Re: Best Driveshaft Shop near Clinton Twp. MI?
[Re: hemiviper588]
#2519353
07/09/18 12:33 AM
07/09/18 12:33 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Have used DTS( Drive train service) for several things in the past. Driveshaft behind the 727 i just took out to go to a 904 was made by them. Shouldnt be far from you, they are in Warren
[Re: hemiviper588]
#2519431
07/09/18 09:06 AM
07/09/18 09:06 AM
Posts: 1,322 Michigan
crlush
CCI driveline in Casco, im pretty sure thats the place my neighbor went to, he had an aluminum drive shaft built and balanced with no problems. I have dealt with DTS before they have been great also but I believe they send there driveshafts out.
[Re: crlush]
#2519434
07/09/18 09:19 AM
07/09/18 09:19 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
CCI driveline in Casco, im pretty sure thats the place my neighbor went to, he had an aluminum drive shaft built and balanced with no problems. I have dealt with DTS before they have been great also but I believe they send there driveshafts out. I agree. I buy about ten a year from them. great service. they are on 26 mile near meldrum rd.
JAKES AUTOMOTIVE
[Re: hemiviper588]
#2519451
07/09/18 11:12 AM
07/09/18 11:12 AM
Posts: 782 s.e. MI
partsforsale
s.e. MI
Does any one have a recommendation for a drive shaft shop (balancing, re-tube) near the Detroit area? Has anyone used B&L Truck in Warren? Thx I've used B&L once for shortening a shaft and had them put new U-joints in two shafts. Never an issue.
[Re: hemiviper588]
#2519708
07/09/18 09:18 PM
07/09/18 09:18 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Good info I may be needing one soon, if I breakdown and install a GV OD.
What happened to the place in Troy, Dynamic I think it was called? They did mine and their service was just like how you guys describe CCI's service.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
