Re: A body's w/ ladder bars??
[Re: dvw]
#252447
03/16/09 01:14 PM
03/16/09 01:14 PM
Posts: 10,051 MI, usa
dvw
MI, usa
[Re: mopowers]
#252452
03/16/09 09:53 PM
03/16/09 09:53 PM
Posts: 3,640 Oakland, MI
dizuster
Oakland, MI
Is it better to notch the subframe connectors to accept the ladder bar crossmember like that? I always thought people just buttweld the LB crossmember to the connectors.
By putting the tube all the way through the frame, you can then weld it on both sides. I'm not sure if it's common to do it that way, but it's certainly stronger...
I would think mounting the coil overs like that would want to twist the upper crossmember. Is that a common way of mounting them, or would mounting them directly below the crossmember be better?
The only way that shock is twisting the 1" 3/4" tube welded only 2" away from the frame, is if this car becomes a dukes of hazard stunt double later in it's life!
Mounting them directly below may just become a packaging issue. You gain about 2" of room when putting them on the side like that vs. straight down.
[Re: dvw]
#252457
03/17/09 07:40 PM
03/17/09 07:40 PM
dvw
MI, usa
