Re: headers that fit?
[Re: marcjames]
#2520036
07/10/18 03:52 PM
07/10/18 03:52 PM
Posts: 4,329 Morrow, OH
markz528
Morrow, OH
Hookers fit pretty decent in a 67 with a 440. I run 5209 (2 inch).
[Re: marcjames]
#2520040
07/10/18 04:01 PM
07/10/18 04:01 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In my 68 satellite with RB motor I’ve run 1-3/4 Eagle(from the 80’s), and Hooker 2” super comp. I had some SR heads on a RB motor in the car, and installed the TTi 2-2 1/8” step headers for the Indy heads. They were the easiest of the 3 to install.
On my 383 B engine I ran Hooker Competition headers , which are 1-7/8”.
In my car, the Eagles and Hooker Comps were actually harder to get into the car than the big headers, but once installed I felt all four sets fit pretty well.
If you have angle plug heads, the TTi’s generally have the best plug clearance.
[Re: marcjames]
#2520046
07/10/18 04:09 PM
07/10/18 04:09 PM
Posts: 13,495 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: markz528]
#2520183
07/10/18 08:23 PM
07/10/18 08:23 PM
Posts: 43,738 Bend,OR USA
Cab_Burge
Hookers fit pretty decent in a 67 with a 440. I run 5209 (2 inch). I have the same Hooker headers on my 1966 Dodge Coronet Deluxe two door sedan with a stock iron headed (452 heads) 440 motor and those headers fit well and weren't hard to install with the new motor, it was a slant six three speed stick car before so I swapped the K member out to a 1968 B Body V8 K member into it also
[Re: marcjames]
#2520245
07/10/18 10:11 PM
07/10/18 10:11 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
anything other then Cyclone or blackjack.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
