Oil Coming Out Of Oil Breathers Help
#2522608
07/16/18 03:42 PM
07/16/18 03:42 PM
Posts: 388 Southington, Ohio
dm69charger
Southington, Ohio
I am getting oil out of the oil breathers on top of the valve covers. They are located towards the front of the engine near the intake on both passenger and driver's side. The valve covers have baffles in them.
Specs: 1969 Dodge Charger, 540 cui Hemi, Megablock, 4.375 bore x 4.5 stroke, Internal pickup for oiling, Miloden oil pan with windage tray, Indy 426-1 Aluminum heads, Solid roller cam, Valve lift .61 intake and exhaust, Indy cast aluminum valve covers, Open oil breathers with baffles, Fresh build, maybe 2,000 miles on it. Some track time. Block was worked, gone through by my machinist, and final torque honed. Rings were file fit according to the instructions.
I haven't done a compression test or leak down test to know if it is blow-by. I was wondering if there was anything else I should check (consider) while I'm at it?
I did not put in the oil restrictors in the heads because I had read horror stories about not enough oil to the top end on Hemis. I was thinking that it was on the safer side to have more oil than less? Should I put them in?
Re: Oil Coming Out Of Oil Breathers Help
[Re: dm69charger]
#2522614
07/16/18 03:44 PM
07/16/18 03:44 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
Do not put oil return restrictor in your heads ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Do you oil the rocker arms full time with your roller cam? How big are the baffles under your breather caps?
[Re: dm69charger]
#2522650
07/16/18 04:39 PM
07/16/18 04:39 PM
Posts: 4,213 New York
polyspheric
New York
When did this start? What change (if any) was done before that?
Boffin Emeritus
[Re: dm69charger]
#2522669
07/16/18 05:21 PM
07/16/18 05:21 PM
Posts: 11,802 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it was OK, and then it was not, something has changed in the engine. Leak it would be the first thing to do.
[Re: Thumperdart]
#2522765
07/16/18 08:22 PM
07/16/18 08:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have you pulled the covers off yet to see if the baffles have plenty of clearance.. if they get pushed partly closed from the rockers then you will build pressure in the covers ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dm69charger]
#2522831
07/16/18 10:27 PM
07/16/18 10:27 PM
Posts: 7,500 Minnesota
Hemi_Joel
Minnesota
I think you did the right thing by not restricting oil to the heads. I usually groove the #4 cam journal to get more oil to the heads on a street motor with stiff roller cam springs. I've smoked too many rockers and push rods to not.
As for the blowby, I agree with Andy, this motor is going to have some. Work on better baffles.
GOod luck! Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2522964
07/17/18 08:39 AM
07/17/18 08:39 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
GOod luck! Joel I see both Andy and now Joel comment on the size of the engine "it's going to have blow by". So is a 4.375 x 4.5 Hemi going to use oil due to it's size? See my post earlier on my engine, same size, and oil consumption. Oddly enough I have no blow by, installed a trap in PVC line to check and it never collected oil?
[Re: dm69charger]
#2522994
07/17/18 10:50 AM
07/17/18 10:50 AM
polyspheric
New York
Oh, wait - I already posted 10,000 words on this, and no one read it. My bad.
Boffin Emeritus
[Re: dm69charger]
#2523104
07/17/18 03:25 PM
07/17/18 03:25 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
There's likely nothing wrong w/ the motor, just the nature of the beast. That big motor is gonna make a lot of crankcase pressure and there's gonna be a lot of oil mist in there. I know, my 572" hemi did it the first time I drove it w/ just two open element breathers on the valve covers. I added baffles and got the Mr. Gasket breathers that sit up above the covers w/ tubes, then added steel wool inside the tubes...which helped a lot, but still ended up leaking oil if you drove it hard. I eventually put a vacuum pump on the motor, which cured it. Having said that, I don't think you need a pump to fix it.
My other car is a wedge, but I use a pair of -10 lines from each valve cover that "tee" into a breather tank mounted beside the radiator. This setup works great, no leaks, and much less expensive than a vacuum pump. See pic...
[Re: dm69charger]
#2523125
07/17/18 03:57 PM
07/17/18 03:57 PM
MR_P_BODY
If its smoking that bad you most likely have a broken ring.. OR the intake is sucking in oil that would be where I looked ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: dm69charger]
#2523144
07/17/18 04:24 PM
07/17/18 04:24 PM
MR_P_BODY
The large diameter of the systems on those NASCAR will drop the air velocity and IF your pulling oil out of the breathers it will help a ton.. it really slows the air down ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
