Sorting out suspension...could use some advice (as always!)
#2532674
08/07/18 09:33 AM
08/07/18 09:33 AM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
I've talked about my suspension mods a lot but so far, I'm not really happy with how it drives yet. I realize that I have more parts to buy, more tuning and more work ahead but this is where my car is right now and I would love some advice on where to go next. '73 Dart Sport, original 318 car (Magnum 5.9 swap) 8 3/4" rear with 4.10 Eaton TrueTrac Built A904 (until I can afford the T56 conversion) Non-power brakes Stock front disks Ford Explorer rear disks Manual 16:1 steering with Tuff Wheel replica Aluminum wheels 15x8 +0mm rear and 15x7 +10mm front 255/60/15 rear Radial T/As (ugh) 225/60/15 front Radial T/As (ugh). Stock front sway bar, no rear sway bar QA1 Upper and Lower control arms Sway-A-Way 1.14" torsion bars Hotchkis lowering leaf springs Fox 1.5 shocks (Hotchkis) Mancini Camber spacers Don't get me wrong, I LOVE driving it...but in general it feels like it needs a lot of work before it drives anything like I had hoped. A few specific points of concern: 1)Brand new (re-man) steering box but there's still a ton of play (20*-30*?) in the steering and it really spoils the driving experience. 2) Alignment...I'm still trying to figure out what else I need to replace to fix the awful steering action and I'm trying to decide on a ride height so I'm hesitant to pay for a professional alignment just yet but I've made a lot of adjustments to camber and toe just playing around with it and it tracks nice and straight though I'm sure it's far from optimized for handling. 3)Something's not right in the rear end. The springs seem way too stiff. I know the Hotchkis springs are much heavier than stock but it feels really rigid when I push down on the bumper and a couple of times it has really gotten jittery over bumps in a way that spooked me. 4)Something else weird with the rear- the car is straight, never hit, everything looks to be lined up correctly yet the driver's side sits slightly higher in the rear than the passenger side. Could this be related to the shackles binding? I just don't know what else could cause this... 5) Something's just weird with the feel on turn-in. It's really hard for me to explain it but it's like the chassis settles in the wrong direction when loading up on a curve. I'm far from giving up...I just know that a properly set-up Mopar can be a great handling and satisfying car to drive...I'm mostly flailing around in the dark though AutoXCuda and 72BlunBlu (over on the Abodies forum) have helped a ton already through their threads as well as direct answers. Any thoughts, advice, appropriately phrased insults, etc. are welcome. I don’t have much footage of the car in action but when watching this quick clip, Something looks odd...Is there something weird about how the front end moves here? I know...not much to go on but it almost looks like there's no suspension travel at all? https://youtu.be/76aQKC2U7zc
Re: Sorting out suspension...could use some advice (as always!)
[Re: MRGTX]
#2532696
08/07/18 10:30 AM
08/07/18 10:30 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There are two philosophies in regards to spring rate.
Stiff with no or little sway bars. Makes for jittery rides on less than smooth pavement.
Softer springs with big swaybars. my preferred setup.
Adjust the freeplay in your steering box, procedure is in the FSM.
Odds are most of your handling issues are due to lack of alignment. What are your current specs?
[Re: BigBlockMopar]
#2533064
08/07/18 11:05 PM
08/07/18 11:05 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
The steering is never going to feel like a modern rack steering system, you can maximize it, but it is a systematic thing. So you need to check EVERYTHING one after the other and optimize it. Only check with a load on the tires- on the ground or an alignment rack. The steering column bearings, the coupler, correctly adjust the box, make sure the box is properly tightened, watch the box for k-member flex, it's very common. Make sure the steering arms are tight, wheel bearings properly adjusted and then suspension- i.e. ball joints and bushings are tight.___ The torsion bars and rear springs look like a good match. You need to get a good professional alignment, have the car checked on a frame rack and have the rear checked for squareness. The factory tolerances are really pathetic on the frame and needing shims to square up the rear end is common- you'll note that several companies make them for old Mopars. ![work work](/ubbthreads/images/graemlins/custom/work.gif) ___ After all this, you can play with the shock adjustments.___ If you are O.K. with the body roll after all this, you are golden, if not I'd go with Firm Feel or Helwig bars. This is just my personal preference, Hotchkis and PST both make good product as well.___ The tires will then be the limit and those old T/As just won't get it done. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Skeptic]
#2533190
08/08/18 10:44 AM
08/08/18 10:44 AM
MRGTX
Connecticut, USA
I gather you haven't touched the caster-settings yet? That's where the most of the proper handling/tracking/stability will come from. Simply eye-balling the alignment is simply impossible and certainly no option to achieve any proper handling.
Steeringplay, I would assume that a "remanufactured" box would have the play taken care off. If the rest of the steering linkage is good and tight, my guess is the box just received some new gaskets and grease inside. Are you really sure the box is mounted tight on the K-member? (Have someone steer left/right while you observe possible box movements.) How tight is the steering coupler?
Most often the idler-arm bushing is the cause for lousy or vague steering response. Next to that are loose steering boxes, worn/trashed LCA bushings, worn ball joints or loose wheel bearings.
A good alignment shop shouldn't even start the alignment-job until these parts are replaced and play-free.
As for nr. 4 and 5; (4) Torsion bars are pre-loaded unevenly.
(5) Caster setting way off, or bushings trashed? Great info here! Thank you. The idler arm bushings that you mentioned may be a critical point...this is one of the few components that hasn't been replaced yet. That will be my next step! Thanks. Looks like they're ~$100 from Mancini. Would anyone recommend a different source? That's a really interesting question about the steering coupler...can they be loose? IIRC, they're splined, no? I used an extension coupler from Mancini when swapping to the manual box. This is worth a look. I will also re-torque the bolts holding in the box. Why do the front wheels have +10mm offset? Is that to the inside or outside? The +10mm moves the wheels in-board a bit as it moves the mounting pad 10mm closer to the outside rim of the wheel. A-Bodies are known to have a narrower track in the rear and I wanted to reduce that a bit, even if it's only 20mm over all. My wheels are a complicated question as the front wheels started out as 15x8+10 but they didn't clear the upper control arm so I had a shop narrow them (because they didn't make these wheels in 15x7 and I love to throw good money after bad ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) ). The steering is never going to feel like a modern rack steering system, you can maximize it, but it is a systematic thing. So you need to check EVERYTHING one after the other and optimize it. Only check with a load on the tires- on the ground or an alignment rack. The steering column bearings, the coupler, correctly adjust the box, make sure the box is properly tightened, watch the box for k-member flex, it's very common. Make sure the steering arms are tight, wheel bearings properly adjusted and then suspension- i.e. ball joints and bushings are tight.___ The torsion bars and rear springs look like a good match. You need to get a good professional alignment, have the car checked on a frame rack and have the rear checked for squareness. The factory tolerances are really pathetic on the frame and needing shims to square up the rear end is common- you'll note that several companies make them for old Mopars. ![work work](/ubbthreads/images/graemlins/custom/work.gif) ___ After all this, you can play with the shock adjustments.___ If you are O.K. with the body roll after all this, you are golden, if not I'd go with Firm Feel or Helwig bars. This is just my personal preference, Hotchkis and PST both make good product as well.___ The tires will then be the limit and those old T/As just won't get it done. Point taken on the comparison to modern steering. I think my expectations are realistic and I know there will always be a relative lack of precision and road feel. I just would like a whole lot less play. You've provided a good roadmap on how to go through the system. Thanks. I'll look into the shims for the springs. The car sat even (to my eye) on the original springs...but maybe the stiffer springs are exacerbating a tolerance issue? Tires- Yeah, I've long noticed how poor the T/As are by modern standards but as we have talked about in this forum, there aren't really any superior options in the 15"/60 series range. What would you recommend.
[Re: MRGTX]
#2533264
08/08/18 01:26 PM
08/08/18 01:26 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
1)Brand new (re-man) steering box but there's still a ton of play (20*-30*?) in the steering and it really spoils the driving experience. Most reman boxes are not remanufactured so much as simply dis-assembled, inspected, excessively worn parts replaced, new gaskets installed, and put back together. Short of a new boxes, all reman boxes will be like this. Adjust freeplay as suggested earlier and see if that tightens things up a bit. The Borgeson unit may be the best example of a recirculating ball box out there. They are newer, have tighter tolerances, and an improved feel. 2) Alignment...I'm still trying to figure out what else I need to replace to fix the awful steering action and I'm trying to decide on a ride height so I'm hesitant to pay for a professional alignment just yet but I've made a lot of adjustments to camber and toe just playing around with it and it tracks nice and straight though I'm sure it's far from optimized for handling.
Are you using a gauge at all or just a string/tape measure? Garage alignments are only as good as the effort you put into them and you can do the basic as well as thrust measurements, but will lack some precision. You are right that you need height decided before you dial in alignment. You didn't mention it but I'd suggest setting max caster first (rear eccentric bolt all the way in/front all the way out), then adjust for camber, finally toe. You can map out the position of everything on your garage floor with a plumb bob and measure it to see how everything lays out squarely, but it takes some effort. While never being an an accident is good news, the factory specs from this era were pretty loose and its possible for any position to be up to an eighth out of ideal. Stack them all up and things can be off quite a bit. Same with a rear thrust measurement. Possible, but takes an effort to be as accurate as possible. 3)Something's not right in the rear end. The springs seem way too stiff. I know the Hotchkis springs are much heavier than stock but it feels really rigid when I push down on the bumper and a couple of times it has really gotten jittery over bumps in a way that spooked me.
Pushing down on the back won't tell you much. You've got maybe a couple hundred pounds of force. The car will be exerting a couple thousand pounds of force. If it feels jittery over bumps, try softening the shock setting. You could also put it up in the air and move it through its motion to make sure it isn't binding since that was mentioned below. 4)Something else weird with the rear- the car is straight, never hit, everything looks to be lined up correctly yet the driver's side sits slightly higher in the rear than the passenger side. Could this be related to the shackles binding? I just don't know what else could cause this...
T-bar adjustment height will impact rear height. If you are adjusting both front bars to be exact, it can throw off height in the rear. Adjust the passenger front up slightly to correct. 5) Something's just weird with the feel on turn-in. It's really hard for me to explain it but it's like the chassis settles in the wrong direction when loading up on a curve.
Could be weight jacking (or lack of) from the caster setting. Is this a low, medium, highspeed, left, right, both directions, does it take more or less effort one way or the other. Lots of things to dig into with this. I'm far from giving up...I just know that a properly set-up Mopar can be a great handling and satisfying car to drive...I'm mostly flailing around in the dark though AutoXCuda and 72BlunBlu (over on the Abodies forum) have helped a ton already through their threads as well as direct answers. Any thoughts, advice, appropriately phrased insults, etc. are welcome. I don’t have much footage of the car in action but when watching this quick clip, Something looks odd...Is there something weird about how the front end moves here? I know...not much to go on but it almost looks like there's no suspension travel at all? https://youtu.be/76aQKC2U7zc Can't see your hand in relation to the car's direction. It looks like a semi-abrupt turn. Maybe turning the wheel some before the tires catch up. Might have someone turn the steering wheel while you watch the steering box and linkage. As suggested by others, box mounting flex in the K frame as well as tolerance stack up from other components could all be factors in the turn in feel. Overall combo seems like a good starting point. May be light on front sway bar. If you can find a large, empty parking lot, you can try some skid pad exercises to find out your suspension balance. walk out a 100' diameter circle, drive the circle 5 times left, 5 times right at increasing speed until you feel the front or rear of the car slide and you balance will become obvious. The car feels the combined difference between front and rear rates in both the springs and sway bars. Because of the front engine layout, you want more rate up front to handle the weight. The skid pad circle exercise will tell you which end needs more or less rate. Yes, steering couplers wear. There are a couple of shoes inside them as well as the housing its self. There are rebuild kits out there for them. Also, if you have an adapter, that is another joint added to the system which can contribute to tolerance stack up. Yea, TAs are not the best choice. If you want to stick with 15s try the MT SR. Its one of the newest 15" carcass designs out there, easily available, reasonably priced, with a relatively soft compound. Might also try stepping up front sizes as the narrower front tire will tend to understeer.
[Re: BigBlockMopar]
#2533419
08/08/18 06:47 PM
08/08/18 06:47 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Idler arm bushings priced at $100 should be roller bearinged. FirmFeel has these too.
A competent person with a lathe could turn 2 halves out of nylon/delrin and have a similar sturdy design made up.
I converted the stock disbrakes on my own '73 Dart to beefy C-body 11.75" rotors. Added 'bonus' was the front track width got narrowed by some 3/8 I recall in the process. Not sure if the same will happen with b-body 11.75 rotors. Would like to know myself as well too.
Is firm feel the only source for idler arm roller bearings?
[Re: MRGTX]
#2533428
08/08/18 07:05 PM
08/08/18 07:05 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Perhaps, not sure. I've seen roller kits on Ebay for older Mopars on occassion, not sure about the '60/'70s stuff. Just found a rollerbearing conversion kit on some Australian site, but at $130 I'm sure some thinkering in the garage could come up with a cheaper alternative. I've converted the idler arm bushing on my '57 Chrysler to 2 nylon halves some years back; ![](https://www.bigblockmopar.nl/wp-content/uploads/2017/07/IMG_0462.jpg)
[Re: BigBlockMopar]
#2533956
08/09/18 09:53 PM
08/09/18 09:53 PM
Skeptic
The Pale Blue Dot
[quote]I'll look into the shims for the springs. The car sat even (to my eye) on the original springs...but maybe the stiffer springs are exacerbating a tolerance issue? When my Barracuda had the 185/70-14s it the rearend looked fine, when I put the 255/50-17s the problem was obviousTires- Yeah, I've long noticed how poor the T/As are by modern standards but as we have talked about in this forum, there aren't really any superior options in the 15"/60 series range. What would you recommend. _ 255/50-17s... they are the same dia as your rear tires ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) though they are getting harder to find too...or something like this scroll down to the end of the post for pics. If you need/want to stick with 15s, there are the Cooper Cobras or the Mickey Thompson Sportsman S/R Tires or ET Street S/S Tires.
[Re: Skeptic]
#2534116
08/10/18 11:51 AM
08/10/18 11:51 AM
TC@HP2
Pikes Peak Country
The Idler Arm roller kit that Firm Feel sells ONLY work with the MOOG idlers, I bought 2 different brands, one I disassembled only to find it wouldn't work. The other was listed somewhat deceptively on E-bay ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) -it was NOT a MOOG as listed. I checked that one more carefully and no it wouldn't work either. Even "good" idlers don't hold up very long, I only averaged 6 months of daily driving. I don't have a handle on the longevity or the rollerized one. IIRC, Moog used to make and market these bearing kits on the open market a number of years ago. For some reason, I vaguely recall seeing them for sale on some different web sites. Perhaps Firm Feel bought them all up or negotiated a deal with the manufacturer to take all their old stock. These bearing conversions for idler arms are also out there for a number of classics. Obviously Mustang and Camaro versions abound, but they all seem to be in the $80-100 range, even for the belly button cars. If you really want to put bearings in an idler, I'm sure some minor machine work on an arm and browsing a bearing catalog could net the results desired.
[Re: ThermoQuad]
#2537568
08/17/18 11:35 AM
08/17/18 11:35 AM
MRGTX
Connecticut, USA
Awesome info, Dilbert! Thank you. First, your Charger looks mean as hell. I realize that B-Bodies have more room for tires (especially up front) but do you mind sharing your tire/wheel specs? you do not have a track car at the moment, it is a straight line machine
410s are not track gears...unless you have overdrive or a 7500 rpm redline
As much as I would love to build a track car, my goal is to build a fun to drive car with responsive/rewarding handling. I've set a few limitations for myself- stock style suspension sticking with the torsion bars), reversibility (no tubbing the rear, etc) and not altered enough where it entirely loses the character of being a Dart. Yeah. The 4.10s are quickly seeming like a poor match for the A904's ratios. I'm planning on a T56 swap as soon as the wife will let me but I'll have to live with it for now. Manual 16:1 steering with Tuff Wheel replica - you need a good steering box and the k frame boxed in as MAJOR flex takes place where the box mounts.
It is a misstatement that these cars will not have rack feel steering - I built a 70 Charger R/T that has amazing steering feel. Track car. Eats SRT Challengers driven by talented drivers. No slop in this ride. See pic, taken at "toe of the boot" at the glen Weld weld weld
That's encouraging info about the potential for steering feel. Was the K-member reinforcement the biggest piece of this? Which steering box/ratio are you running? Aluminum wheels 15x8 +0mm rear and 15x7 +10mm front 255/60/15 rear Radial T/As (ugh) 225/60/15 front Radial T/As (ugh). NO NO NO
Tire and wheel sizes should be the same. Ride height is wrong, back of car is sky high, Poor tire choice, not sure about the wheels, need to see pics
Yeah. I've always run square setups wherever possible...and it looks like A-bodies can handle ~255s up front with 17"+ wheels and the right offset. With 15" wheels, we're limited to 7" width and with anything much more than a 225, you're asking for a lot of sidewall flex. Skinny 225s on the rear of these cars is just seems silly with all of the space I have back there. The 15" Minilite clone wheels were just a style that I always liked, they were quite a bit lighter than the 15x7 rally wheels...and I still have trouble finding 17"+ that I like. The tires flat out suck for performance. If someone said they were snow tires, I'd believe it. Stock front sway bar, no rear sway bar You need a 1 inch front bar & 3/4 rear This is all a waste of time till you fix this
Interesting. How did you know that your Charger needed these sway bars? Maybe it's the low-traction tires and heavy springs on my Dart but this car doesn't really have a body roll issue. Without that problem, I'm hesitant to reduce traction even more with the bars. QA1 Upper and Lower control arms QA1 lower arms have not been road course tested best i know or tested on a press against a stock arm - i am not sure if i would trust them at 130 mph under duress.
I'll look into that. This is a valid concern. For whatever it's worth, I don't have the gear to go 130mph Sway-A-Way 1.14" torsion bars Hotchkis lowering leaf springs Fox 1.5 shocks (Hotchkis) Mancini Camber spacers All good here Your alignment is in left field Specs have been posted many times now [/quote] You mentioned that the back of the car is "sky high" but that's what those Hotchkis springs gave me...and it honestly doesn't leave much room for suspension travel as the Mancini snubber doesn't even fit at the lowest setting so I'm not sure that lowering blocks make much sense. So should I raise the front? Again, thanks for all of the input! This is exactly the kind of info that I need.
[Re: ThermoQuad]
#2537569
08/17/18 11:41 AM
08/17/18 11:41 AM
MRGTX
Connecticut, USA
...I built a 70 Charger R/T that has amazing steering feel. Track car. Eats SRT Challengers driven by talented drivers. No slop in this ride. See pic, taken at "toe of the boot" at the glen Weld weld weld ... Just taking another look, I don't see a rollbar in there. Other than boxing the k-frame, What chassis reinforcements did you do?
[Re: MRGTX]
#2538016
08/18/18 08:07 AM
08/18/18 08:07 AM
BigBlockMopar
The Netherlands
You NEVER raise a car to match it with something else irrelevant on the car! Take off the Mancini snubber and sell it to some racer with limited driving skills, like a dragracer... ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) On my '73 Dart I run 7 blades per side (because of 2 LPG tanks in trunk) and a 1" lowering block to bring it down to my liking. Adjustable Hotchkis shocks up front and adj. QA1 shocks on the rear axle, with stock snubber. I don't recall how much play there is but I never feel the snubber hit the body. Probably due to the stiffer rear springs that axle windup is limited. 225/50/17" Michelin tires all around.
[Re: BigBlockMopar]
#2538928
08/20/18 11:26 AM
08/20/18 11:26 AM
MRGTX
Connecticut, USA
You NEVER raise a car to match it with something else irrelevant on the car! ... Well, I haven't settled on a front ride height. I have the car sitting where the tops of the tires are just inside the fender lip...no rubbing and it looks pretty good to my eye. That said, this isn't necessarily ideal for handling, especially if the rear can't be dropped to match without having the axle housing resting against the body of the car. 225/50/17" Michelin tires all around.
225s? I don't doubt that this can produce some satisfactory grip and I get that this is what we have to do to have a square setup... but even my daily driver Subaru runs 235s. Anything smaller just doesn't look like a performance set up. Michelin makes a broad range of tires from econo models to slicks. Which model are you running? What are the offset/backspace dimensions for your 17" wheels? IIRC, with a 17x8, 5.5" backspace (or better yet, 17x9, 6" backspace)you can run 255s all around.
