'71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? #2533396
08/08/18 05:59 PM
08/08/18 05:59 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
I have / had "?" a Chrysler "Engineering Drawing" that had the specifications
for the Correct placement of the 1971 "DODGE" emblem on the Deck / Trunk Lid
and after 3 days searching scope I simply cannot find it ..... whiney
Does anyone on our GREAT Forum have a copy of this ??? shruggy
A BIG THANK YOU ! bow If you can help Kevin on this one ! wave
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: kidmopar] #2533403
08/08/18 06:12 PM
08/08/18 06:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'll send you the bill for services rendered... smile
Mike
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: DAYCLONA] #2533405
08/08/18 06:14 PM
08/08/18 06:14 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
HOLY COW ! THAT was FAST ! ! ! up thumbs
THANK YOU Mr. Dayclona ! bow
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: kidmopar] #2533412
08/08/18 06:28 PM
08/08/18 06:28 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That reminds me I need to go put mine on
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: Morty426] #2533468
08/08/18 08:19 PM
08/08/18 08:19 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
iagree up
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: kidmopar] #2540397
08/23/18 12:33 PM
08/23/18 12:33 PM
uk
TiMopar Offline
TiMopar  Offline
uk
Are these available repro now?
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: TiMopar] #2540421
08/23/18 01:35 PM
08/23/18 01:35 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Have never seen a repo.
I sold the OP "replacement" emblem that is very close
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: Morty426] #2540554
08/23/18 06:35 PM
08/23/18 06:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
C. was the "replacement" emblem the 3 prong type? if so those are available repro from the likes of YO, Classic, etc...
the original is a glue/stick on...
Mike
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: DAYCLONA] #2540621
08/23/18 09:53 PM
08/23/18 09:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Mike
Mike,
We are talking about the stick on "Dodge" emblem that goes on the deck lid on a 71 Challenger. The emblem I believe was originally used on a 69 Dart. It has been superseded twice and the one that some people try to pass off is for a 1980 Aspen SE.
Sounds like you are talking about the 70 only Challenger side script which has three prongs. I have quite a few originals but I will have to check that out.
What about the two pin R/T emblem for the side 0 used on stripe delete and bumblebee stripe cars?
Chris
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: Morty426] #2540648
08/23/18 11:10 PM
08/23/18 11:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Mike,
Chris
Chris,
I'm referring to this 3 pin DODGE emblem for the challenger 71 grille, if I recall it's the same size/font as the trunk emblem including the black out segment on the "E", just suggesting this could be substituted, either use the pins to attach or remove the pins and surgically cut a lettered 2 way tape for it
Mike
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: kidmopar] #2540668
08/23/18 11:50 PM
08/23/18 11:50 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Mike,
I will have to look at it when I get home but I am doubtful. It looks, from the picture, that the E has a black area in it that I guess supports one of the pins. The rear emblem does not have this.
Chris
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: Morty426] #2540698
08/24/18 12:58 AM
08/24/18 12:58 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike,
Chris
This was hashed out about 6 yrs ago...time flies!, Dan/6bblgt put this collage together...
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: kidmopar] #2540735
08/24/18 04:20 AM
08/24/18 04:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes - the correct emblem has the end of the G and E straight up and down
fmmpr - would run ads with 3811220 part number but they would picture a 2965502 - the old bait and switch
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: Morty426] #2541316
08/25/18 05:33 PM
08/25/18 05:33 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
You did ? shruggy
Why ? Do I not remember this ? ? ? frowwn
I actually just purchased an "NOS" emblem from gentleman in Arizona ........
I also have an NOS 3 - Prong that goes in Front Grille thumbs
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: kidmopar] #2541469
08/26/18 05:59 AM
08/26/18 05:59 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You did ? shruggy
I thought it was you back when you had the green N96 car. Maybe I am confusing you with someone else. All you Mopar guys look the same grin
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: Morty426] #2542305
08/28/18 02:13 AM
08/28/18 02:13 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
So I have my original DODGE trunk emblem for my 71 Challenger although the tape no longer sticks but is still there. Would it be better to use an X-acto knife and apply new double stick tape after removing the old tape or use some emblem adhesive to the old tape and glue it to the trunk lid?
Terry
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ? [Re: 71vert340] #2542318
08/28/18 03:31 AM
08/28/18 03:31 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Terry
Get some 3M double sided emblem tape and leave the original tape on it
