Re: Oil Coming Out Of Oil Breathers Help
[Re: dm69charger]
#2523153
07/17/18 04:50 PM
07/17/18 04:50 PM
Posts: 388 Southington, Ohio
dm69charger
Southington, Ohio
I do not have a stock type PCV system. I am hiding the big boy under the stock hood so air cleaner options are neel to none. I am using two Holley 600's in line on top of a stage V dual plane intake.
I am at least a little more relaxed with understanding that this is more of a common problem than I first had anticipated. I honestly thought a tear down was in my near future. It still may be but this is promising that it is possibly not a bad ring. I have already been looking at some oil catch can options from Summit Racing. I will definitely keep you posted. I would love to show some pictures but I need help with how to post them?
Edit: I think I figured out how to add pictures. I apologize if it comes in to big. If it does, next I will work on how to make it smaller.
[Re: dm69charger]
#2523197
07/17/18 05:55 PM
07/17/18 05:55 PM
Thumperdart
State of confusion
Edit: I think I figured out how to add pictures. I apologize if it comes in to big. If it does, next I will work on how to make it smaller. I'd dump those air filters also cos they rob lots o power and have see it first hand.............
[Re: dm69charger]
#2523299
07/17/18 10:39 PM
07/17/18 10:39 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
The 500" motor in my 69 Dart had a 700 lift roller and always tried to push every gasket out, probably needed a vacuum pump but I did run the evac hoses to the collectors and helped a lot.
The 500" motor in my street car only has a small 557 lift solid cam and was fine for a couple years with just small breathers on the valve covers but once the breathers became oil soaked they started leaking. I put some baffled breather stands on the covers and it seems to be fine now.
Running hoses from the covers to an aluminum tank seems to be the hot setup as some of these guys have already mentioned.
[Re: polyspheric]
#2523328
07/17/18 11:15 PM
07/17/18 11:15 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Oh, wait - I already posted 10,000 words on this, and no one read it. My bad. Browsed through a ton of crap here over the years..... sorry I missed it
[Re: Hemi ragtop]
#2523963
07/19/18 09:58 AM
07/19/18 09:58 AM
dm69charger
Southington, Ohio
So how much oil is your engine using? I would love to know. My setup is very similar, (bore/stroke) I use a factory PVC and an open breather on the opposite valve cover. I have ZERO blow by even with the 4.5" crank. But, with clean plugs, no leakes, I use a quart in 250 miles. What about you? I have been extremely busy this week so I hadn't had a chance to get to it. I honestly don't know off hand? When I get to it on Saturday, I will check how far it is down. I have the speedometer disconnected so I won't know the mileage though. I am interested in what the plugs look like.
[Re: dm69charger]
#2523972
07/19/18 10:21 AM
07/19/18 10:21 AM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I would think you might benefit from a oil separator type breather. Joe
Without Data, you’re just another guy with an opinion.
[Re: Chuck@Best_Machine]
#2524020
07/19/18 12:07 PM
07/19/18 12:07 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
On a Hemi you can’t have the breather directly over the intake valve spring. Relocate the breathers closer to the spark plugs and Install a baffle under it and it should stop. There are a lot of pictures on our FB page of Hemis with breathers for proper location. We put a PVC on the pass side of my bro's 517 Hemi & he has had no oil issues for 5-6 yrs. Also, a pic of Chuck's Best Machine Hemi breather locations.
[Re: Hemi ragtop]
#2525749
07/23/18 09:51 AM
07/23/18 09:51 AM
dm69charger
Southington, Ohio
Something is going on for you to have that much blow by. I have the same bore/stroke combination and I have no blow by, none. I am running stock valve covers with a stock push on breather on the driver side and a pvc valve in the passenger side. Can you use stock valve covers? I can not use stock valve covers. These are Indy 426-1 Legend Aluminum Heads. Stock valve covers won't work. On a side note, what carburetors are you using?
