Pics wanted-71-74 B body manual trans #2524361
07/20/18 02:39 AM
07/20/18 02:39 AM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
Does anyone have pics of the bottom of the floor pan on a '71 through '74 B body 4 speed car?
I want to see how the factory did it.
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524381
07/20/18 05:08 AM
07/20/18 05:08 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think it is different between if your car is a bench seat or bucket seat.
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524382
07/20/18 05:27 AM
07/20/18 05:27 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Need to specify which car. Bench and buddy seat cars are different than bucket seat or buckets with a console. The pans are the same but the weld in humps are different.
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524486
07/20/18 12:29 PM
07/20/18 12:29 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I have a naked 71 RR that came with a bench seat sitting in my garage, I can take some pics of the inside easily, do you need pics from the underside too?
Joe
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524727
07/20/18 08:24 PM
07/20/18 08:24 PM
MO
cdp Offline
cdp  Offline
MO
Here's mine. Original bench seat 4spd car. I'm going with buckets and arm rests.
Re: Pics wanted-71-74 B body manual trans [Re: cdp] #2524730
07/20/18 08:27 PM
07/20/18 08:27 PM
MO
cdp Offline
cdp  Offline
MO
Bottom
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524734
07/20/18 08:34 PM
07/20/18 08:34 PM
MO
cdp Offline
cdp  Offline
MO
let me know what you need, my car is right here in the garage and am working on it tonight.
The bucket seat/console version is identical to the E-bodies, but the pedal configuration is slightly different.
Re: Pics wanted-71-74 B body manual trans [Re: jlatessa] #2524859
07/21/18 03:00 AM
07/21/18 03:00 AM
Stroker Offline OP
Stroker  Offline OP
YES! That would be great-I want to see how much of the floor is cut under the 4 speed hump
Re: Pics wanted-71-74 B body manual trans [Re: cdp] #2524860
07/21/18 03:10 AM
07/21/18 03:10 AM
Stroker Offline OP
Stroker  Offline OP
CDP-good pics, but I was looking for undercar shot with no trans. (picky, ain't I?)
The interior shot was good-that's the stock 4 speed hump for bench seat, correct?
I'm converting my '72 Charger to manual.
More like, fixing somebody else's slop job.
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524935
07/21/18 12:06 PM
07/21/18 12:06 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
bench seat 4 spd car
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2524956
07/21/18 12:57 PM
07/21/18 12:57 PM
MO
cdp Offline
cdp  Offline
MO
Re: Pics wanted-71-74 B body manual trans [Re: gygeneral] #2525046
07/21/18 05:57 PM
07/21/18 05:57 PM
Stroker Offline OP
Stroker  Offline OP
Thanks,gy!
cdp-nice 'Runner, still have it?
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2525493
07/22/18 07:03 PM
07/22/18 07:03 PM
Stoney Creek, Ontario, Canada
76Beeper Online content
76Beeper  Online Content
Here's mine.
I replaced the drivers side floor pan and added the 4 speed hump.
It was an automatic transmission car.
Re: Pics wanted-71-74 B body manual trans [Re: 76Beeper] #2526184
07/24/18 12:34 AM
07/24/18 12:34 AM
Stroker Offline OP
Stroker  Offline OP
Originally Posted By 76Beeper
Here's mine.
Did you just sort of use the hump as a template?
Did you leave the floor sheetmetal on top of the torsion bar crossmember?
Good pics, thanks to everyone for the replies.
Re: Pics wanted-71-74 B body manual trans [Re: Stroker] #2526431
07/24/18 03:05 PM
07/24/18 03:05 PM
[/quote]Did you just sort of use the hump as a template?
Good pics, thanks to everyone for the replies. [/quote]
Yes, I did use the hump as a template.
For the very top of the torsion bar cross member, the 4 speed hump covers that area.
