Re: transission help, racecar to street car
[Re: rickraw]
#2522258
07/15/18 07:50 PM
07/15/18 07:50 PM
Posts: 26,046 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yep, the governor guts are usually removed when installing a manual VB. And, if the trans has a roller rear support you won't be able to use a stock VB.
[Re: Dave Hall]
#2522283
07/15/18 09:22 PM
07/15/18 09:22 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
The manual VB's are cool on the street. Why would you remove it? Put it back and shift it! You'll be much happier... Agreed. Our Challenger has it and it's 100% a street car.
[Re: dustergirl340]
#2522290
07/15/18 09:34 PM
07/15/18 09:34 PM
Posts: 4,087 Mo.
racerx
Mo.
The manual VB's are cool on the street. Why would you remove it? Put it back and shift it! You'll be much happier... Agreed. Our Challenger has it and it's 100% a street car. x3 nothing like barking tires in 2 and 3 if you can. ![cool cool](/ubbthreads/images/graemlins/custom/cool.gif)
[Re: Dave Hall]
#2522297
07/15/18 09:42 PM
07/15/18 09:42 PM
Posts: 4,715 Wichita
GY3
Wichita
The manual VB's are cool on the street. Why would you remove it? Put it back and shift it! You'll be much happier... Yep, and you eliminate that Rube Goldberg kickdown linkage.
[Re: Dave Hall]
#2522301
07/15/18 09:48 PM
07/15/18 09:48 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
The manual VB's are cool on the street. Why would you remove it? Put it back and shift it! You'll be much happier... Im usually to drunk to concentrate on shifting, plus the wheel in one hand and my beer in the other makes it a bit hard
[Re: racerx]
#2522323
07/15/18 10:44 PM
07/15/18 10:44 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
The manual VB's are cool on the street. Why would you remove it? Put it back and shift it! You'll be much happier... Agreed. Our Challenger has it and it's 100% a street car. x3 nothing like barking tires in 2 and 3 if you can. Even cooler if you push buttons to do it!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: mcat4321]
#2522334
07/15/18 10:55 PM
07/15/18 10:55 PM
Posts: 4,213 New York
polyspheric
New York
I drove a street car with a converted full manual VB (Chrysler instructions, separator plate, transfer plate) in 1970. Hated it - got pulled over many times for smoking the tires on the 1-2 shift with light throttle. Couldn't drive it on wet pavement unless the steering wheel was centered or it would loop on the shift. Same problem with my DD now (dangerous when wet), except it retains full auto upshift and kick-down.
Boffin Emeritus
[Re: mcat4321]
#2522356
07/15/18 11:38 PM
07/15/18 11:38 PM
Posts: 20,231 Park Forest, IL
slantzilla
Park Forest, IL
I drove a Slant car on the street for years with a 10" converter and 3.91 gears. I rarely used first gear and most of the time just drove in high gear. RMVB's are not that difficult on the street. If yours has LBA you'll quickly learn not to downshift into low while moving. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: mcat4321]
#2522413
07/16/18 06:48 AM
07/16/18 06:48 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I don't get the fascination with manual valve bodies. Why not get a proper manual gearbox instead? 3 pedals are too confusing?
Had a reverse MVB in a mainly strip-only '71 Dart years ago. While it was 'secure' shifting on the actual strip, it felt cumbersome in every other situation.
Besides that, I can manually shift just fine in any automatic transmission I have, even the pushbutton ones. Heck, I pretty much keep the A518 in my daily Dart in 2nd gear most of the time during city-driving, unless the situation lents to use 3rd or OD. Whenever I don't like manual 'labor', I just put it in Drive and enjoy the ride evenso.
If you want sharper shifting, you need to install a TransGo Reprogramming kit that takes any slip out of the trans.
[Re: slantzilla]
#2522427
07/16/18 09:29 AM
07/16/18 09:29 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I have an A1 brake valve body for another transmission I might use. It has an LBA and after 20 some odd years of driving a non LBA manual valve body I am not sure how well that is going to go at first lol.
68 Barracuda Formula S 340
[Re: mcat4321]
#2522435
07/16/18 09:45 AM
07/16/18 09:45 AM
Posts: 570 UK
rb446
UK
Around 1986 we got a bit more serious with my '71 340 Cuda street/strip car and installed 4.30's, 4200 stall and a manual v-body (no brake) in the 727, standard shift pattern with factory slapstick, we also drilled some holes in the clutch drum I think it was, can't remember exactly......wow, that shifted real hard 1st>2nd, not quite so to 3rd, it would chirp the tyres on the road, almost hurt your neck, but I loved it, got used to it and where to have the revs to calm it a bit, best of both worlds a manual auto.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
