Re: Tighten up a street driven HEMI (long?)
[Re: Hemi ragtop]
#2513050
06/25/18 01:50 PM
06/25/18 01:50 PM
Posts: 13,535 Marion, South Carolina [><]
an8sec70cuda
Forgot to mention, but I'm pretty sure mine were set up w/ .0015" intake and close to .002" exhaust stem clearances w/ the std. 5/16" valves.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Hemi ragtop]
#2513749
06/27/18 12:07 AM
06/27/18 12:07 AM
Posts: 43,903 Bend,OR USA
Cab_Burge
The piston alloy(4032 for street motors, not 2618 ) will determine what clearances are needed, any GOOD brand of forged pistons and a good set, not a cheap rebuilder set of 1/16,1/16 3/16 (standard tension oil rings) size file to fit moly rings should work real well, I shoot for .0045 per inch of bore size(.0045 X 4.310= .01935 end gap, round it up to .020) tight and .0050 per inch on the second ring and go have some tire smoking fun , not oil smoking fun I do have the machine shop hone all my blocks with a torque plate and the type of head gasket the motor will run and add .0005 additional piston to wall clearances for all my street and strip or bracket race only motors
[Re: Hemi ragtop]
#2513925
06/27/18 01:23 PM
06/27/18 01:23 PM
Cab_Burge
Some of the after market company don't offer that tight clearance 4032 alloy Ross being one of them JE,SRP and Diamond as well as probably several other do offer any of their custom piston in either alloy JE doesn't own that alloy, the foundries make the piston blanks and the piston makers finish them
[Re: Hemi ragtop]
#2513998
06/27/18 03:36 PM
06/27/18 03:36 PM
an8sec70cuda
My pistons are Diamonds using the typical 1/16", 1/16", 3/16" ring pack. Have been using Total Seal plasma moly rings, not gapless. I'll be switching to whatever ring Diamond recommends me to run for nitrous.
[Re: Hemi ragtop]
#2514039
06/27/18 04:46 PM
06/27/18 04:46 PM
Posts: 12,492 Kalispell Mt.
HotRodDave
Kalispell Mt.
I like tighter piston clearance for noise reduction but once the negine is warmed the higher expansion alloys are supposed to be just as tight as the low expansion ones. Unless you have a really loose piston to wall clearance I dont think it would make it use a bunch of oil unless you had an insuficent ring and bore finish combo.
[Re: Hemi ragtop]
#2514917
06/29/18 12:37 PM
06/29/18 12:37 PM
Cab_Burge
4.360 That is .040 above the stock 440 4.320 bore size Make sure that you get the ring size correct for your application and that those rings are in stock
[Re: Hemi ragtop]
#2515141
06/29/18 11:10 PM
06/29/18 11:10 PM
Posts: 4,821 Moved to N.E. Tennessee
GomangoCuda
I plan on doing whatever it takes to make the bores straight and true. If it has to be bored to do this, what is the next available ring/piston size above 4.350? What block are you using? If that is a stock Hemi block then 4.35 is already too big and could be part of your problem.
[Re: GomangoCuda]
#2516261
07/02/18 06:55 AM
07/02/18 06:55 AM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
I plan on doing whatever it takes to make the bores straight and true. If it has to be bored to do this, what is the next available ring/piston size above 4.350? What block are you using? If that is a stock Hemi block then 4.35 is already too big and could be part of your problem. It is a siamease bore Mega block
