Tighten up a street driven HEMI (long?)
#2512211
06/23/18 03:25 PM
06/23/18 03:25 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
The questions in this post are aimed at the engine builders on here that KNOW the answers! I developed the desire for a 426 HEMI when I was 10 or 11. Richard Petty was having one of the best seasons in history in a square body, 426 HEMI stock car. I decided then to own one of these cars. Finally in the spring of 2012, I was driving a square body convertible with a 426 HEMI. Everything about the car was designed to be DRIVEN. First it was a convertible, next was power steering and brakes. I also mounted a Gear Vendor overdrive ahead of the Dana with 3.54 gears. The 727 shifts AUTOMATICALLY with the help of A&A components and a Turbo Action valve body. The converter is as tight as PTC could make an 11", 250K+. I've enjoyed driving it over 7,200 miles now, It is just what I wanted with just one problem, it uses WAY too much oil. I have won all the "Best of Show" trophies I want, won at Pigeon Forge 8 times in a row, now I want to DRIVE the car, a lot! I have an extensive collection of original car magazines with many HEMI cars tested new. I know that a lot of them complained that they had to add a quart of oil for every tank of gas, but I am not satisfied with that. I have decided to pull the engine apart over the winter and "tighten it up". I have chased the oil consumption through intake gaskets, Superformance cured that, leak down, compression checks, catch valve in line to the PVC, all to no avail. I suspect valve guides/seals, but conversations with the BEST HEMI engine builders (you know who I'm talking about), have convinced me that it is a combination of cylinder sealing and guides/seals. So, who makes the best piston that has the lowest expansion rate? How tight can I run them? I currently have "Diamond" with 4.35" bore. If I need to, I am prepared to bore the block and buy new pistons. What ring size is readily available after 4.350? Richard Nedbal's book suggests a Napier second ring with a "gapless" top ring. I have a GOOD shop that will get the bore straight and put the proper finish on the cylinder walls. What brand ring do you guys suggest? What wall finish? What ring gap? What type of rings? Next, the heads. I might as well step up to a new, better head. I am currently running MP but am looking at the Edelbrock or Stage V. How tight can I run the valve to guide? What type of seals? I have lost track of the engines that I have built over the years. The last one was a Gen I HEMI with a 6-71 blower for a 32' roadster that has never had a valve cover off since I put it together in 2009! I want my HEMI to be like the LS-7 that I built and installed in a 70' Chevelle with air, PS, PB, tilt etc. in 1995. I drove that car ANYWHERE I wanted and NEVER had to add oil! It is still running strong and dependable. Any and all info would be appreciated. What I want is real, tested solutions by real engine builders. Thanks
Re: Tighten up a street driven HEMI (long?)
[Re: Hemi ragtop]
#2512232
06/23/18 04:21 PM
06/23/18 04:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I am no expert but I run low tension napier second, low tension oil and top rings, the fresh short block (410 SB) would turn over like an old worn out 273 with glazed over walls that burns a ton of oil but this thing never uses oil. This is basically the ring recipe that GM used on the LS motors to fix the oil consumption issues they had. I am running diamond pistons, dont remember the number but we set them to the tightest diamond recomended.
I would also run the bearings all on the tight end of acceptible with a high quality shop doing the work to make sure they are in all the specs like taper, roundness, diameter... everything, not just a quick check of diameter in one place. This will lower oil volume through the engine and a good oil pan and windage tray set up. Then you can run a standard volume pump and keep everything lubed while reducing excess oil on the cylinder walls.
No reason a hemi has to use a bunch of oil.
[Re: Hemi ragtop]
#2512253
06/23/18 05:48 PM
06/23/18 05:48 PM
Posts: 4,457 Washington
madscientist
Washington
The questions in this post are aimed at the engine builders on here that KNOW the answers! I developed the desire for a 426 HEMI when I was 10 or 11. Richard Petty was having one of the best seasons in history in a square body, 426 HEMI stock car. I decided then to own one of these cars. Finally in the spring of 2012, I was driving a square body convertible with a 426 HEMI. Everything about the car was designed to be DRIVEN. First it was a convertible, next was power steering and brakes. I also mounted a Gear Vendor overdrive ahead of the Dana with 3.54 gears. The 727 shifts AUTOMATICALLY with the help of A&A components and a Turbo Action valve body. The converter is as tight as PTC could make an 11", 250K+. I've enjoyed driving it over 7,200 miles now, It is just what I wanted with just one problem, it uses WAY too much oil. I have won all the "Best of Show" trophies I want, won at Pigeon Forge 8 times in a row, now I want to DRIVE the car, a lot! I have an extensive collection of original car magazines with many HEMI cars tested new. I know that a lot of them complained that they had to add a quart of oil for every tank of gas, but I am not satisfied with that. I have decided to pull the engine apart over the winter and "tighten it up". I have chased the oil consumption through intake gaskets, Superformance cured that, leak down, compression checks, catch valve in line to the PVC, all to no avail. I suspect valve guides/seals, but conversations with the BEST HEMI engine builders (you know who I'm talking about), have convinced me that it is a combination of cylinder sealing and guides/seals. So, who makes the best piston that has the lowest expansion rate? How tight can I run them? I currently have "Diamond" with 4.35" bore. If I need to, I am prepared to bore the block and buy new pistons. What ring size is readily available after 4.350? Richard Nedbal's book suggests a Napier second ring with a "gapless" top ring. I have a GOOD shop that will get the bore straight and put the proper finish on the cylinder walls. What brand ring do you guys suggest? What wall finish? What ring gap? What type of rings? Next, the heads. I might as well step up to a new, better head. I am currently running MP but am looking at the Edelbrock or Stage V. How tight can I run the valve to guide? What type of seals? I have lost track of the engines that I have built over the years. The last one was a Gen I HEMI with a 6-71 blower for a 32' roadster that has never had a valve cover off since I put it together in 2009! I want my HEMI to be like the LS-7 that I built and installed in a 70' Chevelle with air, PS, PB, tilt etc. in 1995. I drove that car ANYWHERE I wanted and NEVER had to add oil! It is still running strong and dependable. Any and all info would be appreciated. What I want is real, tested solutions by real engine builders. Thanks If you have to go in and tell your builder how to build the engine, you need a different builder. I don't know a single engine builder (myself included) who will let the customer come in and tell them what rings to run, how to finish the bores, what guide clearance to use and all that. The engine doesn't know it's a Hemi. It has no idea what it is. If your rings don't deal, it's not because it's a Hemi. If the guides are loose it's not because it's a Hemi. A Hemi is no different that any other internal combustion engine.
[Re: Hemi ragtop]
#2512258
06/23/18 06:01 PM
06/23/18 06:01 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
One big reason, the exhaust valve is usually submerged in oil. Get the best valve seals and go over the drain backs in the corners of the head, there's a lot of oil leaks in the rocker assembly up there. At speed I wouldn't be afraid to say 50% or more of the oil capacity is up in the heads. Get a piece of welding wire 1/16 , bend and attach so the end sticks down a little in the center of the hole, this helps promote flow since oil can't swirl in. Can't remember who told me that but it was way back before the turn of the century.
[Re: Oyvind Mopar]
#2512353
06/23/18 11:07 PM
06/23/18 11:07 PM
Hemi ragtop
Tennessee
Beware of one major Hemi-problem, that the rockers sometimes do not line up well and try to push the valvestems away. (Too short, and wrong geometry) This, along with coarse finish on the valvestems can eat the guides after a short while. And the MP alu heads have valvestem clearances same as iron heads, way more than needed on alu heads. When building a Hemi you need special attention to the heads, or you will get an oilburner.... So could the problem be isolated to the heads? Leak down, compression tests all look good. No blow by that I can see. The glass catch can between the PVC and intake never collected oil?
[Re: Hemi ragtop]
#2512388
06/23/18 11:50 PM
06/23/18 11:50 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Yes it could quite easily be a guide/seal problem. My last two Hemi's had Stage V heads prepped by Tim Banning and after running Hemi's since 1980 I was very impressed these two didn't use any oil. They both ran CP pistons speced by Tim as well. I can't remember the clearances though.
Sheldon
[Re: Hemi ragtop]
#2512420
06/24/18 12:49 AM
06/24/18 12:49 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
All the good hemi engine builders and hemi machine shops I dealt with when I ran 426 Hemi motors in NHRA stock class set the intake valve stem to guide clearances at .0000 to maybe .0002 cold on the stock iron heads, around .0015 to .0019 on the exhaust side cold On the Stage V aluminum heads I would use similar clearances for a street motor, make sure the motor has some heat in it, warmed up to at least 100F + before revving it above 3500 RPM I would do a quick check of the clearances by moving the valves up and down in the guides with no springs, keeper or retainers on them first, if they slid up and down easily and no rocking side to side or forward to backwards clean I would use them and oil them up and install the seals and go racing No oil consumption in any of those motors We where using stock type TRW or Speed pro 5/64 file to fit rings back then also
[Re: Hemi ragtop]
#2512644
06/24/18 03:51 PM
06/24/18 03:51 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
If the MP heads have the original guides, I would start looking there. They were over-sized and soft from the factory. I had a new Hemi build, with new alum. MP heads that was smoking. It was the guides! I sent the heads to Modern Cylinder heads, and the problem was solved.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi ragtop]
#2512942
06/25/18 11:23 AM
06/25/18 11:23 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Hemi Ragtop...it sounds like you have a ring seal issue to me.
My 572" hemi is more of a race build that's streetable, but it doesn't use oil. I've never had to add any to it. Been running it since 2006. I don't drive it as much as I used to. Having kids put a damper on that, lol, but it used to see a lot of street time. Not to mention track time.
The first 2 freshen ups, the valve guides and valve stems were worn. First freshen up in fall 2008 I just put in new valves, tightened it up so I ran it for 4 more years like that. This last time I had bronze liners installed along w/ new valves...that was over the winter of 2012/2013. I still use the factory style springs to locate the rockers...may contribute to the guide wear problem? I have MP aluminum heads from the 2005 production range. I use the teflon valve seals on the intakes and NO SEALS ON THE EXHAUSTS.
My main clearances are .0035" and rods are at .0023-.0024 w/ coated bearings. Piston to wall is .0075".
I'll be freshening it up here soon. Hoping to get it on the stand and apart in the next month or so.
