Re: A body's w/ ladder bars?? [Re: roadrunnerreds] #252443
03/15/09 08:48 PM
03/15/09 08:48 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
pic 3
Re: A body's w/ ladder bars?? [Re: roadrunnerreds] #252444
03/15/09 08:50 PM
03/15/09 08:50 PM
Gettysburg Pa
Gettysburg Pa
pic 4
Re: A body's w/ ladder bars?? [Re: roadrunnerreds] #252445
03/16/09 10:48 AM
03/16/09 10:48 AM
Gettysburg Pa
Gettysburg Pa
pic 5
Re: A body's w/ ladder bars?? [Re: roadrunnerreds] #252446
03/16/09 02:11 PM
03/16/09 02:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
These are pics of my 64 Belvedere. Remember the car will have a forward rake. This will require raising the front mount to keep the bar level. Also lowering the rear ride height will require raising the ladder bar front location to maintain its current posistion. I agree after a lot of research, its hard to install the mounts to low unless the car sits in the weeds.
Doug
Re: A body's w/ ladder bars?? [Re: dvw] #252447
03/16/09 02:14 PM
03/16/09 02:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Heres the front mount
Re: A body's w/ ladder bars?? [Re: dvw] #252448
03/16/09 02:16 PM
03/16/09 02:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Heres the outside of the front mount. the tube was boxed in later.
Doug
Re: A body's w/ ladder bars?? [Re: dvw] #252449
03/16/09 02:18 PM
03/16/09 02:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This is how it sits at ride height.
Doug
Re: A body's w/ ladder bars?? [Re: dvw] #252450
03/16/09 06:02 PM
03/16/09 06:02 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Doug
Is it better to notch the subframe connectors to accept the ladder bar crossmember like that? I always thought people just buttweld the LB crossmember to the connectors.
Re: A body's w/ ladder bars?? [Re: dvw] #252451
03/16/09 06:07 PM
03/16/09 06:07 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I would think mounting the coil overs like that would want to twist the upper crossmember. Is that a common way of mounting them, or would mounting them directly below the crossmember be better?
Re: A body's w/ ladder bars?? [Re: mopowers] #252452
03/16/09 10:53 PM
03/16/09 10:53 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
By putting the tube all the way through the frame, you can then weld it on both sides. I'm not sure if it's common to do it that way, but it's certainly stronger...
The only way that shock is twisting the 1" 3/4" tube welded only 2" away from the frame, is if this car becomes a dukes of hazard stunt double later in it's life!
Mounting them directly below may just become a packaging issue. You gain about 2" of room when putting them on the side like that vs. straight down.
Re: A body's w/ ladder bars?? [Re: mopowers] #252453
03/16/09 10:57 PM
03/16/09 10:57 PM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
It is a very common way of mounting the shock tabs. The S&W racecars instructions show that you can mount them directly under or on the side, either way is fine.
Re: A body's w/ ladder bars?? [Re: mopowers] #252454
03/17/09 09:52 AM
03/17/09 09:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can't see it very well, but the shock tab is also welded to the OE cross member. I had worried about this also untill I loooked at many other cars that were the same.
Doug
Re: A body's w/ ladder bars?? [Re: dvw] #252455
03/17/09 11:00 AM
03/17/09 11:00 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Yeah, I noticed that when I went back and looked at your pictures again last night. That seems like a smart thing to do. I may have to 'borrow' your idea . Thanks again for the pics. Do you have a picture of the front LB crossmember all welded up?
Re: A body's w/ ladder bars?? [Re: mopowers] #252456
03/17/09 08:39 PM
03/17/09 08:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here you go. I hole sawed it first. Thene cut the bottom piece out. Slid the cross member up and tacked it. Then I welded the botom piece I cut out back in.
Doug
Re: A body's w/ ladder bars?? [Re: dvw] #252457
03/17/09 08:40 PM
03/17/09 08:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A pic from the inside.
