Page 2 of 3 1 2 3
Re: 440 STROKER KIT [Re: AndyF] #2523285
07/17/18 10:07 PM
07/17/18 10:07 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I SENT THEM TO DUANE PORTER LAST YEAR.
Re: 440 STROKER KIT [Re: rickb67] #2523305
07/17/18 10:46 PM
07/17/18 10:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Never heard of him... shruggy
grin
'63 Dodge 330
11.19 @ 121 mph
Re: 440 STROKER KIT [Re: rickb67] #2523313
07/17/18 10:52 PM
07/17/18 10:52 PM
AndyF Offline
AndyF  Offline
That is the right guy to send them to. If Dwayne did the heads then you should be ready to go. He'll probably have a record of what the combustion chamber size is too and he can provide you with a cam recommendation if you don't already have a cam.
Do you have a Stage VI intake? If so, 4150 or 4500? You'll need a 4500 intake and carb to make the bigger power.
Re: 440 STROKER KIT [Re: rickb67] #2523321
07/17/18 11:04 PM
07/17/18 11:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Let’s cut to the chase.... what ET/mph you looking for?
Re: 440 STROKER KIT [Re: rickb67] #2523353
07/17/18 11:47 PM
07/17/18 11:47 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
well, if you don't have a stage VI RB intake manifold, one just got posted in the race parts section here...
Re: 440 STROKER KIT [Re: krautrock] #2523377
07/18/18 12:48 AM
07/18/18 12:48 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If it's the 4500 piece, that intake along with a 1050 really woke my 498 mech cam StageVI junk up.
Re: 440 STROKER KIT [Re: AndyF] #2523386
07/18/18 01:04 AM
07/18/18 01:04 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I HAVE A STAGE 6 INTAKE 4150. I KNOW I WILL NEED A DIFFERENT INTAKE TO RUN A 4500 CARB. I AM LOOKING TO HIGH 9'S.
Re: 440 STROKER KIT [Re: rickb67] #2523391
07/18/18 01:18 AM
07/18/18 01:18 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
What kind of car & weight ?
Re: 440 STROKER KIT [Re: CSK] #2523406
07/18/18 01:36 AM
07/18/18 01:36 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
67 BARRACUDA 3300 LBS WITH DRIVER.
Re: 440 STROKER KIT [Re: rickb67] #2523522
07/18/18 11:22 AM
07/18/18 11:22 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
You don't need a big stroker to run in the high 9's
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 440 STROKER KIT [Re: rickb67] #2523523
07/18/18 11:24 AM
07/18/18 11:24 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Any idea what the typical DA is where you race?
And for those keeping score....... I didn’t port Ricks heads...... I repaired them.
They were suffering from the “not all that ususual for stage 6’s, the valve seats are loose syndrome”.
They’re std port stage 6’s with similar flow numbers to BradH’s old 6’s.
I’d probably lean towards to low deck 511 build myself.
The 400 block is generally tougher and that combo can use a std RB intake manifold.
Flat tops .005 down the hole and .040 gaskets, heads at 72-73cc, would put it at right about 12.5:1cr.
I’d probably open the heads to MW size and run either an Indy 440-3 or the Edelbrock SV.
Put enough cam in it, should work pretty well.
That being said....... if it were in the budget, better flowing heads wouldn’t be a bad thing.
Sorry, wrong Sonny! [Re: fast68plymouth] #2523669
07/18/18 04:57 PM
07/18/18 04:57 PM
dogdays Offline
dogdays  Offline
Sonny Leonard is a famous mountain motor builder. Sorry for the mixup.
https://www.enginelabs.com/news/inside-scoop-sonny-leonards-new-820ci-marine-engine/
R.
Re: 440 STROKER KIT [Re: rickb67] #2523725
07/18/18 06:44 PM
07/18/18 06:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
1. It's Dwayne, not Duane... I've written him enough checks over the years to know that. tonguue
2. ALL CAPS is considered "YELLING!". Please flip off the caps lock, except when punctuation requires it. no
Re: 440 STROKER KIT [Re: 67mprfan] #2523729
07/18/18 06:49 PM
07/18/18 06:49 PM
BradH Offline
BradH  Offline
Given what your old car in your signature ran, I think you'd agree that you don't need a stroker at all to run high 9s. A well-built 440/451 can do it with the right car combination, but it's not the way most people choose to go about it these days.
Re: 440 STROKER KIT [Re: rickb67] #2523773
07/18/18 07:58 PM
07/18/18 07:58 PM
UK
rb446 Offline
rb446  Offline
UK
According to my no's in a 3300lb all in car you only need 672fwhp on track to run S/G times@135mph.....Moroso s/rule will show even less.
You don't need 500+ cubes to do it, 440/451 as said, put some decent gears in it (4.56+), and let it 60 and rev through the traps. 7k+ twocents
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 440 STROKER KIT [Re: rb446] #2523780
07/18/18 08:16 PM
07/18/18 08:16 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
[quote
You don't need 500+ cubes to do it, 440/451 as said, put some decent gears in it (4.56+), and let it 60 and rev through the traps. 7k+ twocents [/quote]
4.56 gears Dwayne Porter spec cam Indy ez-1 heads dominator carb ...then let her eat
Re: 440 STROKER KIT [Re: rickb67] #2523796
07/18/18 09:11 PM
07/18/18 09:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
A build like this should easily make 1.25ft/lb per ci.
You have to buy a crank, rods, and pistons anyway...... the extra cubes are free.
I’ll take the extra 80ft/lbs of torque for no additional charge please.
The Moroso chart shows 650hp for a 9.80@3300lbs.
I’d be targeting a solid 10%+ over that to account for a less that optimal chassis set up and air quality/density.
Re: 440 STROKER KIT [Re: fast68plymouth] #2523801
07/18/18 09:17 PM
07/18/18 09:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just lose 500 pounds and do it with 906 heads, stock rods and crank, TRW pistons, and old school technology like we did 30 plus years ago. You guys are spoiled. Lol 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 STROKER KIT [Re: pittsburghracer] #2523806
07/18/18 09:35 PM
07/18/18 09:35 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
👍For the guys still doing it that way!
Have a great day
Iowan
"obsolete is neat"
Re: 440 STROKER KIT [Re: fast68plymouth] #2523921
07/19/18 02:54 AM
07/19/18 02:54 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
DUANE I WILL BE CALLING YOU FOR A CAM WHEN I GET THIS STARTED
Page 2 of 3 1 2 3
