Burned Ram 3500 identification
#2513345
06/26/18 03:29 AM
06/26/18 03:29 AM
dogdays
Someone dumped a Ram 3500 on my property. No plates, and the cab and part of the engine compartment are burned. It has a steel flatbed and probably was a weldor's truck. It hs a V10 engine and a transfer case putting the front driveshaft under the driver. It has a Dana 80 rear with 4.10 gears. Dual tires. Regular cab.
The VIN plate was destroyed and there is nothing left in the cab or under the hood that easily identifies the truck. The door and jamb are bare except for some ashes.
Where would I find a VIN on this hulk? Any other way to identify? There is a tag on the rear end with a part number. Would this help? Thanks!!!
Re: Burned Ram 3500 identification
[Re: dogdays]
#2513398
06/26/18 10:35 AM
06/26/18 10:35 AM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
check radiator support. Also ive heard either bottom of passenger side frame rail, in area of transfer case or top of frame rail around drivers door area.
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
[Re: ViperDave]
#2513440
06/26/18 12:47 PM
06/26/18 12:47 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
If you know a LEO there are hidden tags that help them ID burned vehicles. Not sure when manufacturers started doing it though. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: dogdays]
#2513531
06/26/18 03:53 PM
06/26/18 03:53 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
No VIN on the engine?
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: dogdays]
#2513766
06/27/18 02:06 AM
06/27/18 02:06 AM
Posts: 954 garnett kansas
rhad
garnett kansas
the round tag on the t case should have a date on it
my ladder of success is missing some rungs
[Re: 73MagDuster]
#2514057
06/27/18 06:33 PM
06/27/18 06:33 PM
Posts: 10,161 A Red State
SNK-EYZ
A Red State
It should be pin etched on the frame rail on the passenger side lower flange near the trans/tcase. Correct. Look there, the VIN is pin etched into the frame. It was done fairly early on the chassis line (frame component assembly) in the plants.
