Re: my fresh BB won't idle [Re: JAMESDART] #2513852
06/27/18 12:14 PM
06/27/18 12:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I rarely use the paper gaskets with the valley pan.
Re: my fresh BB won't idle [Re: fast68plymouth] #2513867
06/27/18 12:53 PM
06/27/18 12:53 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Curious what sealant if any you use, Dwayne.
Re: my fresh BB won't idle [Re: JAMESDART] #2514382
06/28/18 12:37 PM
06/28/18 12:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
Years ago I used “high tack”.
More recently I’ve used a very thin smear of black “the right stuff”.
I’ve run them dry as well....... usually when I know there will be manifold swaps involved.
Re: my fresh BB won't idle [Re: JAMESDART] #2514903
06/29/18 01:11 PM
06/29/18 01:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
Until I had things more sorted out, I’d remove the pcv valve and use 2 breathers, and lock out the distributor...... start out at like 32deg.
Re: my fresh BB won't idle [Re: JAMESDART] #2515110
06/29/18 10:50 PM
06/29/18 10:50 PM
nj
JAMESDART Offline OP
nj
I'll try again tomorrow. I put the intake back on.
Re: my fresh BB won't idle [Re: JAMESDART] #2515143
06/30/18 12:11 AM
06/30/18 12:11 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
No gaskets and two beads of Right Stuff on both sides valley pan hopefully... grin
Re: my fresh BB won't idle [Re: JAMESDART] #2515166
06/30/18 01:18 AM
06/30/18 01:18 AM
nj
nj
That's what I did, I had right stuff. I never used the gaskets in the past, Spray copper or smeared a thin layer of the ultra copper or something like that.
This engine i dropped the parts off to the machinist I've known for 20 years. I just wanted machine work, I wanted to assemble it. I never had an issue with his work, great guy. He talked me into him assembling it and run it on the stand, break in the cam.
Re: my fresh BB won't idle [Re: JAMESDART] #2515168
06/30/18 01:30 AM
06/30/18 01:30 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Right on! Hopefully it will help the issues. thumbs
Re: my fresh BB won't idle [Re: JAMESDART] #2525660
07/23/18 12:27 AM
07/23/18 12:27 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Any update?
drinking
Re: my fresh BB won't idle [Re: JAMESDART] #2525689
07/23/18 01:29 AM
07/23/18 01:29 AM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
Possible.... have you tried giving it more timing anyways until it breaks up? Ive had an MSD box play with my timing light and give a way off timing indication. also are you using a factory balancer and timing indicator??
Re: my fresh BB won't idle [Re: JAMESDART] #2525911
07/23/18 04:09 PM
07/23/18 04:09 PM
nj
nj
I was thinking about the msd giving a false reading the other day. It's an old
6al. Maybe I'm way off on the timing. I hooked up the lm2 wideband yesterday and ran it. Light throttle it's 12.2-12.8. When i drop the idle down there is a point where's 1/4 turn on the idle speed
Screw just kills it, is that when it's switching over to the idle circut? It's
not killing it because It's closing too far, I Checked the transfer slot.
At that point when it starts to stumble and die it jumped up to like 15.2.
I did take the carb apart last week and write it all down, I just don't have that in front of
Me right now.
It's an aftermarket balancer professional products or something. It's not a
Big money piece.
Re: my fresh BB won't idle [Re: JAMESDART] #2525917
07/23/18 04:17 PM
07/23/18 04:17 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
sounds like the transition slot is keeping it running and as you drop the idle speed down once you get close to idle speed (and less of the transition slot is below the butterfly feeding fuel) it goes lean and dies.
i would turn the idle MIX screws out to richen it up (a good initial setting here is 1.5 turns out), start it and then drop the idle speed down to where it needs to be. then slowly turn the idle mix screws back in to find your leanest idle tolerance.
