Re: Comp xe295hl in a 505
[Re: TonyS451]
#2530003
08/01/18 02:22 PM
08/01/18 02:22 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Tony, I have dynoed numerous engines with hyd cams where the upward trajectory of the hp curve was still fairly steep....... only to have it fall off a cliff when the lifters gave up. It usually works out that way when the heads and induction are pretty good and will support more rpm than what I typically can get out if a hyd cam/lifter package. Sometimes it’s high enough where the owner doesn’t really care...... sometimes it’s not, and then decisions and choices have to be made.
For myself, I really prefer any type of what I would call a “high performance” build to have the valvetrain be suitable for about 62-6500rpm capability, even if the power peaks are lower than that.
Some customers or builds just aren’t a good match for solid lifters....... then the expectations need to be adjusted.
The last hyd cammed BB I dynoed was a 505 with a pretty mild hyd cam(.483 lift), using lobes I have successfully run to about 6300 in oval track SB’s. This 505 had rpm heads and 1.5 Mancini rockers. The cam was pretty short duration and coupled with a small intake manifold(original Torker), peaked at a low rpm(5100), which was a few hundred before the airflow numbers started backing up(this is usually the first tell tale of valvetrain instability). I was making pulls to 5700, and never heard any unhappiness from the motor, but the airflow numbers indicated some loss of control above 5400, and the motor lost 30hp from 5500 to 5700. Based on past experiences, In the car, I’m sure it would still feel like it was perfectly happy to about 5900-6000.
[Re: fast68plymouth]
#2530031
08/01/18 03:44 PM
08/01/18 03:44 PM
Posts: 889 Oh
parksr5
Oh
Unfortunately, the seat of the pants feel is the same as “valve float”, so it’s not always clear as to what the problem is. The old heads had a spring that could maintain control, and the lifters were cooperating.
I did an experiment on a BBC years ago that wouldn’t go over about 55-5600 with a hyd cam. I swapped out the springs for something with about 20lbs more on the seat and like 40-50 open. It gained maybe 100rpm, but when it nosed over with the stiffer springs it did so more abruptly than with the lighter springs. Ultimately I swapped the cam for a small solid, and used springs which were in between the previous two........ the motor pulled effortlessly to 6500(never saw any float), and as a result picked up about 30hp.
As for the situation with the head swap in the post above, I would be comparing the open/closed spring loads between the two sets of heads as a starting point. Is the rest of the valvetrain the same as before? Same rockers and pushrods? Same lifter preload? Same brand and viscosity of oil?
Those can all be factors when running hyd lifters.
The takeaway here should be, the likelyhood of achieving good high rpm results when using hyd lifters is directly linked to the bleed rate of the lifters....... not just being sure the springs/rockers/pushrods are matched to the cam profile. With a solid lifter cam, that very unpredictable variable is removed. The rest of the valve train is the same as before. Smith Brothers pushrods, Isky ductile rocker arms gone through and bushed by rocker arms unlimited and Brad Penn 20w-50. I've actually messed with the pre-load a little to see if it made any difference and it did not. I'll most likely be calling you within the next year or so to have you spec a cam for me. I think I'm just going to go with a solid; the Mopar 528 sounds like it will fit the bill pretty good. This is a FAST type build so; it's weird (HP manifolds, crappy 301 intake and etc.)
[Re: TonyS451]
#2530085
08/01/18 05:08 PM
08/01/18 05:08 PM
fast68plymouth
So. Burlington, Vt.
I think whatever Tony does, it should include a before & after chassis dyno session.
#2530093
08/01/18 05:25 PM
08/01/18 05:25 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I think whatever Tony does, it should include a before & after chassis dyno session. Would be pretty cool actually... although I don't think I'll be showing up with five cams like Andy!
2 kids and a dog
[Re: TonyS451]
#2530105
08/01/18 05:45 PM
08/01/18 05:45 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I've been running an XE295HL cam in my 440 (w/ OOTB Indy SRs and 1.5 Harland Sharp rockers) for about eight years now with no issues. The valve train/lifters are pretty noisy. Of course, the engine rarely sees anything over 5500 rpm, so take it with a grain of salt.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: TonyS451]
#2530259
08/01/18 11:18 PM
08/01/18 11:18 PM
fast68plymouth
So. Burlington, Vt.
The XE/HL lobes are the .904 fast rate hyd lobes. The 275, 285, 295 are all catalog cams.
There have been numerous posts throughout the various forums where owners have discussed/complained about the noisy operation. Again, this comes right back to the bleed rate of the lifter. For a “normal” lifter with regular hyd internals, the slower the bleed rate, the quieter it will be in operation.
Tony, I wasn’t really suggesting parts swapping on the chassis dyno....... more like a test it as it is now for a baseline, then again after the upgrades.
[Re: TonyS451]
#2530306
08/02/18 01:26 AM
08/02/18 01:26 AM
1968RR
I vaguely remember something about the lifters that I installed with the XE295HL cam being somehow different than what is regularly sold with them. I remember Comp selling some "special" type of hydraulic lifters that may have pumped up quickly and essentially acted like solid lifters afterwards. Anyway, my point is that I didn't use what Comp typically suggests for the XE295HL cam and used lifters that (IIRC) a guy at Comp that I talked to suggested instead. Obviously, my memory on the subject isn't too good. Maybe someone with more experience like fast68plymouth knows the type of lifters that I'm referring to.
#2530375
08/02/18 09:52 AM
08/02/18 09:52 AM
TonyS451
Chicago, IL
I know Dwayne, I was just joking .
2 kids and a dog
[Re: TonyS451]
#2530378
08/02/18 09:56 AM
08/02/18 09:56 AM
TonyS451
Chicago, IL
My current xe284 (non-hl) cam seems pretty quiet. Maybe because of the less aggressive grind?
2 kids and a dog
[Re: TonyS451]
#2530407
08/02/18 11:15 AM
08/02/18 11:15 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I have the Comp XE295HL in my red 70' Charger with close to 30,000 miles on it now. It is a little noisy but doesn't bother me at all. My car has power disc brakes & I did have to add a vacuum can that I hid under the battery tray. It used to get a little dicey if I got caught in bumper to bumper traffic. Much better now with the can.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: TonyS451]
#2530417
08/02/18 11:38 AM
08/02/18 11:38 AM
fast68plymouth
So. Burlington, Vt.
The XE/HL lobes make very good power for hyd cams. The upper rpm power is “usually” limited by the lifters. I think it’s the exception rather than the norm that a motor combo using one of those cams, along with good heads and exhaust, will peak at the rpm determined by the “combination” rather than the lifters ability to maintain proper control of the valvetrain. However, I’ll admit I’m basing that off a pretty small sampling of examples when compared to how many are in service.
In the MM article they tried the beehive springs, and on that motor were worth a zero rpm gain. Interestingly(?), I had been down the fast rate hyd cam road well before that article came out and had already come to the conclusion the issue was the lifters. A Moparts member was exchanging pm’s with dulcich while that build was going on, prior to the article coming out, and he had been passing along some of the info to me. When I heard what the cam/rocker plan was, I said it wouldn’t work....... and it didn’t........ at least not well enough for them to reach their goal. The final test they did provided the “proof” that the lifters were the thing limiting the upper rpm capability........ but it also showed something else, that they never touched on, but if you look at the power curves it’s pretty evident.
If you do a search for something like “noisy comp cams xe cams” you find no shortage of complaints. I had forgotten about my very first experience with one until reading a few of them. We rebuilt a 305 sbc for a guys boat, and he wanted just a little more grunt to help get water skiers up. We put in either an xe250 or 256(can’t remember which), and it worked well enough in that regard, but from about 4000rpm up the valvetrain was horrendously loud. We went and checked everything over, found no issues...... it was just that noisy. The noise was unacceptable to the owner, so we ended up installing a stock replacement marine cam in it...... which was way waaaay quieter.
[Re: TonyS451]
#2530482
08/02/18 02:06 PM
08/02/18 02:06 PM
Posts: 2,094 central texas
krautrock
central texas
here is a link to the article. also if you right click and open the image in a new tab you can see the graph nice and large. http://www.moparts.org/Tech/Archive/bb/Lobe.htmlthe baseline is the mopar 528 cam? that cam looks like it works great in that motor, but the racer brown looks super punchy on the low end, maybe the short duration plus the tighter LSA?
