Page 2 of 3 1 2 3
Re: when to replace torsion bars [Re: mopar dave] #2534848
08/11/18 11:49 PM
08/11/18 11:49 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I ran my original slant 6 bars with iron head bb in my dart. I re did the front end again and just put a heavier slant six bar in, but now have aluminum head bb.
Re: when to replace torsion bars [Re: mopar dave] #2534916
08/12/18 02:25 AM
08/12/18 02:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would say it of course depends on if its a race or street car. Myself I still run the original bars in my 63. Its an original 383 car and to me they work fine on the street and work fine at the track. I don't think I would want to run the 6 cyl bars on a car that's basically a street car most of the time. Ron
Re: when to replace torsion bars [Re: mopar dave] #2534924
08/12/18 03:06 AM
08/12/18 03:06 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By mopar dave
Why the 68/69 383 bar?
383 is only what, 20 lbs less than a high block.
Re: when to replace torsion bars [Re: cudaman1969] #2535010
08/12/18 11:32 AM
08/12/18 11:32 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
My BB added 80# to the car over the SB it replaced. Mostly street car, but i want suspension to work best possible at the track. So the 68/69 383 tb is the best option for this?
Re: when to replace torsion bars [Re: mopar dave] #2535046
08/12/18 01:08 PM
08/12/18 01:08 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If you can find a set that's nice,? 340 should be ok, depends on how many miles where on them. My bars for the 69 440 are #895-894 (off build sheet) Can't remember the diameter right now. The SB bars are a dime a dozen, should be easy to find. If street-strip they would be best all around in my book. Aftermarket ones that size would be ok, nothing heavier, it would ride like a tank.
Re: when to replace torsion bars [Re: mopar dave] #2535064
08/12/18 01:58 PM
08/12/18 01:58 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
A torsion bar is a spring. Just as with coils, different spring rates (diameters) can be used to adjust how the suspension and how the car reacts in your particular situation. And springs wear out too. More so for a light spring required to store more energy.
Re: when to replace torsion bars [Re: cudaman1969] #2535304
08/12/18 09:19 PM
08/12/18 09:19 PM
Mt Morris Michigan
Mt Morris Michigan
I think the 340 bar would be an .870". I readjusted bars both sides again 1 more turn each. Will see if this holds for now.
Re: when to replace torsion bars [Re: mopar dave] #2535444
08/13/18 02:46 AM
08/13/18 02:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Also on my sons 72 Dart it was a 318 AC car. We removed the AC and now have a 400 in it but the 400 has aluminum heads and intake and headers. I felt with the AC gone and the aluminum parts on the 400 it may be no heavier then when it had the 318 with AC. So it still has the 318 AC bars in it which have been in it with a bigblock (400) since 1997 with no problems. And it is a street car. Ron
Re: when to replace torsion bars [Re: 383man] #2535722
08/13/18 05:03 PM
08/13/18 05:03 PM
Mt Morris Michigan
Mt Morris Michigan
Just sooke with matt at firm feel. He suggests .880 bars for best of both worlds. $325/pr, but out of stock right now. Who else should i call for opinions?
Re: when to replace torsion bars [Re: mopar dave] #2535728
08/13/18 05:13 PM
08/13/18 05:13 PM
Washington
madscientist Offline
Washington
Well that sucks. How long before they get some in?
I think PST has torsion bars. I can't vouch for the quality though. Maybe someone else can.
Re: when to replace torsion bars [Re: madscientist] #2535733
08/13/18 05:16 PM
08/13/18 05:16 PM
Mt Morris Michigan
Mt Morris Michigan
He did say they might have them tomorrow. Hes gonna call me when they are available. He also said he sells alot of 1" bars for street cars that are not stiff at all. They also have a .820 but said it wouldnt last long.
Re: when to replace torsion bars [Re: mopar dave] #2535744
08/13/18 05:41 PM
08/13/18 05:41 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Re: when to replace torsion bars [Re: krautrock] #2535749
08/13/18 05:46 PM
08/13/18 05:46 PM
Mt Morris Michigan
Mt Morris Michigan
That bar from mancini might be fine, but i nolonger call mancini for advise on anything.
Re: when to replace torsion bars [Re: mopar dave] #2535764
08/13/18 06:29 PM
08/13/18 06:29 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
you can use that part number to search availability elsewhere. i found some .960 bars for my coronet using that method. only paid about ~$250 shipped if i recall correctly.
got them here, if you're in a hurry though, i'd just order from Jeg's...
https://www.moparonlineperformance.com/product-p/p5249150.htm
Re: when to replace torsion bars [Re: krautrock] #2535771
08/13/18 06:43 PM
08/13/18 06:43 PM
Mt Morris Michigan
Mt Morris Michigan
Always looking for a deal. Thanks
Re: when to replace torsion bars [Re: mopar dave] #2535819
08/13/18 08:04 PM
08/13/18 08:04 PM
Mt Morris Michigan
Mt Morris Michigan
Just received a call back from matt@firm feel. They had to order the material for the .880 bars. Wont be available for another month.
Re: when to replace torsion bars [Re: mopar dave] #2535826
08/13/18 08:22 PM
08/13/18 08:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
$300 for bars! Glad I have about 10 sets.
Re: when to replace torsion bars [Re: cudaman1969] #2535837
08/13/18 08:48 PM
08/13/18 08:48 PM
Mt Morris Michigan
Mt Morris Michigan
Yep. I want brand new. Not used up bars that need to be changed again in another 2 or 3yrs. Magnumforce has .870 bars for $325 as well. Need to give them and hotchkiss a call yet. They are pricey new.
Re: when to replace torsion bars [Re: mopar dave] #2535895
08/13/18 10:45 PM
08/13/18 10:45 PM
Washington
Washington
I forgot about Magnumforce.
Re: when to replace torsion bars [Re: madscientist] #2536293
08/14/18 05:51 PM
08/14/18 05:51 PM
Mt Morris Michigan
Mt Morris Michigan
Made some more calls today. Magnumforce recommended a 1.030 and a 1.080 bar. Hotchkis have a 1.1 bar. Not where i want to go. So i called calvert racing because i use caltrac bars and they recommend 340sb bars as a member here also recommended.
Page 2 of 3 1 2 3
