interior paint
#2512229
06/23/18 04:09 PM
06/23/18 04:09 PM
Posts: 46 Toronto, Canada
67fastfish
Toronto, Canada
hello All,
New to the forum, need help to find interior paint, for my 67 Cuda? can someone please help me find the right paint code and where to buy the paint for my car. I am sure I'm leaving some info out. I have the fender tag interior is a dark blue just trying to find the correct color paint.
Re: interior paint
[Re: 67fastfish]
#2512280
06/23/18 07:24 PM
06/23/18 07:24 PM
Posts: 20,786 A collage of whims
topside
A collage of whims
Welcome to the board. I don't have charts for '67, only '63, '68 & '69. Some years they changed interior codes, sometimes they carried over, and some color codes like black tended to span several years. Another thing is that there are usually 4-5 different codes for the different surfaces; if your car is original, you can see the variations. Unless someone can post their '67 info, I'd suggest you shop Ebay for 1967 Plymouth color charts, and make sure the Seller's charts also have the interior info, as some charts don't. Typically DuPont charts are the most complete. Their library is also pretty good for comparing the old #s to their current products. Look around your area for automotive paint suppliers, or ask a local quality body shop who they're buying from.
Re: interior paint
[Re: 67fastfish]
#2512451
06/24/18 03:58 AM
06/24/18 03:58 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Below is a copy of a 1969 Barracuda (not 1967) factory service manual, chapter 23, Paint Charts, to give you an idea of the information you need and how it is organized. See a 1967 FSM for your correct colors.
INTERIOR COLORS BARRACUDA
EXTERIOR GLOSS FINISH COLORS Used On: Integral Door Upper and Lower Garnish. 2 Door Hardtop Quarter Panel Lower Garnish.
Black Velvet, Chrysler Code AY 1TX9, Ditzler Code 9000 Bright Blue Metallic, AY2EB5, 2019 Light Bronze Metallic, AY2ET3, 2030 Dark Green Metallic, AY2EF8, 43786 Bright Red, AYlER6, 2029
GLOSS FINISH COLORS Used On: 2 Door Hardtop Quarter Panel Upper Garnish Moulding. Fastback Headlining Retainer Moulding. Lower Wheelhouse Moulding. Rear Quarter Moulding. Convertible Header and Defogger Intake Bezel.
Jewel Black, Chrysler Code ABlTX9, Ditzler Code 9000 Thunder Blue Metallic, AB2EB5, 13693 Golden Tan Metallic, AY2ET3, 23086 Bayou Green Metallic, AB2EF8, 43926 Rally Red, ABlER6, 71685
LOW GLOSS FINISH COLORS Jewel Black, AB5TX9 9028 Console Only Jewel Black (Semi-Gloss), AB3TX9 9293 Optional for Front Seat Manual Adjuster Majesty Blue, AB5EB9 13686 Console Only Buckskin Tan, AB5ET8 23061 Console Only Bayou Green Metallic, AB6EF8 43929 Console Only Rally Red, AB5ER6 71687 Console Only
SUEDE FINISH COLORS Used On: Instrument Panel. Glove Box Door. Ash Receiver and Steering Column Assembly. Jewel Black AC38VX9 9324 Baltic Blue Metallic AC39EB7 13705 Sienna Tan AC38ET8 23076 Bayou Green Metallic AC39EF8 43925 Regatta Red AC38ER8 71688
Re: interior paint
[Re: kentj340]
#2660763
05/30/19 09:32 PM
05/30/19 09:32 PM
Posts: 704 USA
rftroy
USA
Go here for free service manuals: http://www.mymopar.com/index.php?pid=109And, yes, there are no paint charts in the 1967 Plymouth Service Manual. Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: interior paint
[Re: Barry70GTX]
#2662864
06/05/19 10:18 PM
06/05/19 10:18 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Thanks. Appreciate the additional info from all. That 67 FSM must be Dodge or Chrysler. Paint names are different, but presumably the colors are the same and I should be able to figure it out by cross referencing the SS YY names and color codes. Are the Gloss colors and the Sueded colors in matching order? So a YY interior got 22700 gloss and 22754 Suede?
'67 Plymouth FSM Group 23 is quite different. So maybe I'm missing where such info is, but suspect its not there at all. Maybe in the Parts book instead....
