Re: Battery n trunk cable routing?
[Re: GoDartGo]
#2523295
07/17/18 10:25 PM
07/17/18 10:25 PM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I keep all the electrical stuff inside the car. Main cable runs up through the car to a junction where it is distributed as needed.
[Re: fullmetaljacket]
#2524453
07/20/18 11:31 AM
07/20/18 11:31 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Mine after coming off the battery runs along the continental shelf of the trunk floor by the lower quarters and then hugs the passenger wheel wells up to the rear well valley hump and across to the drivers side and into the cars interior. From there it runs along the floors edge and under the sill plates up to the kick panel area under the kick panel covers and then ends at a junction box half way up the inner firewall. On the engine side of the firewall, it snakes down very tightly down to the starter stud. Aluminum cable strand for a lightweight set up. Heat shrink sealed ends for trouble free operation out in the elements. This is pretty much how mine is ran.
[Re: dvw]
#2524457
07/20/18 11:37 AM
07/20/18 11:37 AM
Posts: 10,046 MN
JERICOGTX
MN
I made tabs so the cable runs along the upper RH 1/4 panel. Glued the tabs on with Plexus to the trunk gutter. Then over the tub and along the right door sill under the carpet. It terminates at a firewall pass thru near the gas pedal. That way you don't see it laying in the trunk. Doug Doug, how did you do the lever/handle for the battery cutoff switch, inside the car? Jeff
69 GTX
68 Road Runner
[Re: GoDartGo]
#2524541
07/20/18 02:19 PM
07/20/18 02:19 PM
Posts: 10,046 MN
JERICOGTX
MN
Any pictures of how it is mounted in the passenger area?
69 GTX
68 Road Runner
