Re: Fore/Aft limiter
[Re: Kevins493]
#251804
03/12/09 06:45 PM
03/12/09 06:45 PM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
Is a limiter necessary when you have both motor plate and mid plate?
"These go to eleven", Nigel Tufnel
[Re: blownEFI]
#251805
03/12/09 06:54 PM
03/12/09 06:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would definitely use them... 2 flat plates in the vertical plane are not the best for holding a load, they tend to bow under load in a horizontal plane
[Re: blownEFI]
#251806
03/12/09 06:55 PM
03/12/09 06:55 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
.....YES......
[Re: Kevins493]
#251807
03/12/09 08:03 PM
03/12/09 08:03 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I went off my trans, I bushed the holes too.. (street car)
CrAzYMoPaRGuY
[Re: Kevins493]
#251810
03/13/09 07:08 AM
03/13/09 07:08 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Where does it mount on the motor? Thanks.
I looked for a pic of the bracket on the oil pan rail, I can't find one. It's basically a flat plate with a couple of holes to bolt to the pan rail. On the bottom of the plate there is a tab welded to it that the limiter rod bolts to.
[Re: 62SAVOY]
#251815
03/13/09 06:44 PM
03/13/09 06:44 PM
MR_P_BODY
I just went solid all around on my mounts. I made the front mount plates and made a solid mount setup for the tranny. Actually smoother feeling than when i had rubbers all around I kept tearing. I went solid in front and boss just said run a solid on the tranny too. Says he did in his and never had problems. So far all is well and have had it like this for awhile. Am I asking for it solid all around. Doesn't seem it would be any difference with solid fronts and a limiter setup? Could be wrong though?
Seen too many tranny tailshafts broke off due to the solid tranny mount. If you get chassis flex(which you do) it binds on the tranny mount, over time it can only take so much flexing ... but thats up to you to do it any way you wish
[Re: MR_P_BODY]
#251816
03/13/09 07:01 PM
03/13/09 07:01 PM
Posts: 202 CA
62SAVOY
CA
Mr P.
Maybe i should have described how I did it. Maybe that why it working so far? I used trailer receiver square tubing for it. Male tubing is welded to the plate that bolts on the tranny. Than I used the female tubing and notched my tranny cross memeber for it and welded it in. Put a bolt through the assembly mid way facing front to back. Maybe the little bit of slop in the tubing is letting it move around under extreme movements? Thanks for the warning too. I will keep an eye on it. I picked up a spare tranny mount on ebay once. Amazing when u got a car that is not in much demand how cheap you can get things for.
