Re: How much does rear gear ratio effect HWY gas mileage?
[Re: dogdays]
#2504830
06/05/18 02:27 PM
06/05/18 02:27 PM
Posts: 8,383 fredericksburg,va
cudaman1969
fredericksburg,va
It depends entirely on the engine load and the engine's efficiency map. So there's no real answer, but in general as rpm increases, internal friction goes up and economy goes down. So, IN GENERAL, lowering the numerical gear ratio should increase mileage.
But here's a true story of my '64Dog. It's a 318 Poly stocker D100 and it came with 3.91 gears. Rear tires were 32-11.50 15, 636 revolutions per mile. I used to drive long distances and it would get a maximum of 15mpg. Much of that time was spent on Interstates at 80. Calculating that out that's 3320rpm at 80.
Then, I swapped rears as I had a donor truck and the '64 axle was leaking onto the brakes. The donor truck had a 318 and 727, 3.23 gears. New rpm,2740 at 80.It's like overdrive, right? To my dismay the next trip fuel mileage was same as before, 15mpg.
Changing the gear ratio that much really made for a better road truck but around town it lacked the snap it had with the 3.91s.
R. This is what I've come to realize by staying with the 4.10s. The rpm would go down at speed with the 3.54s, but the gain would be minimal and a trade off at that. Don't know what the rpm is at 70 but it doesn't seem to be taxing the engine (tires are 245/75r16 30" tall) And the van will scoot.
[Re: dogdays]
#2504832
06/05/18 02:33 PM
06/05/18 02:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
R. This. My 64 300 came with 3.23's stock. It's get a solid 12 mpg regardless. Swapped in 4.10's and started getting 15. The 413 was warmed up a bit and I suspect the mild gears put it out of it's sweet spot whereas the steeper gears was more to it's liking.
[Re: HotRodDave]
#2504838
06/05/18 02:44 PM
06/05/18 02:44 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
This is over-simplified, but at a steady speed on the highway, just do a little math problem.
For example, if you got 10mpg with 4.10's and you swapped out to 3.23's, the you'd get about (4.10/3.23) x 10mpg = 12.7mpg traveling at the same speed. This should be really darn close. I have actually found this to be close to a point, you can not keep adding higher ratio and just always keep getting better MPG as your engine will only make enough power to keep you moving at a certain RPM and if its always downshifting to get up the slightest incline you just reach a point of diminishing returns but if you have very deep gears already than this formula is kinda close. I have contemplated throwin a 2.20 rear diff in my daokta with a .69 OD ratio in the trans and really put it to the test but have not had the time or ambition. This is true Dave. Another factor is that if your cam/engine makes peak torque (best mileage) right in the "sweet spot" of your highway rpm & you drop the gear ratio, then you may not be in that "sweet spot" anymore....but the math is still good for a ballpark idea of mileage, rmp at highway speed, etc.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: 360view]
#2504884
06/05/18 04:23 PM
06/05/18 04:23 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I like to think more of displacement per mile than RPM per mile. For example you could have a 512 stroker turning 2000 revolutions per mile (a gear/tire combo that gave you 2000 RPM @ 60 MPH for example) and displace the same air and have the same basic internal friction as a 383 turning 2674 revolution per mile (or RPM @ 60MPH). The two should get very similar MPG and put similar TQ to the tires with identicle top ends, cams...
Also the whole thing about keeping the vacuume as high as possible is sort of bologna, yes you want to keep it as high as possible within a given combo but keeping that number down through gearing is not really by it self a bad thing. You will always get higher vacuume in 1st gear than 2nd 3rd 4th... but you will absolutly not get your best MPG driving everywere in 1st gear. The reason you were getting better MPG watching that gauge is because you were not doing as much work accelerating and then slowing down if you keep the gauge steady with a particular load if you were trying to keep the vacuume up. Also it is a good indicator of your engines tune state. I always got my best MPG with my 318 magnum 5 speed dakota by running a much higher gear selection than most would ever consider running and then accelerating with WOT at a low RPM. I could get near 20 MPG in town all the time driving this way, you will not get anywhere in a hurry but it saves a butt load of gas. If I ran it up to 2500-3000 to shift and accelerated at part throttle is would get maybe 12MPG in town.
[Re: ragtop]
#2504951
06/05/18 07:34 PM
06/05/18 07:34 PM
Supercuda
About to go away
About to go away
up yours
Somethings not right if you are only getting 10-11 mpg in a 318 Dart. You should be getting a lot better than that.
[Re: ragtop]
#2505087
06/06/18 07:05 AM
06/06/18 07:05 AM
Posts: 2,474 Answering the call of the wild
ThermoQuad
Gas mileage is affected by many factors - the largest factor is rolling resistance. I have owned wicked cars that got good gas milage One is particular: E Body 416 six pak with 4sp OD and 355's 16 mpg going to and from Carlisle, back in forth to Watkins Glen etc. Top speed 140+ ET 12.20 to 12.80 with 11.90 trap speeds 400+hp at the rear wheels
Place car on level pavement in neutral Can you push it backwards without effort?? Probably not. This is the test, if you can't do this there will be no gas mileage.
Synthetic fluid in the diff, run level 1/4 inch down. Rear wheel bearings greased with synthetic grease, end play 0.005-0.007 Front wheel bearings in synthetic grease, bearing preload about 50 inch pounds. Proper wheel alignment Manual Trans? Passon gear lube Auto Trans? Mopar ATF4 or better yet Amzoil synthetic
Engine oil, 10-40 or 10-30 synthetic, 5-30 if your engine will tolerate it
Proper engine tune up and distributor curve - here is the other major mileage factor. Lots of timing advance under part throttle needed.
K&N air filter
60% distilled water, 40% antifreeze, bottle of coolant enhancer.
195 degree thermostat
External Trans cooler if AT with internal radiator connection bypassed
[Re: ThermoQuad]
#2505098
06/06/18 08:56 AM
06/06/18 08:56 AM
Supercuda
About to go away
About to go away
up yours
K&N air filter
External Trans cooler if AT with internal radiator connection bypassed That's a lot of turd polishing there. A stock, no polished turds, 318 Dart should have no problem approaching 20 mpg highway. Oh DO NOT PRELOAD THE BEARINGS use the fsm method.
[Re: Supercuda]
#2505243
06/06/18 02:45 PM
06/06/18 02:45 PM
Posts: 19,705 north of coder
moparx
one time, a million years ago in the mid 70's, i had a 74 dodge 4x4 pickup with a 318/727/3.91 gear 35" tires that got right around 5mpg pulling a super bed load of junk to the scrapper. it was tuned to the max, but to be fair, i had added a "super" bed made entirely of 1/8" plate steel, with 2" oak floor, and a 3" roll bar using 1/4" tube gas pipe. [and that was a real "treat" to bend !] it had 6"&8" C channel cross members, as well as a piece of 6" well casing between the rear frame horns. up front, there was a fabbed 2" push bar on top of some 4" well casing for a front bumper. to say this thing was heavy would be an understatement ! i built a 440 8.5cr with a torque/rv cam, TQ carb/factory hi stall converter, and swapped it for the 318. mileage went instantly to almost 14 ! the 318 was foot to the floor all the time, while the 440 was just loafing. i wished i never sold that truck. it could sure haul the loads, plus push/pull almost anything out of the road ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: ragtop]
#2505283
06/06/18 04:04 PM
06/06/18 04:04 PM
Posts: 4,467 Morristown Tn.
71birdJ68
Morristown Tn.
In town mileage is hurt, cause we are trying to get 4000 ids up to speed, on the highway, it rolling resistance, AND wind resistance. Usually, less filling of each cylinder per mile is the answer, if everything is set up right. If our engines were turbo charged, then lowering the RPM, and increasing the manifold pressure would do the trick. Read what Charles Lindberg did during WWII to help the P-38 guys save fuel. Two cents.
[Re: BigBlockMopar]
#2507096
06/11/18 03:25 PM
06/11/18 03:25 PM
HotRodDave
Kalispell Mt.
I tried to test the rotating-resistance of two 727 transmissions and a A500/42RH I got laying around by grabbing the inputshaft with 2 fingers and rotate it clockwise;
Both the 727's rotated fairly easy but the A500 took way more effort and required a firm grip to rotate.
Something is not right with the a-500 or the 727s, too tight of clutch clearance or end play or... when a 727 and a500 are properly assembled the a500 shaft is always easier to turn. At the other end of the trans is a different story as you will have an extra set of clutches and more weight on the a500 output shaft but the extra drag there is more than offset by the lower RPM in %99 of cases (for example a 4cyl might not have enough spare power at a low RPM to overcome the extra friction/weight).
[Re: ragtop]
#2507823
06/13/18 08:49 AM
06/13/18 08:49 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
There is an interesting USA Patent for an improved method of estimating the aerodynamic coefficient of drag of a real vehicle out on roads.
Near the end of their description of their aero method, they also describe a neat way to better estimate transmission and differential friction and “stored rotational energy” in driveshafts and wheels.
They jack up and put the vehicle on jackstands, start the engine, engage the 1:1 gear and bring the drivetrain up to a speed. They measure the rpms of the wheels, then take the vehicle out of gear and let the drivetrain coast down to a lower rpm ( but not zero). After gathering this data, they remove the wheels, and re-run the coastdown again without the wheels.
With the two sets of data, they could calculate both drivetrain friction and stored rotational energy if they just knew how much rotational energy the wheel and tires have.
They devised a neat way of measuring this.
Think of Chrysler torsion rod suspension.
These inventors made a “torsional pendulem” by fixing a small diameter steel shaft to a ceiling and welding on a plate to the other lower end of the steel shaft with studs to match the bolt pattern of the wheels.
They attach a wheel/tire to the plate, then twist the tire on the hanging pendulem, and let it go.
The wheel/tire will twist back and forth in a cycle whose twists per minute depends only on the rotational inertia of the wheel/tire/mounting plate, plus the “spring rate” of the steel shaft. It is a easy to build “ I of a wheel” measuring instrument, where I is the symbol scientists use for “Rotation Inertia” of a rotating mass.
Old fashioned mechanical wrist watches have a similar torsional pendulem inside them.
[Re: ragtop]
#2507826
06/13/18 09:03 AM
06/13/18 09:03 AM
Posts: 8,162 USA
360view
USA
