If you didn't put sealer in the groove the seal goes into that's probably where your leak is. On the ends of the seals you should use an adhesive sealer, not silicone. You'll never get a rope seal to slide into place with the crank shaft still bolted up tight. You need sealer on the side seals also, just a light coating in the channel and the mating surface.
