Re: J head mods ?
[Re: Porter67]
#2532002
08/05/18 07:34 PM
08/05/18 07:34 PM
RapidRobert
I think Steve Dulcich has some good porting on them. I would Google it. EDIT Google "dulcich porting articles"
Re: J head mods ?
[Re: Porter67]
#2533003
08/07/18 09:12 PM
08/07/18 09:12 PM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
A bit of a shameless plug here, take a look at this older post of mine... If you want to see more of the pics of the finished stuff let me know. I am no pro at this, but these were opened up pretty well while still retaining a smaller port volume.
Re: J head mods ?
[Re: Porter67]
#2533032
08/07/18 09:58 PM
08/07/18 09:58 PM
Porter67
Thanks, I have seen that before. Porting is not new to me, but trying to squeeze a teener is.
I dont think the level of work for a teener would be the same as a good 360 or long arm build.
Ive managed to keep this a pretty simple build and that goes for the heads, just 13k mile castings, oem guides, I found a good single spring that works, ect...
Ive some new 318 castings but vs putting alot of work in them I figured id use the J heads with a little work.
I live at 4100 ft and with a intake closing point of 68-70 depending where I put it even with the 6cc dome and .028 gaskets im just about middle ground on things looking good on paper, I even took the block back in today to get .015 knocked off it which will get it to true zero, sucks a extra $100 just for 2cc.
I could of went with a bit more modern grind with alot lower intake closing point but ya know how hard headed some of us are.
Re: J head mods ?
[Re: Porter67]
#2533045
08/07/18 10:32 PM
08/07/18 10:32 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I would just open up the pocket to the valve job, and match the ports. Try to open up the pushrod pinch but don't go crazy there, it doesn't make a huge difference. Do not touch the port floors or the short side radius.
Re: J head mods ?
[Re: Porter67]
#2533049
08/07/18 10:42 PM
08/07/18 10:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I wouldn;t even mess with J heads anymore
Re: J head mods ?
[Re: Porter67]
#2533181
08/08/18 10:14 AM
08/08/18 10:14 AM
Supercuda
About to go away
About to go away
up yours
Fair enough, sounds more like it's a "I wanna see what I can do" project which is neat
Re: J head mods ?
[Re: Porter67]
#2533223
08/08/18 11:51 AM
08/08/18 11:51 AM
fast68plymouth
So. Burlington, Vt.
I realize you already have the castings prepped, so those are what you’ll use...... but I would have preferred to use the 1.88 intake valve for that combo.
Actually, I would have probably used 1.94 sbc valves....... along with minimal bowl work and a tweak of the short turn. I’d have shot for flow in the 220-225 range.
Re: J head mods ?
[Re: cudaman1969]
#2533376
08/08/18 05:32 PM
08/08/18 05:32 PM
Supercuda
About to go away
About to go away
up yours
YWhat's more impressive a 318 with iron heads that have 500 hours each of hand porting running 11.50s or aluminum heads out of the box running 11.00.
Fixed that for you. J heads are so wonderful they quit making them ~45 years ago. If you are going to mess with iron heads Magnums are a better choice.
Re: J head mods ?
[Re: Supercuda]
#2533388
08/08/18 05:49 PM
08/08/18 05:49 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Fixed that for you. J heads are so wonderful they quit making them ~45 years ago. If you are going to mess with iron heads Magnums are a better choice. Nope, didn't fix it, tell that to the 340 stocker guys. If you want to run fast, spend $20,000 on an engine. If you just want to have fun and run good, spend $0000. Js are perfect for his combo, aluminum is a waste of $2000. Now if he wants to ring it 9-10,000 rpm with no bottom end, go for it.
