C-Body fuel tank set up for efi #2511853
06/22/18 06:21 PM
06/22/18 06:21 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Anyone sell a C-body (69 Fury) fuel tank with built in efi pump. Planning throttle body efi.
Re: C-Body fuel tank set up for efi [Re: Dart451] #2511939
06/22/18 10:52 PM
06/22/18 10:52 PM
IL
furious70 Offline
furious70  Offline
IL
FWIW I've been running my 70 SF efi since 09 with a walbro 255 hanging on the frame rail sucking off the stock pickup with sock removed and a filter before it and after.
My 70 had evap return so used that as return, it vented to the 4 corners of the tank so my return shoots into a corner to not bubble at the pickup
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: C-Body fuel tank set up for efi [Re: Dart451] #2512127
06/23/18 12:23 PM
06/23/18 12:23 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I have to look current tank over better see what options I have for returns. Thanks for the idea
