Re: Last minute Brake issue before Carlisle.. ??? Update
[Re: mymcodebee]
#2519383
07/09/18 01:23 AM
07/09/18 01:23 AM
RapidRobert
I would adj it so there is .020" clearance & an engine 5/16 pushrod makes a good measureing tool to stick into the MC piston "thimble" to get it dead on.
[Re: mymcodebee]
#2519417
07/09/18 05:52 AM
07/09/18 05:52 AM
Posts: 1,757 Phila
PhillyRag
Phila
Checked on the lift when bled. All four tires were locked up when brake depressed. Once we start car pedal pushes to the floor and you can here air loudly under the dash when pedal is depressed to the floor The 'woosh' you here is the entire booster vacuum 'dumping' rapidly, because the pedal went to the floor. With no air in lines, adjustments OK, a pedal should NEVER go to the floor regardless if booster working or not. With no leaks anywhere & bled properly; only way is if m/c seals allowing fluid to leak past seals.
[Re: mymcodebee]
#2519443
07/09/18 10:36 AM
07/09/18 10:36 AM
RapidRobert
when you pickup a MC you might grab those MC port brass plugs & see if your current MC hold pressure (light pedal pressure & stomp it) & if it ain't the current MC then you can return the new/rebuilt one & while you are there likely they will let you use the MC in the box to get the correct fittings (1/2-18 or 1/2-20 or 9/16-18 or 9/16-20 iirc).
Re: Last minute Brake issue before Carlisle. UPDATE
[Re: Andrewh]
#2520102
07/10/18 06:08 PM
07/10/18 06:08 PM
Posts: 21,537 It's a dry heat
gtx6970
It's a dry heat
if you plugged the ports and you had it bled correctly you should not be able to push the rod in at all. It should be hydro locked.
This is correct. Once the rod moves forward it closes off the ports to the bore itself.
[Re: mymcodebee]
#2520783
07/11/18 11:21 PM
07/11/18 11:21 PM
Andrewh
