Re: New 4500 TBI EFI systems.....
[Re: Dragula]
#2526787
07/25/18 10:57 AM
07/25/18 10:57 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I've always been an old school advocate of keeping things simple. I love my carbs, but I'm telling ya, seeing this has me really wanting to put one on my hemi. Love the simplicity of it and the fact that one component can control so many different functions that I currently have separate boxes for.
[Re: an8sec70cuda]
#2526829
07/25/18 12:13 PM
07/25/18 12:13 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
I've always been an old school advocate of keeping things simple. I love my carbs, but I'm telling ya, seeing this has me really wanting to put one on my hemi. Love the simplicity of it and the fact that one component can control so many different functions that I currently have separate boxes for. Totally agree! Plus, data logging related to the F.I. unit.
[Re: STEFF]
#2526834
07/25/18 12:21 PM
07/25/18 12:21 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
This technology definitely has my attention
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: an8sec70cuda]
#2526837
07/25/18 12:25 PM
07/25/18 12:25 PM
BradH
I've always been an old school advocate of keeping things simple. I love my carbs, but I'm telling ya, seeing this has me really wanting to put one on my hemi. Love the simplicity of it and the fact that one component can control so many different functions that I currently have separate boxes for. I'm following Andy's Sniper thread to see how things work for him, what he's had to deal with to make it "right", etc. Cool stuff... says the man with more carbs than fingers on one hand.
[Re: Dragula]
#2526853
07/25/18 12:59 PM
07/25/18 12:59 PM
Posts: 304 Florida
Mark Whitener
Be careful on those Dominator EFI's. I heard of one shop that had three. First one wouldn't run, second fairly, third wouldn't go richer than 15 to 1 at WOT...
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: Dragula]
#2526866
07/25/18 01:25 PM
07/25/18 01:25 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Well I'm sticking with the carbs for sure for now. I am not into being the 'guinea pig" and have heard similar issues from a couple folks. We were at the dyno Monday and those guys have seen similar, theyhad three Holley boxes sitting there to go back. So while I'm "intrigued" I will be in wait and see mode. Trying to hold my son at bay for now on this stuff.
As for getting around the pits. Our cars fire right up and idle with zero issues. Since they are bracket cars we rarely change jetting unless we are headed to Denver, Salt Lake or Sonoma if the weather is nice up there. Usually done before we load them up. As for the heads up car, we are still gonna stick with our beloved carb, although Alex Hayes has definitely had some impressive runs since he switched.
[Re: an8sec70cuda]
#2527048
07/25/18 07:17 PM
07/25/18 07:17 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I've always been an old school advocate of keeping things simple. I love my carbs, but I'm telling ya, seeing this has me really wanting to put one on my hemi. Love the simplicity of it and the fact that one component can control so many different functions that I currently have separate boxes for. My EFI runs everything on my car now. I went from switches for two fans, a water pump, and a fuel pump to nothing but a starter button. For your nitrous you would just need an arm switch, the ECU will do the rest.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2527177
07/26/18 12:28 AM
07/26/18 12:28 AM
Posts: 12,160 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Does anyone wonder what it will be like in a few years when Holley moves on from this platform and you need service parts?
Heck, look at what a guy can run into getting current production MSD components serviced.
Master, again and still
[Re: DaveRS23]
#2527249
07/26/18 08:12 AM
07/26/18 08:12 AM
Bad340fish
Tulsa OK
Heck, look at what a guy can run into getting current production MSD components serviced. Valid concern, especially on all these units that are potted and cannot be repaired. If that concerns you do what I did. Buy a kit from DIYAUTOTUNE.com and assemble it yourself. Save money and have a repairable ecu because you built it. That being said I would imagine most of the failures out there are related to poor installs. You can let the smoke out of anything if you hook it up wrong. I would imagine a charging system in an old stock mopar would cause fits for one of these systems when the voltage goes to crap with the headlights on at idle.
[Re: AndyF]
#2527451
07/26/18 04:19 PM
07/26/18 04:19 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I've been spending time on the Sniper forum and the biggest problem I see is that a lot of people don't understand how sensitive digital electronics are to RF noise. EFI wiring has to be protected from RF so that means resistor plugs, resistor wires, keep the ignition stuff away from the EFI wires, fly back protection on relays, etc. It is fairly simple to do it correctly but if you don't know what you don't know then you can screw stuff up. I had this problem with my Commander 950 using the ign pickup for a tach signal. The inside of a distributor is basically a lightning factory and my tach signal looked like a jagged ribbon 3000 RPM wide. I had to splice a shielded cable as tight to the pickup as possible to get a usable signal. Another issue is ground differentials. If you don't know what that is, just follow the wiring instructions to the letter because if it says to power and ground a particular circuit to a specific point, there is a reason and the reason is ground differential. Kevin
