440 source 438 stroker kit #2526690
07/25/18 12:22 AM
07/25/18 12:22 AM
Woodbridge
Tommy The Chryco Offline OP
Woodbridge
Anyone running a 438 stroker kit in there 383? using there aluminum heads as well. My question is what length push rod are you using? comp cam .491 lift
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 440 source 438 stroker kit [Re: Tommy The Chryco] #2526730
07/25/18 02:25 AM
07/25/18 02:25 AM
I've assemble several different 400 stroker motors with those heads with 1.5 rocker ratio aluminum rocker arms and 3/8 pushrods with solid roller cams and lifters up
I'm getting ready to finish assembling a 1972 413 truck block bored to 4.250 with a 4.150 stroke crank with a set of their heads and a set of ductile iron RAS blueprinted 1.5 ratio rockers, if I run into problems with 3/8 Manton 3/8 pushrods on the hydraulic lifters used in this motor I'll add onto this post later about that up
Re: 440 source 438 stroker kit [Re: Tommy The Chryco] #2528617
07/29/18 02:03 PM
07/29/18 02:03 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
The bottom line is, you will need an adjustable pushrod to come up with the correct length. Lift is not important, is the cam a hydraulic flat tappet, a solid F/T, are you running adjustable rockers or the stock stamped? Any way, to do it right, it needs to be measured after assembly.
Re: 440 source 438 stroker kit [Re: Tommy The Chryco] #2528714
07/29/18 06:32 PM
07/29/18 06:32 PM
definitely view the "straub" youtube vid on rocker arm geometry
