Re: Refreshed 440 sounds like a diesel - video
[Re: Charger446]
#1922424
09/30/15 11:39 AM
09/30/15 11:39 AM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
Thanks for all the replies guys, its much appreciated, Ill be tearing into it tomorrow night, ill pull the valvecovers off and will inspect everything closely.
Im reading many different things about the Edelbrock RPM heads in regards to stock rockers and pushrods, I thought they were an exact copy of the physical size of the iron units.
I set the roller rockers when I had the vally pan off and was able to physically see the lifter on the cam, Im thinking of re installing the Hughes Rockers and pushrods and trying to adjust them again but Im thinking it may be difficult not being able to see the cam and lifter? No it's not that hard though it does make it easier, I have set up a couple of engine that way. The last 2 I did I used adjustable pushrods with stamped steel rockers, so I could set the preload exactly how I wanted it, because not every valve is the exact same height due to casting variation of the heads. Also note that some .904 lifters are also made to fit AMC applications and those lifters the pushrod seat is .200 taller, meaning you have to run a shorter pushrod. This was also the case on those 2 I did as I used Crower cam savers which are AMC spec. :crazyme: If you want give me a call and I'll swing by on my way home and give you a hand.
Mainstream Media is the new Pravda
[Re: Charger446]
#1923403
10/01/15 02:45 PM
10/01/15 02:45 PM
JohnRR
A gulag near you.
Very interesting on the lifters, these were the same ones I used previously with this cam and the old heads and rockers.
Appreciate the offer John, I may take you up on that, Ill be pulling it apart first and will inspect everything tommorrow night after the kids go to bed, Ill report back what I found, and maybe next week if you wouldnt mind taking a look at it that would be awesome.
sure, let me know.
[Re: The Shadow]
#1925446
10/04/15 09:30 AM
10/04/15 09:30 AM
Posts: 282 Northeast MA
Charger446
Northeast MA
Have you checked the torque converter bolts? its a 4 speed now. Thanks
[Re: Charger446]
#1925506
10/04/15 11:07 AM
10/04/15 11:07 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
If you can find an old valve cover, cut the top, bolt it back on and fire it up. This will allow you to do a visual on the valve train without oil flinging all over the place. If nothing is found, swap valve covers and inspect the other side. Make sure there is already some heat in the motor, so that you can maintain a low idle speed.
[image][/image]
[Re: sgcuda]
#1925515
10/04/15 11:13 AM
10/04/15 11:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you can find an old valve cover, cut the top, bolt it back on and fire it up. This will allow you to do a visual on the valve train without oil flinging all over the place. If nothing is found, swap valve covers and inspect the other side. Make sure there is already some heat in the motor, so that you can maintain a low idle speed. If you do this you can press on the adjuster end of the rocker(use gloves) and see if the sound changes.. also... look at the inside of the valve cover.. make sure the rockers arent hitting the baffles.. this really amplifies any noise
[Re: Hot 340]
#1925550
10/04/15 12:26 PM
10/04/15 12:26 PM
Posts: 2,107 Apollo, PA.
B1MAXX
Apollo, PA.
That ticking is half engine speed. Rotational noise is a lot faster jmo I'm with ya But diesels don't tick, they rattle and knock. Going by his description not the vid.....That speed tick from the vid is usually an ex. leak. There is no reason the stock rockers would be causing the issue for a typical freshen up.
[Re: sgcuda]
#1925759
10/04/15 07:38 PM
10/04/15 07:38 PM
JohnRR
A gulag near you.
If you can find an old valve cover, cut the top, bolt it back on and fire it up. This will allow you to do a visual on the valve train without oil flinging all over the place. If nothing is found, swap valve covers and inspect the other side. Make sure there is already some heat in the motor, so that you can maintain a low idle speed. I made one he can borrow from a valve cover I have with a big dent in it.
[Re: Charger446]
#1925814
10/04/15 09:11 PM
10/04/15 09:11 PM
Posts: 77 British Columbia Canada
Challenger340
Just my 2 cents, if it ain't anything obvious under the valve covers, Piston Slap, or it is one of those wrist Pins they "loosened" up is REALLY loose now.
Better to be a "has been" than a "never was".
[Re: Charger446]
#1925897
10/04/15 10:41 PM
10/04/15 10:41 PM
Posts: 17,929 Akron, Ohio
ProSport
Akron, Ohio
My friends small block Chevy was making similar noises last week, the rockers were banging against the valve cover, one valve cover actually split open while I was standing there watching it. Hopefully yours is an easy fix like that.
[Re: Mr.Yuck]
#1926197
10/05/15 12:08 PM
10/05/15 12:08 PM
Charger446
Northeast MA
Again,thank you all for the replies and suggestions, the engine in that last video sounds a bit similar, but mine doesnt change when the engine warms up.
Im pretty sure the bearings were installed correctly, once the motor warms up, the pressure will stay between 40 and 50 PSI, its pegged when cold.
I need to look at the side to side clearance of the aluminium rockers as I know for a fact I added a few shims this time around to get the roller over the valve stem centered. I know I have a few that feel very tight, I cant even get them to move at all.
John, If you have a cut up cover that you wouldnt mind bringing by, that would be great, let me know if you are around later this week. Thanks again guys!!
Mike
