Re: Decent air spray gun for a beginner?
[Re: MrMayhem]
#2516889
07/03/18 02:42 PM
07/03/18 02:42 PM
Posts: 21,455 It's a dry heat
gtx6970
It's a dry heat
All the naysayers of the HF $20 gun should probably try one... I have 4 of them and as well as several high end Sata guns. Are they the same, no but can I shoot a show quality finish with a $20 HF gun, YES! I have 3 cars with best paint trophies shot with those guns... are they perfect, far from but they do work.
Agreed, Ive used a couple of them . with zero complaints. Right down to the airbrush for $10. if something goes wrong, I'll drop it in the trash and go get another one. Im not a painter and would never try to make a living with one of them . BUT, I know enough to paint small parts , brackets , pulleys, etc etc
[Re: astjp2]
#2517480
07/04/18 02:30 PM
07/04/18 02:30 PM
Posts: 2,049 MD
RTSE4ME
MD
[Re: RTSE4ME]
#2517565
07/04/18 04:43 PM
07/04/18 04:43 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Now that’s reasonable! Is the 1.4 tip good? What psi should the regulator be set to when spraying with a gun like this? All of this info has helped me a ton. Thanks to everyone! Wally.
[Re: RTSE4ME]
#2517569
07/04/18 04:52 PM
07/04/18 04:52 PM
crabman173
crabman173
I buy them six at the time--toss the cleaning kit wash them out , use them , TOSS them and keep rolling I have done some great paint work with them!! Not what you want when you are making a living but hey--they are awesome for yard furniture, wood furniture, under hood jobs etc Pressure is the key I have a regulator that I swap from gun to gun
