Re: 1972 340 w/400-450 HP what is a good carb setup.
[Re: Mr T2U]
#2513233
06/25/18 09:31 PM
06/25/18 09:31 PM
Posts: 12,039 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Well.....your estimate for the cheapest EFI system is still over twice the price of the carb set-up. And will probably pass triple the price for many users. And that is still the cheapest set-up with an external pump, no costs for sumping the tank, assuming the installer can handle all the connections, etc. And that cheapest kit is not necessarily the preferred set-up.
What about ignition control? Seems important to get the most from an EFI system. Any extra costs or labor to that?
You seem to have more carb problems than the rest of the posters here. Personally, I do not experience the issues you list with my carbs.
If you want to believe that the cheapest EFI system that is 2 or 3 times the cost of the preferred carb is the way to go.....then go for it. But at least be honest about the comparison and compare apples to apples.
Master, again and still
[Re: Barrelhouse]
#2513684
06/26/18 10:42 PM
06/26/18 10:42 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I have a 750 AED on my 450hp 340....it’s one of the reasons it’s making 450 plus...
A new iron curtain drawn across the 49th parallel
[Re: Mr T2U]
#2513717
06/26/18 11:37 PM
06/26/18 11:37 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
maybe a little more. i would figure about $1K for a COMPLETE FITECH system with external walbro fuel pump and lines. from what i have read they are pretty good overall system with a not so complicated setup. once installed with the basic parameters programed in. then a couple trips around the block it's ready to go. it's self learning so the more you drive it the better it runs.
now with a carb the initial buy in is just part of the price. the weather changes you have to re jet and adjust, the weather changes you have to adjust again. with the alcohol mixed fuel it will eat the seals, accelerator pumps, and floats. now you gets leaks. really hot day you get vapor lock. sit for a while when hot and the fuel boils in the carb. sit for weeks at a time you have no fuel in the car and have to crank and crank until it starts. i know i am exaggerating a bit on the problems, but they do happen a lot. jets, gaskets, air bleeds all cost $$. it adds up. when i had my hemi with a carb i was adjusting it almost every other day. the temp changes 15* and adjust again. runs great in the morning runs a little rough in mid day runs like crap in the evening. or maybe runs great in the AM and PM runs like crap in the daytime. self learning FI almost none of the listed problems happen. hop in and drive. even when it's running a bit off, it is probably running better than a carb could hope to. i know it's not a FITECH system. but my 08 supercharged mustang the only thing i have to do is fill it up and drive. change the plugs 1 time a year and change the oil every 2K miles. car makes 650rwhp on pump 93, runs 10's all day long at the track if i don't miss a shift, drive it to the track, drive it home and gets 25mpg. never had ANY of the above listed carb problems. the only thing i do to it is load my race tune at the track, 5* timing and richen it up a little bit with my hand held tuner don't even have to open the hood to do it.
Bull $hit. I read that if frogs had wings they wouldn't bruise their arses when they landed.
[Re: justinp61]
#2513718
06/26/18 11:40 PM
06/26/18 11:40 PM
Posts: 20,166 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Good old 750 Holley double pump worked well for me.
