Re: Tubular K-frames ?
[Re: Rhinodart]
#2529639
07/31/18 06:04 PM
07/31/18 06:04 PM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
Here is an older AlterKtion on a 67 Barracuda that I currently have. The coil overs go where the round bar is between the lower control arm and the vertical member, the entire load on the coil overs is on the vertical member while the k-frame itself is bolted to the regular mounting spots on the frame rails. I don't see any issues with this design. Three things stand out on this frame that bothers me, one is the distance between the lower control are attachments, wider the better for stability of back and foward movements. Second the rack, for proper steering geometry the pivot on the arms has to be inline or same distance as the centerline of the lca pivot (hard to tell with boot on). Third I don't like the one sided (not double sheer) of the lca pivot bolt either, like I said I've seen the 3/4 bolt that broke on the lca while backing up and turning real slow.. Can't remember the guy but he's a well know writer in the mags that totally downed these k frames, in fact I read his stuff on here years back. Erenburg or something like that.
[Re: bigdad]
#2529649
07/31/18 06:15 PM
07/31/18 06:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A coilover is when you combine a spring with a strut, making it a type of strut.
Ah no. Try again. A coil over SHOCK, which is exactly what the OP is talking about, is when you combine a spring with a SHOCK, which does NOT replace the upper control arm but works in conjunction with one. See my comment about you not knowing the difference between a coil over and a McPherson strut. BTW, if you think a McPherson strut setup is better than our torsion bar setup would would be correct in exactly one aspect, cost. In all others it fails.
[Re: Devil]
#2529742
07/31/18 09:45 PM
07/31/18 09:45 PM
Posts: 2,826 NY usa
540challenger
NY usa
Don't forget all tubular K-members are illegal for road use. So as long as he doesn't want to drive it on the street, he's all good. 99% of the aftermarket parts on Our cars have a similar statement. It's the industry standard.
[Re: Stanton]
#2529801
08/01/18 01:21 AM
08/01/18 01:21 AM
Posts: 3,102 N.W. Florida
Fat_Mike
N.W. Florida
"Disclaimer Reilly MotorSports, Inc. cannot control how this product is installed or used. By purchasing this product, the buyer/end user assumes all risks associated with its use and agrees to having the proper skills for it's installation. Reilly MotorSports Inc. and its suppliers will not be held responsible, liable or accountable for any injury, damage, loss, penalties, or fines that occur from using this product in any manner." And any lawyer that just passed the bar could fight this and win. There isn't a disclaimer on the planet that can't be fought and won if negligence by the manufacturer can be proven. And I guess you're a lawyer... Regardless, what it DOESN'T say is "THIS PRODUCT IS FOR OFF ROAD USE ONLY" which is what member "Devil" said was disclaimed on "ALL" tubular K frames, which is total BS. This product is ADVERTISED to be used for street use.
[Re: Fat_Mike]
#2529853
08/01/18 09:04 AM
08/01/18 09:04 AM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Winter came early this year? How about the best of both worlds? Lighten the factory K and use tubular control arms and coilovers, especially with a motor plate? Been considering this way myself when we drop the stroker in the Charger. Member dvw (Doug) put up some pics of his on FBBO that were nice. I would link to them but can't on my tablet (don't know how). Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: 383man]
#2529940
08/01/18 12:42 PM
08/01/18 12:42 PM
Posts: 66 Catskill Mountains, NY
Joe12459
I've run an RMS AlterKtion in my 5.7 Hemi Mirada for almost 5 years now, and well over 15000 miles, and I've had no issues with it. It handles significantly better than any available high performance upgrades to the stock suspension that I have driven, and I've tried quite a few. I drive the [censored] out of the car, and it still feels like it did the day I installed it. For me, this was definitely a great investment. Of course, for the A/B/E guys, there are a lot more options, so it's probably more a matter of preference.
[Re: 383man]
#2530088
08/01/18 05:13 PM
08/01/18 05:13 PM
Posts: 1,553 Michigan
Kiddart
383man/Ron,
I cant find the thread but a year or so ago this very same conversation came up. I believe it was White dart(Guessing) that did something with a large bolt thru the lower control arm and added some support in different places to achieve this task. I recall Monte Smith added his two cents and it was positive saying he had done it on one of his many old Mopar's. I will continue to look for it. It can be done for sure on the cheap. I hate it when someone tells me it cant be done, instead of telling me why it cant be done with examples.
all these new front ends are only as good as the guy welding them together. did he do your on Friday after a long lunch?
Thank you Kiddart
[Re: 383man]
#2530103
08/01/18 05:43 PM
08/01/18 05:43 PM
Kiddart
Thank you Kiddart
[Re: 383man]
#2530178
08/01/18 08:33 PM
08/01/18 08:33 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thanks again guys for all the replies. Kid Dart thank you for the link as I will check that out. And thanks "I Bleed Mopar" for that info. I was not aware that anyone had used coil/overs while using the factory K-frame as I would love to hear more about that also. I did not start this post for anyone to be fighting with others about it as all replies are cool whether good or bad I appreciate hearing them all. As I said I have not done any aftermarket coli/over K-frames and even when we think we know all about something many times we can find out there is still something we may not have know about. So I do appreciate all the replies and info. Ron
[Re: Devil]
#2530373
08/02/18 09:50 AM
08/02/18 09:50 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Oh boy , here we go any chance for the journalism major to get his jabs in at RMS ... Devil , What did Bill do to you that got you a hair across your [censored] over him and his product ?
[Re: Fat_Mike]
#2530380
08/02/18 09:58 AM
08/02/18 09:58 AM
JohnRR
U.S.S.A.
Stop with the BS! Alterkations says this: "Disclaimer Reilly MotorSports, Inc. cannot control how this product is installed or used. By purchasing this product, the buyer/end user assumes all risks associated with its use and agrees to having the proper skills for it's installation. Reilly MotorSports Inc. and its suppliers will not be held responsible, liable or accountable for any injury, damage, loss, penalties, or fines that occur from using this product in any manner." https://www.reillymotorsports.com/files/attachments/16247/AlterKtion_Instructions_2016.pdf Ryan is a journalist, first class they are required to take is B.S. 101, I think it was is minor
[Re: FurryStump]
#2530436
08/02/18 12:32 PM
08/02/18 12:32 PM
I_bleed_MOPAR
Buford, GA
He's looking to lose the torsion bars because a PO did some cutting and welding around the trans crossmember. Tim
[Re: Kiddart]
#2531327
08/04/18 01:12 AM
08/04/18 01:12 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
383man/Ron,
all these new front ends are only as good as the guy welding them together. did he do your on Friday after a long lunch? Member Justadart (Rod) did the front K on Whitedarts (Shilohs) Dart.
[Re: 383man]
#2531344
08/04/18 01:50 AM
08/04/18 01:50 AM
cudaman1969
fredericksburg,va
Back in the day, the early pro stock-comp cars used a bracket that attached to frame and tb opening when converting to coil overs. They also had bars out there to connect the shock towers so no flexing. Better idea in my view. Try to find Roy Hills blue Duster, if I remember rite he was running out of Pettys garage then. They also use the front rack with flipped spindles or lower ball joints.
