Page 3 of 3 1 2 3
Re: another plug read [Re: mopar dave] #2532058
08/05/18 09:32 PM
08/05/18 09:32 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks for posting.
Re: another plug read [Re: mopar dave] #2532079
08/05/18 10:43 PM
08/05/18 10:43 PM
Washington
madscientist Offline
Washington
Originally Posted By mopar dave
Havent had much time with the car this week, but did take a cruise out in the country, about 25 miles mostly cruising at 3000rpm with alot of stop and go and a few wot blasts. Still on the 110/93 mix and using champion RC9YC plugs. When they start coloring up i will lean the T slots at that time and see if they clean up at all. Engine ran fantastic with very good street manners whole short trip. Only pulled 3 because they all burn the same except #7 which is on the far left.
Hot damn. They are looking pretty damn good. Now you have to do some WOT and cut the shells off so we can see that.
NICE!
Re: another plug read [Re: mopar dave] #2532136
08/06/18 01:55 AM
08/06/18 01:55 AM
Those look really good to me from here up
I wish it had been all light part throttle cruising with no WOT blast though shruggy
The pencil looking colored line on the ground strap that I can see looks good also up
Now put in one new one in #7 and go get after it for a 1/4 mile right away and pull it out before driving it anymore and post the picture of that one scope up
Re: another plug read [Re: Cab_Burge] #2532175
08/06/18 10:14 AM
08/06/18 10:14 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
they do look very clean. Im not seeing the color change on the ground strap though as these may be to hot. I will see as i run them. Wont be able to get to a track til end of sept, that would be a good plug test if i could. When i do go i have a set of champion race plugs with the cut back ground strap(c63cx) i would like to try.
Re: another plug read [Re: mopar dave] #2532716
08/07/18 11:16 AM
08/07/18 11:16 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The cut back strap is for piston clearance no?Do you like the Champion brand plug over NGK?
Re: another plug read [Re: Clanton] #2532759
08/07/18 12:37 PM
08/07/18 12:37 PM
Mt Morris Michigan
Mt Morris Michigan
Just trying the rc9yc as i used to see a few racers on here recommend that plug. Thought i would give it a try. Back in the 70's as a kid i always used champion plugs in my dirt bike. They lasted longer without fouling than the ngk would. Didnt chryslers used to come from the factory with champions in them? Ngk got there crap together and now make a good plug and their cheap.
Re: another plug read [Re: Clanton] #2532761
08/07/18 12:39 PM
08/07/18 12:39 PM
Mt Morris Michigan
Mt Morris Michigan
Some have said the cut back strap makes a few more hp on the dyno. I cant confirm. Indy cylinder head recommends them as well.
Re: another plug read [Re: mopar dave] #2532796
08/07/18 02:09 PM
08/07/18 02:09 PM
A friend of mine who ran NHRA stock would cut back his plug ground strap to expose the spark to the motor work
I didn't, I had some colder Champion race plugs that where that way also work He set several NHRA stock class records, I didn't work grin
Re: another plug read [Re: mopar dave] #2532841
08/07/18 03:56 PM
08/07/18 03:56 PM
Washington
Washington
This made me LOL real hard!!!!!!^^^^^^^^^^^^^^^^
My folks bought my first dirt bike for me in August 1972 (damn near caused a divorce because my mom didn't want me and my brother riding dirt bikes...we already playing tackle football and did all the crazy things we did back then...but I held my ground and won out) and that's when I started learning how to read plugs. It's been a life long learning experience.
I've read plugs on everything except injected nitro and blown nitro. When we were old enough to ride with our friends and the old man was too old to ride, I started asking anyone riding with us what bike they had. That way I could buy a Champion plug for the bike. I'd tape it to the handle bar. Sometimes I'd have 3 or 4 pugs taped on the bars.
You just KNEW one or two of those guys would foul a plug 25-30 miles from the truck. They'd be pissed, and say that was a brand new plug for this ride. Id swap in a Champion and we'd finish the ride.
Back at the truck, I'd make then pull my plug and give it back.
That happened more times than I can count. I've been using Champion plugs since 1972. I no longer ride, but my brother still does. And when he rides with people he doesn't know...he brings Champion plugs for them.
I can read NGK plugs, but I'm not a fan. If you are paying me to do your tune up, we start with a fresh set of Champions and tune from there.
Re: another plug read [Re: madscientist] #2532865
08/07/18 04:42 PM
08/07/18 04:42 PM
Mt Morris Michigan
Mt Morris Michigan
Hahaha, yep good old memories. Golden spectro and klotz technoplate, man that stuff smelt good. The champions burned right thru all that oil.
Re: another plug read [Re: mopar dave] #2532968
08/07/18 07:56 PM
08/07/18 07:56 PM
Mt Morris Michigan
Mt Morris Michigan
1 of Doms ngk8 with 5 months+ some miles and a few tested carbs.
Re: another plug read [Re: mopar dave] #2532978
08/07/18 08:14 PM
08/07/18 08:14 PM
Washington
Washington
Dom has his [censored] wired tight. That's a nice tune up.
Re: another plug read [Re: madscientist] #2533039
08/07/18 10:18 PM
08/07/18 10:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not bad for a "non street-able" Dommy street car with 276-281 @ .050 .680-.660 Isky solid roller at 470 cubes............Duration is your FRIEND, don't be afraid of it and hang on............ drive thumbs
Re: another plug read [Re: mopar dave] #2533041
08/07/18 10:23 PM
08/07/18 10:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx for posting this and the post about the 505 ci street car and his concern with drive-ability and mileage needs to see this..........The street IS the equalizer, not theories or 200 dyno sessions but actually driving these things and seeing the results instead of PREDICTING what you think may or should happen............. work drive
Re: another plug read [Re: Thumperdart] #2533230
08/08/18 12:12 PM
08/08/18 12:12 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Sure....... now put in a 3500 converter, OD trans and A/C along with probably 500lbs additional weight........is the 276 cam still the best choice?
Re: another plug read [Re: fast68plymouth] #2533251
08/08/18 12:58 PM
08/08/18 12:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And I get that but have customers running a bit less than me but the 500+ cubes and even 3.55's and tighter vert's are no problem for them trust me. for the op about the 505 stroker deal, I think he might as well buy a modern heap since he wants EFI and economy BUT may hit the track a few times a year......To each his own but you guys are turning a potential beast into a tamer than it needs to be deal and just seems like a waste in some ways by building big and tuning small.......... work
Page 3 of 3 1 2 3
