Re: Why everyone needs a turbo
[Re: polyspheric]
#2521499
07/13/18 03:44 PM
07/13/18 03:44 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
theory's from the keyboard jockeys
LOL! That's me. Never had a wrench in my hand, put anything together, tuned or ran anything but my mouth.
[Re: polyspheric]
#2521528
07/13/18 05:19 PM
07/13/18 05:19 PM
Posts: 4,680 Wichita
GY3
Wichita
LOL! https://youtu.be/aE_lrZEEc94Yeah, turbos aren't consistent at all... Go to 27:50 in the video.
[Re: 1980volare]
#2521620
07/13/18 09:20 PM
07/13/18 09:20 PM
Posts: 4,206 New York
polyspheric
New York
I'd explain, but the IQ levels displayed make that sort of... pointless.
Boffin Emeritus
[Re: polyspheric]
#2521660
07/13/18 10:58 PM
07/13/18 10:58 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I'd explain, but the IQ levels displayed make that sort of... pointless. Yup, pointless is you on a mopar site thinking you are some kind of know it all.
[Re: polyspheric]
#2521777
07/14/18 12:28 PM
07/14/18 12:28 PM
Posts: 2,297 NE Ohio
DoubleD
NE Ohio
I'd explain, but the IQ levels displayed make that sort of... pointless. How can you explain? - you have never done anything like it - so it is pointless then!
[Re: 1980volare]
#2521884
07/14/18 05:14 PM
07/14/18 05:14 PM
polyspheric
New York
Sorry, have you made an extensive tour of my property and history? I began work on cars in 1963, were you there? I don't recall. My DD is a 520 hp twin turbo 2JZ-GTE Lexus. I started working on turbos in 1975 with a Corvair Corsa, then in 1978 with a new Riviera V6.
Remind me: when did I make any claim to "know everything"? Try limiting your insults to facts? Please enlighten me: exactly which statements of mine are WRONG (as opposed to "things you don't understand")?
You're up.
Boffin Emeritus
[Re: 1980volare]
#2521898
07/14/18 06:04 PM
07/14/18 06:04 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
where consistency matters anyhow. Unfortunately true. In addition to all the other annoying variables (air density, ATF temperature, octane) you have to add intercooler efficiency (what's the actual output temperature?), time to spool, does spark retard kill more power than too rich (for the same degree of anti-knock defense). When you read that "on a turbo car the tune is worth 500 hp", that's what they're talking about. Poly you're a smart guy, but man can you come off arrogant sometimes. First... air density changes effect all cars, not just turbos. My guess is you already know that though. ATF temp effects all cars... not just turbos. An improperly sized trans cooler on anything is going to suffer repeatability issues. Explain to me how octane on a turbo car effects repeatability? Any car that doesn't have enough of it N/A or Turbo, is going to detonate and have issues. It's not a "Turbo" thing. Intercooler efficiency effects power... not consistency. Put a good sized intercooler on it, and you don't have to worry about heat soak. No different then making sure a NA car has the proper sized radiator. Time to spool is repeatable as hell. It's a mechanical device, there is no magical external unpredictable forces in the world that make it spool fast one time, and slow another. The mass flow from the engine is predictable, and that's what makes the turbo spool. I have HUNDREDS of data logs that prove it. My boost controller holds the boost within 0.1psi of the targeted curve throughout the run. It will go from 13psi to 20psi in about 0.3sec. What does spark retard killing more or less power then A/F ratio have to do with bracket racing? It's like any NA car. You get a good tune in it, and leave it alone when you're bracket racing it. Who would re-jet or move spark around in between rounds at a race? If we're going to focus on facts... I have 100's of passes, timeslips, and data logs from a turbo car that I actually bracket race. You're up.
[Re: 1980volare]
#2521955
07/14/18 10:21 PM
07/14/18 10:21 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Time for a group hug. You wonβt find a stronger proponent for turbos than I, but .... If I were building a bracket car, it would be either N/A and light,(choice #1) or turboed and heavy (choice #2) A turbo car that is light and at its limits will repeat easier than that same car turned way down to meet an index. Results may vary...
[Re: FastmOp]
#2522147
07/15/18 02:57 PM
07/15/18 02:57 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
Stupid turbos.
I got runner up last night π
I treed him and out 60 foot him with my new best 1.14
He drove around me. I make 20 PSI on gas. His Procharged BBF on alcy makes 38 PSI . He got me by a car. Running heads up? Or couldn't run your dial? I wouldn't bring a knife to a gun fight.
[Re: FastmOp]
#2522166
07/15/18 03:29 PM
07/15/18 03:29 PM
Posts: 20,180 Park Forest, IL
slantzilla
Park Forest, IL
Stupid turbos.
He drove around me. I make 20 PSI on gas. His Procharged BBF on alcy makes 38 PSI . He got me by a car. Obviously you need more boost!
[Re: polyspheric]
#2522460
07/16/18 10:35 AM
07/16/18 10:35 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
You're up.
[Re: 1980volare]
#2549044
09/11/18 11:35 PM
09/11/18 11:35 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have a turbo problem. I like them so much I had to get two for the next Hemi build.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: an8sec70cuda]
#2549085
09/12/18 01:15 AM
09/12/18 01:15 AM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
After YEARS of reading Poly's posts both on here and elsewhere, there's no doubt he is a thinker and very knowledgable in this caper.
But seriously....his choice of words on forums are perhaps a little abrasive and can be processed as a form of arrogance.
All of us have knowledge some less than others however projecting oneself as the last word is really unnecessary.
We all want to learn as much as we can....without the aggravation.
[Re: 1980volare]
#2549087
09/12/18 01:20 AM
09/12/18 01:20 AM
polyspheric
New York
Yes, it's only helpful if you tell people what they want to hear. Anything else is just sooo hurtful.
Boffin Emeritus
