Re: AAR T/A Exhaust Hanger [Re: Porter67] #2525699
07/23/18 02:22 AM
07/23/18 02:22 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Originally Posted By EV2Bird
If you cant find the pattern, make it.
A plainer blade isnt too costly. Chuck that blade in a mill and make any consistent pattern you like on it. Then go cut your one side that way.
Find the right material and make a bucketful.
I may be wrong but a planer blade would likely tear and chunk the rubber if it doesn't try tearing it from the bed.
So I went to the local rubber supply house and compared samples, nothing is a direct match. Closest material is available in the correct thickness but since I needed to machine the grooves I decided to purchase the next thickness up, unfortunately the guy cut my strip from the thinner material and I didn't realize until at home and ready to machine. That said I decided to test a few cuts and see if it would produce the desired look.
(Cut piece held behind original for comparison in each photo)
First pic is simply to see if I could cut the material and if it would be an acceptable look with shallow grooves.
Second pic is an attempt to cut TO the fiber (without cutting into the fiber and weakening, the material only has 2 plys of cloth, so not an exact material match)
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2525751
07/23/18 09:53 AM
07/23/18 09:53 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
A few pictures of one of the hangers I had kicking around from that warehouse with many others styles.
Rubber is only 3.5 inches long so wont help you.
Rivets same as used on many Mopar hangers, noteably regular E-bodies as seen in last picture....and NO,.. those aren't available.
If you give me some time till I get back there, I can get plenty of correct rubber size on big ol NOS truck hangers they have, that can be cut to size for your AAR hanger
Re: AAR T/A Exhaust Hanger [Re: mccannix] #2525766
07/23/18 10:33 AM
07/23/18 10:33 AM
Ontario, Canada
Ontario, Canada
The rubber on this NOS B-body hangers looks like a close match,... problem is it is only 2 inches wide, 10 inches long.
Re: AAR T/A Exhaust Hanger [Re: mccannix] #2525772
07/23/18 10:55 AM
07/23/18 10:55 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I have the angles and rivets covered (using the original "D" Tube rivets), the only thing missing is the rubber.
While the matting I've found doesn't have as many ply's of fabric, its new, pliable, fresh appearing, , , and certainly strong enough. I can make it appear very close to my original material, and I like that aspect. Seems "original" material can vary just looking at Floyd's example above Vs mine (AAR - T/A), and to a lesser degree mccanix. Not just the number of threaded ply's, but the back texture.
Floyd, do you know for sure yours are factory installed originals or parts counter hangers? With these hangers being AAR-T/A only, it would appear unlikely for such a short run of cars that our examples vary so much, carrying different rivet heads and the rubber has a texture on both the front and back.
I think I'll continue with the rubber I found and keep my eyes peeled for a closer replacement. Perhaps one day I'll run across an exact match and I could replace them once again. Until then, 99.9% (or greater) will never know the difference.
If anyone ever comes across a suitable match (or original piece in great shape), please PM me with details.
Re: AAR T/A Exhaust Hanger [Re: mccannix] #2525773
07/23/18 10:58 AM
07/23/18 10:58 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Material is very good, I think the 3" wide is the killer and during my salvage yard search I didn't run across any cars with a hanger that wide, though I will say there are no trucks in the yard I was at, so I don't know what they look like.
Thanks for all your help
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2525805
07/23/18 12:00 PM
07/23/18 12:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted By AAR#2
The search for conveyor belt material in the correct thickness and pattern is exhausting and near impossible, then theres the issue of buying in small quantity. While it or fiber reinforced rubber are certainly functional options, trying to get a legitimate match to original in a correct thickness and pattern is like finding a needle in a haystack.
pick up the yellow pages and contact building maint companies
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2525833
07/23/18 12:50 PM
07/23/18 12:50 PM
MD
floyd Offline
floyd  Offline
MD
Mine are NOS/over the counter parts
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2560517
10/07/18 09:06 PM
10/07/18 09:06 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thought I'd provide an update . . .
Its been weeks, I ran into a ton of issues trying to cut the material clean.
I tried several thicker materials in a attempt to cut to the fiber and maintain the original thickness. Each attempt was extremely time consuming and resulted in failure for various reasons. Almost defeated I decided to go back to my original material choice and only make low cuts to give the appearance of the raised pattern.
Below are the results (original on the LH side and replacement piece on the RH side.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2560521
10/07/18 09:13 PM
10/07/18 09:13 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
1 more
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2562268
10/11/18 01:51 AM
10/11/18 01:51 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Are those original brackets? Where did you find the rivets?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: AAR T/A Exhaust Hanger [Re: 71TA] #2562339
10/11/18 10:39 AM
10/11/18 10:39 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Bracket on the left is original, one on the right I fabricated based on original examples. I had a set of aftermarket brackets and while functional there was so little right about them I just couldn't use them.
I went to the salvage yard and found an exhaust hanger on a C-body with the "D" rivets as my original, and reused the fasteners with some fancy engineering.
Now that I have a process I'll replace the rubber on the LH bracket as well.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2562345
10/11/18 10:49 AM
10/11/18 10:49 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Check McMaster Carr, they may have something similar and you don't have to order by the Semi Load.
