want to actually be able to drive it on the street too. What does someone charge to fab something like that up? I dont have the welding and fab skills for anything close to that.
[Re: crankn101]
#2536027
08/14/18 07:29 AM
08/14/18 07:29 AM
dvw
MI, usa
[quote=Clanton][quote=BradH]What's the budget for this effort? 12 to 15,000$ I would think I dont really have a budget, I was hoping for 10-12K for the engine or so plus whatever power adder I go with. For the record, building a 572 or an after market block was never in any of my plans. I'd run a Late Hemi with a turbo. Stock block and forged crank will hold 1000 HP w/o issue. Stock heads are very good. aftermarket piston/rod for boost. Use a knock off Drag Pac intake. 20 psi should get it easy. Doug
