Page 2 of 4 1 2 3 4
Re: Ritter Blocks [Re: Biginchmopar] #2518287
07/06/18 04:37 AM
07/06/18 04:37 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
It's good to see things coming around for blocks in the Mopar world. boogie
Re: Ritter Blocks [Re: Biginchmopar] #2518334
07/06/18 11:08 AM
07/06/18 11:08 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Any idea what that block weighs?
Re: Ritter Blocks [Re: Biginchmopar] #2518345
07/06/18 11:41 AM
07/06/18 11:41 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By Biginchmopar
Well it's time for an update. My block was being machined and my crankshaft was being built the last 12 weeks.
Thanks for the update, very interesting.
I have a used Bryant crank and have also worked with Jim, he has always been very helpful.
I just picked up a used Winberg crank and they have been very good to work with as well.
Good luck and please keep us posted!
Bill
Re: Ritter Blocks [Re: dthemi] #2518356
07/06/18 12:07 PM
07/06/18 12:07 PM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
On Hughes engines web site it says they weight 215lbs. I'll look for my invoice and see if I can find it.
Re: Ritter Blocks [Re: Biginchmopar] #2518427
07/06/18 02:48 PM
07/06/18 02:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
So you had the cam journals and lifters bushed, was that "needed" or could they have been used "as is" for a lesser build? Same with the bores (cylinder and crank), could they have been sucessfuly as is or did they need work?
Re: Ritter Blocks [Re: Biginchmopar] #2518447
07/06/18 03:24 PM
07/06/18 03:24 PM
Nampa, Idaho
Nampa, Idaho
Well the bore' s are a rough bore, I got the 3.99 and opened mine up, if you run a hydraulic lifter you might be okay, the cost isn't all that much to get them bushed and it's just extra insurance. The lifter galley is raised slightly from the center of the lifter. The cam bearing area can be opened to regular cam and bearings, I went roller and 50mm. It's well worth it for these blocks.
Re: Ritter Blocks [Re: Biginchmopar] #2518451
07/06/18 03:30 PM
07/06/18 03:30 PM
Nampa, Idaho
Nampa, Idaho
Plus depending on the heads you want to use, you'll need to need to have the coolant passages drilled. I'm using magnum heads and drilled 10 holes each side, but you can do it or have the shop do it. And if you go with standard bearings a oiling passage will need to be drilled in the rear journal as stated on the website as well. Roller bearing it's not needed due to the drain back and splash will be enough as Mike at QMP told me.
Re: Ritter Blocks [Re: HotRodDave] #2518453
07/06/18 03:32 PM
07/06/18 03:32 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
On mine the block came ready for 50mm roller bearings, ruff bored to 4.120", and the mains were bored but needed to be line honed. The lifter bores looked great and would work with the 50mm cam.The deck was ruff machined.
So bottom line you would need the block to be decked, line honed and the bores honed to 4.125". Not a lot of work if you ask me.
Re: Ritter Blocks [Re: Biginchmopar] #2518487
07/06/18 04:55 PM
07/06/18 04:55 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Did you ask your machinist how he determined the bore centerline on your rough bored block? Just curious. Not trying to stir the pot.
Re: Ritter Blocks [Re: Biginchmopar] #2518490
07/06/18 05:03 PM
07/06/18 05:03 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Nice, I may end up with one and I'm not even a drag racer. Just a regular guy. smile
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Ritter Blocks [Re: mopardude318] #2518516
07/06/18 06:37 PM
07/06/18 06:37 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I wonder what would be involved in building a big inch P7 aluminum monster. I believe the aluminum block is 1k more but not sure if same improvements have been made as iron block. Does anyone know of a current aluminum block build?
Re: Ritter Blocks [Re: Biginchmopar] #2518535
07/06/18 07:11 PM
07/06/18 07:11 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The blocks are not the same for p7 heads. Im not sure if any of the xrII blocks are working in builds. You can buy an Ernie Elliot aluminum block for p7 heads that can go to 440 inches.
Re: Ritter Blocks [Re: Leigh] #2518541
07/06/18 07:27 PM
07/06/18 07:27 PM
Carson City, Nevada
Carson City, Nevada
I believe on a CNC Rottler
Re: Ritter Blocks [Re: TRENDZ] #2518547
07/06/18 07:41 PM
07/06/18 07:41 PM
Carson City, Nevada
Carson City, Nevada
These block can be made to except P5 heads
Now that might be well worth the extra effort.
P7 Head I don't believe would be any better than a W8 or W9
Re: Ritter Blocks [Re: Biginchmopar] #2518556
07/06/18 07:58 PM
07/06/18 07:58 PM
Nampa, Idaho
Nampa, Idaho
69lawndart on here did a aluminum 420cid Ritter block build,I think that was the size, he helped with some improvments on things he found on his.
Re: Ritter Blocks [Re: Biginchmopar] #2518571
07/06/18 08:51 PM
07/06/18 08:51 PM
Carson City, Nevada
Carson City, Nevada
Sorry I was wrong it was a RMC v30 Block CNC Machine.
Re: Ritter Blocks [Re: Biginchmopar] #2518590
07/06/18 09:52 PM
07/06/18 09:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
So with news getting out that the Ritter blocks are getting better will that news deture Darts interest in getting into the small block Mopar market. Hmmmmmmm.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ritter Blocks [Re: Leigh] #2518601
07/06/18 10:34 PM
07/06/18 10:34 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
he will fixture the block off of the mains and use a CNC boring machine. The same thing for the hone.QMP is not your average machine shop..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Ritter Blocks [Re: WHITEDART] #2518610
07/06/18 10:50 PM
07/06/18 10:50 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Reason I ask, is, if the rough bore is done with the same precision. I wonder how close the two machine centers were, and how close to blueprint, people actually end up with.
Re: Ritter Blocks [Re: Leigh] #2518617
07/06/18 10:57 PM
07/06/18 10:57 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Basically he will cut the whole wherever it needs to be.. they do a lot of file core blocks also
Page 2 of 4 1 2 3 4
