Re: ANTI LOCK BRAKES
[Re: GoodysGotaCuda]
#2532568
08/06/18 11:26 PM
08/06/18 11:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
That's fancy looking. I pickup undriven speed from the rotor vanes, works well.
Genius
[Re: Skeptic]
#2532699
08/07/18 10:42 AM
08/07/18 10:42 AM
Posts: 656 Florida
CJD AUTOMOTIVE
That's killer, talk bout thinking out of the box. I've never seen that before, or thought of it myself. Well Done! @ CJD did you build your own harness or did Bosch supply a "A vehicle specific wiring harness is included in the Kit." I bought the Club Sport kit. It comes with a long harness to fit about anything.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
#2532944
08/07/18 07:11 PM
08/07/18 07:11 PM
Posts: 23,295 Here
jcc
Here
Elegance of K.I.S.S. Are those hall effect sensors? Thought hall sensors like square edge teeth, and thats hard to do on a rotor, but if it works so be it. Do they handle the potential heat load in that proximity? Its a straight or curved vane rotor?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: CJD AUTOMOTIVE]
#2533069
08/07/18 11:14 PM
08/07/18 11:14 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
That's killer, talk bout thinking out of the box. I've never seen that before, or thought of it myself. Well Done! @ CJD did you build your own harness or did Bosch supply a "A vehicle specific wiring harness is included in the Kit." I bought the Club Sport kit. It comes with a long harness to fit about anything. Nice, that car looks like a max effort machine. Fabbing that kind of harness would be a PITA, doable though. After wrenching for 34+ years now I'm getting to a point where doing everything just isn't how I want to spend my time. I'd still double check every crimp and connector just to be on the safe side. There's too much 3rd world "craftsmanship" out there.
[Re: jcc]
#2533170
08/08/18 09:17 AM
08/08/18 09:17 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Elegance of K.I.S.S. Are those hall effect sensors? Thought hall sensors like square edge teeth, and thats hard to do on a rotor, but if it works so be it. Do they handle the potential heat load in that proximity? Its a straight or curved vane rotor? Yes, it's a hall effect sensor. The vanes themselves are straight with rounded edges. Not having sharp edges doesn't seem to be a problem, having that many teeth makes for a pretty high resolution signal. You can see the first and second gear wheelspin [vss1 = rear] From there I have some tweaking to do to the tire diameter input for them to read exactly the same at speed. They average 1/2mph apart right now.
Re: LBS braking system?
[Re: A/MP]
#2571848
10/30/18 10:35 PM
10/30/18 10:35 PM
Supercuda
About to go away
About to go away
up yours
I talked to the guy that developed it some years ago, when I was building Warhammer. My understanding of this items was that it was a type of surge suppressor. I never ended up running one so I can;t help there. Seems the items is at http://www.larsenracingproducts.com/brakes-calipers-supporting-and-replacement-parts/
