Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: Supercuda] #2526636
07/24/18 10:29 PM
07/24/18 10:29 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Originally Posted By Supercuda
Originally Posted By bbtrux
drill and tap for a relatively large bolt (3/8, 7/16), cutoff wheel and smooth off excess bolt , and then drill and tap stock size. Did it once on a rearend yoke on a truck, and got away with it. No problem on a low tension valve cover bolt.
Genius, I have never even thought of that. I will have to remember it.
X2!
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2526803
07/25/18 11:25 AM
07/25/18 11:25 AM
God's Country Maryland
GODSCOUNTRY340 Offline
This may be a lost art these days but I'd put a stud in there and braze it in place (brass rod). Cast iron is easy to braze and it will also repair that crack coming from the hole. Let it cool on it's own after brazing, don't cool it with water.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2527088
07/25/18 09:00 PM
07/25/18 09:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Clean cast iron is easy to braze, getting it clean is another story. But goos idea
Don't be the exception.
